Author |
Damon |
Damon World Chat Champion
Back to top |
Pete. |
Posted: 21:36 - 24 Mar 2010 Post subject: |
JB weld is fully oil and petrol resistant once fully cured, but I don't know about araldite. Either way you'll have to remove and clean the casting before application quite thoroughly.
A better option would be to have someone weld over the crack. ____________________ a.k.a 'Geri'
Back to top |
pepperami |
pepperami Super Spammer
Back to top |
Damon |
Posted: 22:01 - 24 Mar 2010 Post subject: |
It looks as if its been repaired before so im guessing the repair has just cracked slightly. The thing is though, one of the bolts has been welded into the repair. So to get the the sump plate off I will have to destroy the plate and grind off the bolt. PITA |
Back to top |
map |
map Mr Calendar
Posted: 22:09 - 24 Mar 2010 Post subject: |
Providing it's clean/grease free then I'd say the liquid metal stuff should be ok for a temporary repair.
I used it on a broken brake caliper bracket as a get me home repair.
Lasted a couple of months until I got a replacement from breaker. Was still ok when I took it off, it's now in the spares draw.
HTH ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger? |
Back to top |
Pete. |
Posted: 22:10 - 24 Mar 2010 Post subject: |
A steel bolt will not be welded to an alloy sump, so you should not have to destroy the sump plate.
Most cracked sumps are a result of contact with the ground. No1 cause is heavy-landed wheelies IMO. ____________________ a.k.a 'Geri'
Back to top |
Damon |
Back to top |
DrDonnyBrago |
Posted: 12:59 - 25 Mar 2010 Post subject: |
I have used steel epoxy putty on a sump that was riddled with holes.
I was under my car picking rust off the sump when a rust flake came off revealing a hole and pouring hot engine oil down my neck... not pleasant
The sump needs to be rediculously grease/oil free before you begin and you need to key the surface so itll stick.
I had better resutls with the steel epoxy paste with a seperate hardener thah I did with putty - mix up loads spread it on thick and even and hope you covered the hole properly - dont be tempted to push it into the crack or else you might get epoxy bits floating in ur oil.
Once it has cured for a week or so, de grease it again and give it a coat of engine enamel - seemed to do the trick for me
This was about 2 years ago - worked well so far |
Back to top |
chris-red |
Posted: 14:21 - 25 Mar 2010 Post subject: |
Just buy a new one that aren't dear.
https://cgi.ebay.co.uk/Yamaha-R1-4XV-Sump-Pan_W0QQitemZ120548055054QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item1c1139580e
I seem to rememeber someone on a triumph forum only paying £40 for a brand new one from a dealer. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
Back to top |
supZ |
supZ World Chat Champion
Back to top |
Tim.. |
Tim.. World Chat Champion
Back to top |
chris-red |
Back to top |
swiftb |
swiftb World Chat Champion
Back to top |
DrDonnyBrago |
Posted: 17:09 - 25 Mar 2010 Post subject: |
If you can get the sump for £20 as people have posted, do that!
Itll cost you £5+ for the putty
My car sump was £180 for OEM or £120 for a dodgy chinese copy.... £5 on some glue seemed like a better option on a car worth £500 |
Back to top |
Handsome |
Handsome World Chat Champion
Posted: 17:33 - 25 Mar 2010 Post subject: |
Back to top |
supZ |
Posted: 17:37 - 25 Mar 2010 Post subject: |
Back to top |
cloric_tzr |
cloric_tzr Brolly Dolly
Back to top |
Pete. |
Back to top |
Damon |
Posted: 21:02 - 25 Mar 2010 Post subject: |
Thanks for the link, but that is already ended. The cheapest I have seen them go for is £60 ish second hand. Araldite is the answer in the short term whilst I try and find a decent replacement.
Thanks for the replies. |
Back to top |
chris-red |
Back to top |
DrDonnyBrago |
Back to top |
BanditsHigh |
BanditsHigh Worse than a woman
Back to top |
Handsome |
Posted: 18:53 - 26 Mar 2010 Post subject: |
That's got a max temp of 150, if your bike's getting that hot it's going to blow up anyway, since I've used it on mine it hasn't budged, moved, cracked, nothing... ____________________ Previous Bikes...Honda NSR 125 RR...Kawasaki Zephyr 550...Suzuki SV 1000 S...Yamaha FZ8...Current Bike...Suzuki GSX-R 750... |
Back to top |
Damon |
Back to top |
andybon |
andybon Nitrous Nuisance
Back to top |
The last post was made 14 years, 32 days ago. Instead of replying here, would creating a new thread be more useful? |
