CG125 Woes
heytc
PostPosted: 18:16 - 20 Feb 2010    Post subject: CG125 Woes Reply with quote
I'm getting out of my depth with a bike I've recently bought.
It's a CG125 br-j that was been sat idle for 10 years before I bought it. I'm pretty much a novice mechanic so hadn't realised that a bike sitting idle is the worst thing for it.
When I got it home I cleaned out the carburetor and was able to start it up. It sounded great and rode fine for the first half mile then lost power and stopped and I had to push it home.
I was able to get it started again when I changed the spark plug but it ran terribly, backfiring and not idling.
However today it has lost compression - it was reading about 150 from cold the day before. Today it is about 85 and about 95 when I added a little more oil. From my Haynes I take it that the piston or piston ring has gone.
So the advice I'm looking for is am I going to be able to sort this myself ? If it is piston rings that have gone is that all I would have to get ? Any gaskets or anything else ?
Cheers for the advice in advance
Alexio
PostPosted: 18:59 - 20 Feb 2010    Post subject: Reply with quote
Good to hear more CG's getting some love. If it was sat for 10 years did you check / change the fuel, oil, tires, inner tubes, chain, battery and... well I guess there's a hundred things you could check?
I suppose after all this time a piston ring could be worse for wear and deteriorate rapidly after use again. I've heard it isn't that hard but I don't know if you need to drop the engine out of a CG or not to do a top end rebuild / change the piston rings? I really need to know as well because I want to change mine as soon as I can.
New gasket would definitely be recommend yes.
heytc
PostPosted: 19:19 - 20 Feb 2010    Post subject: Reply with quote
I've changed the oil and its got a new battery. It will be getting a new front inner tube. I hadn't thought about getting new tyres for it. Maybe I should - does tyre rubber age badly ?
Beginning to get the feeling that if it can go wrong it will....hopefully the CG's reliability will help me out though.
spiderwheels
PostPosted: 19:38 - 20 Feb 2010    Post subject: Reply with quote
The tyres will be shot after 10 years. If you get it running change them before you ride it Smile
Did you change the oil before you rode it for the first time or afterwards?
Old oil isn't good either. If it was running with 10 year old oil it could have scored the barrel or lunched the big end bearings for example (both of which would reduce compression).
heytc
PostPosted: 19:52 - 20 Feb 2010    Post subject: Reply with quote
I've got to admit that the oil change was after my very brief journey on it. The mechanic I bought it off took it for a short spin round his yard so I thought that a similar short trip would be ok.
Feeling fairly dim but ya live and learn.
Alexio
PostPosted: 20:15 - 20 Feb 2010    Post subject: Reply with quote
I'm sure it'll be fun to take the engine apart anyway Razz
spiderwheels
PostPosted: 20:23 - 20 Feb 2010    Post subject: Reply with quote
Absolutely Very Happy
Hopefully its just the top end. I don't think a re-bore and a new oversize piston is too dear.
heytc
PostPosted: 20:59 - 20 Feb 2010    Post subject: Reply with quote
Thanks for the replies.
I will follow the Haynes manual and have a look inside.
neatbik
PostPosted: 21:05 - 20 Feb 2010    Post subject: Reply with quote
CG engines are very easy to work on and parts arent a lot of money.
You can drop the motor out of the frame in 10 minutes.
Best thing i think you can do is strip the top end down and have a look at whats going on. Feel free to post pics of what you find and people on here will help you.
pepperami
PostPosted: 11:52 - 21 Feb 2010    Post subject: Reply with quote
if you do delve into your bikes guts... .... lots of posts & pictures please..
i`m waiting to pick up an old CG and the more i can learn about them the better Smile
i picked the CG because they are a simple bike....... lets hope that you find out that they are nice and easy to work on, so you can tell us lots! Smile
skatefreak
PostPosted: 12:22 - 22 Feb 2010    Post subject: Reply with quote
Yeah, go for it.
Certainly cant do to much harm!
I took my engine appart and it was in the kitchen for over a month waiting for a gasket and such... When i got it back together and in the bike hearing it go again was amazing Very Happy
Am back at square one but new head gasket in there and i know a heck of a lot more now Wink
Lots of pictures please !
-Jvr
heytc
PostPosted: 02:36 - 06 Mar 2010    Post subject: Reply with quote
Thanks for all the encouragement.
Well I've opened up the bike and had a tinker but still haven't solved the problem.
As requested photos were taken. Here's the cylinder barrel on first inspection -
https://farm3.static.flickr.com/2688/4410034156_ee2f812f50_o.jpg
The barrel itself seemed pretty good to my untrained eyes. Smooth without anything that I could see wrong -
https://farm5.static.flickr.com/4061/4409269845_82814fc1cb_o.jpg
https://farm5.static.flickr.com/4072/4409269611_f22af5c1a8_o.jpg
https://farm3.static.flickr.com/2750/4409269283_5e4c8b13ab_o.jpg
Same with the piston rings. They looked fine to me but maybe I'm missing something -
https://farm3.static.flickr.com/2786/4410035784_94c6631927_o.jpg
https://farm5.static.flickr.com/4047/4409270247_40fa1b8037_o.jpg
While i was turning the engine over with the kickstart I could hear the air coming out of the cylinder hissing. Sounded like it was coming from a couple of places really and I was definate that one of them was the inlet valve because if it put my hand over the inlet hole then part of the hissing stopped.
The valves as they were -
https://farm5.static.flickr.com/4058/4410035478_5529f5796d_o.jpg
Decided to put new valves in coz at least part of the problem was there. New valves installed using grinding paste -
https://farm5.static.flickr.com/4055/4410036102_a62be973d4_o.jpg
So new gaskets installed, new valves installed, cleaned up the carbon and taken off the old gaskets, the piston rings look ok to me (is the lower one supposed to stick out slightly less ? ) but the compression is still barely anything and I can still hear a hissing coming out.
Any thoughts on what I'm missing ? What else can cause catastrophic loss of compression ?
Enjoying messing with my bike and learning loads by taking it apart - wish I could get it running lol.
Many thanks for reading
temeluchus
PostPosted: 02:45 - 06 Mar 2010    Post subject: Reply with quote
Have you checked the valve adjustment?
May be you have a loose rocker and its gone VERY tight.
As long as you've checked the bores (look fine) rings (also look fine), valves (which you've done) this is the thing I would check.
Whilst screw and locknut rockets tend to go loose, it wouldnt be impossible for them to go tight.
heytc
PostPosted: 03:10 - 06 Mar 2010    Post subject: Reply with quote
Thanks for the reply.
The rocker arms seem to be moving fine as far as I can see. The pushrod guide was missing but I got the part from David Silver spares.
I will try to take a short video turning the engine over to show the pushrods in action.
temeluchus
PostPosted: 03:24 - 06 Mar 2010    Post subject: Reply with quote
have you actually checked the clearances?
check it out here:
https://hondacg125.awardspace.com/valve_clearance.htm
Wont take too long, one of the advantages of a bum basic pushrod and rocker engine!
vcrmoss
PostPosted: 12:28 - 06 Mar 2010    Post subject: Re: CG125 Woes Reply with quote
Im not going to help much being a novice myself but am kind of dealing with similar issue on my Gilera Cougar 125 (Honda CG engine)
It also has been sat idle,maybe not for as long but around a year.This is surely most relevant and helpfull topic thread I have found so far.
spiderwheels
PostPosted: 13:59 - 06 Mar 2010    Post subject: Reply with quote
Nice pictures.
It could be the rocker adjustment but looking back at how it failed you said it was riding fine and then suddenly stopped. That seems too sudden to be rocker adjustment (unless the locknut wasn't done up properly of course..)
How's the big end bearing? Does the con-rod move up and down with the crankshaft fixed at TDC?
temeluchus
PostPosted: 16:20 - 06 Mar 2010    Post subject: Reply with quote
i suspect big end failure would be obvious and noisey
spiderwheels
PostPosted: 17:11 - 06 Mar 2010    Post subject: Reply with quote
Possibly, but if it dies suddenly you may not get much chance to hear it Smile
temeluchus
PostPosted: 18:08 - 06 Mar 2010    Post subject: Reply with quote
there would be some pretty dramatic clanking if a big end bearing failed THAT badly to cause the engine to conk out like that!
heytc
PostPosted: 19:09 - 06 Mar 2010    Post subject: Reply with quote
Many thanks for the replies.
I have rechecked the valve clearances and they did need some readjustments but didn't solve the problem unfortunately.
Here's a youtube video of the rocker arms in action, the video is sideways I'm afraid -
https://www.youtube.com/watch?v=rrSeLARI0PI
Also some video of the piston travelling up and down to see if anybody could spot anything.
https://www.youtube.com/watch?v=VhwxaLfopaI
The piston is totally solid when it is in place and doesn't feel like there's something wrong to me. I'm reluctant to take off the cylinder barrel to look at the con-rod because it was a difficult job getting the piston back in last time (Haynes says to push the rings in with fingers - not likely, ended up using some metal cut from a drinks can as a makeshift piston ring compressor)
heytc
PostPosted: 19:12 - 06 Mar 2010    Post subject: Reply with quote
I forgot to mention - the sound of the air getting out might be coming from the holes that the pushrods go into. Difficult to tell but sounds like it.
heytc
PostPosted: 00:46 - 07 Mar 2010    Post subject: Reply with quote
Update -
Believe I've worked out where the problem is. Thought it might be worth slightly overtightening the cylinder head bolts to see if that helped - and it did slightly taking the compression upto 60.
So it seems to be the gasket where the leak is.
How smooth do the connecting faces have to be ? Do they look smooth enough in the photos ? Are there techniques for getting an effective seal ?
I may even solve this Smile
Thanks again
Alexio
PostPosted: 00:49 - 07 Mar 2010    Post subject: Reply with quote
Are you using a new gasket and proper gasket sealant?
heytc
PostPosted: 00:54 - 07 Mar 2010    Post subject: Reply with quote
Using a new gasket but not using any gasket sealant - Haynes didn't tell me to. Sounds promising
The last post was made 16 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 2.04 - MySQL Queries: 16 - Page Size: 134.88 Kb
