Bicycle speedos
Gazdaman
I did a trackday!!!
PostPosted: 21:56 - 24 Mar 2010    Post subject: Bicycle speedos Reply with quote
Anyone got one to recommend?
In an absolute ideal world I want one that I can wire into 12v with a backlight, but I suspect I'm not going to get that without splashing on on a motorbike specific one.
Gaz
PostPosted: 23:33 - 24 Mar 2010    Post subject: Re: Bicycle speedos Reply with quote
They hardly use any power - battery lasts ages and is easy to replace.
The Cat's eye one on the zx9 works well, well into triple figures.
The cheap tescos one started to show half speed at around 50mph or so (then a third speed as you get faster).
Go for wired.
In fact, I'm not using the zx9 one now Smile.
Make a separate LED 'front' light either way. (New ones may have back lights, I haven't seen any though.)
Gazdaman
I did a trackday!!!
PostPosted: 10:48 - 25 Mar 2010    Post subject: Reply with quote
You can get some with backlights for not alot. But you have to press a button, which I suspect would get annoying.
I'll probably just go for one of those.
Cheers!
Gaz
PostPosted: 11:19 - 25 Mar 2010    Post subject: Reply with quote
Yea, it is a bit annoying coming up to a Gatso and having to look at the speedo at just the right point as you pass a street light.
If this is for your dirt bike and you're only going to use it/ intending to use it in the day time I wouldn't worry - never had it questioned at MOT.
Gazdaman
I did a trackday!!!
PostPosted: 11:23 - 25 Mar 2010    Post subject: Reply with quote
Good point! I should have bought 2, I'll need one for the KX. This is actually for the SV. I just bought one with a backlight though. £11.95 inc postage.
Gaz
MarkJ
PostPosted: 11:31 - 25 Mar 2010    Post subject: Reply with quote
Are you avoiding the universal morocycle speedos for a reason? I had a generic 60mm one that had a backlight and odometer in it, think it cost £30. Seemed to be accurate too.
Gazdaman
I did a trackday!!!
PostPosted: 12:07 - 25 Mar 2010    Post subject: Reply with quote
Are they not cable driven?
Gaz
MarkJ
PostPosted: 13:04 - 25 Mar 2010    Post subject: Reply with quote
Ah, I thought the SV was cable driven. Go with the bicycle ones then Laughing
Gazdaman
I did a trackday!!!
PostPosted: 16:19 - 25 Mar 2010    Post subject: Reply with quote
You got me all excited! Nah it's electrically driven. I'm wondering if I can use the standard pulse from the speedo drive to run the cycle computer...
Gaz
PostPosted: 16:38 - 25 Mar 2010    Post subject: Reply with quote
They cost a bit more, but you can get motorcycle specific ones, that often have tachos and other functions. Look fairly neat.
There's a thread about someone fitting one in show & tell, reckon it'll be in the index thread.
pa_broon74
PostPosted: 16:57 - 25 Mar 2010    Post subject: Reply with quote
I bought one that purported to be for motorcycles but was in fact just an ordinary push bike model.
Didn't work well at all, it had magnets and shit you needed to attach to the spokes and whatnot. It looked good though, had loads of gadgets on it including a temperature gauge, oddly enough, it was 22 degrees everywhere I went which was nice...
What I mean to say is, if you're procuring one from eBay or the like, look very carefully at the discription, while they might say it's for a motorbike, that might not actually be the case.
Didn't catch anything.
TheDonUK
PostPosted: 16:58 - 25 Mar 2010    Post subject: Reply with quote
I have been riding for the last two years without any instrument lights, the speedo works but has no light, so as you say its a case of glance at it whenever streetlights illuminate.
Infact when i switched my ninja with a mates SV on a ride, i found the illuminations a bit of a distraction TBH.
Playing it by ear seems to work fine for me (as far as police/gatso's etc).
As far as im aware theres no legal requirement to have a speedo is there? and even if there was, how are they going to prove your's does not work if you dont admit it, They have already stopped you...
Gazdaman
I did a trackday!!!
PostPosted: 17:22 - 25 Mar 2010    Post subject: Reply with quote
There are some proper motorcycle ones, with tachos and stuff. But the cheapest I found was about £80.
And some I found are marketed as being motorcycle ones, but when you look closer are just cycle ones.
And it's a construction and use issue to have a working, and accurate (within reason) speedo. Although I've never seen one tested! And it doesn't have any part in an MOT.
But annoyed I didn't buy one for my KX125 now though.
Gaz
PostPosted: 17:32 - 25 Mar 2010    Post subject: Reply with quote
I'm pretty sure there are laws about having a speedo - something about vehicles that can go over 30mph need one? (presumably from before 20mph limits.)
TheDonUK
PostPosted: 17:55 - 25 Mar 2010    Post subject: Reply with quote
I would be interested to know for sure.
I always thought its one of those things that if fitted, legally has to be working but there was no part of the road traffic act that stated you require a speedometer to use it on the public roads?
Gazdaman
I did a trackday!!!
PostPosted: 17:58 - 25 Mar 2010    Post subject: Reply with quote
It's in construction and use. Finding the proper legislation is a bit of a mission though:
https://www.dft.gov.uk/pgr/roads/vehicles/vssafety/regulationsforpoweredtwoandt4564
Gaz
TheDonUK
PostPosted: 18:06 - 25 Mar 2010    Post subject: Reply with quote
3.6. Speedometers
Every motorcycle first used on or after 1 April 1984 and capable of more than 25 mph must have a speedometer which reads in both miles per hour and kilometres per hour either simultaneously or separately by the use of a switch. A speedometer which is approved to Community Directives 75/443/EEC as amended by 97/39/EC, 2000/7/EC or to UNECE Regulation No.39 is acceptable.
Guess you lot were right then.
Anyway it just seems very hard to prove no?, I mean so im stopped lets say by a really ratty traffic cop who hates my guts and is going over the bike with a magnifying glass for anything, whats he going to see? a speedo that reads 0, because the vehicle is stationary, i in no way would allow any authorities to ride my bike (even if they were allowed by H+S regs), so what they are going to bring a dyno out? naa mate...
Bit like the old 33bhp law
Gazdaman
I did a trackday!!!
PostPosted: 18:08 - 25 Mar 2010    Post subject: Reply with quote
Any Police officer can test a vehicle upto the level of his/her expertise. So it could be tested. The chances of it happening? Pretty much nil.
Gaz
PostPosted: 18:09 - 25 Mar 2010    Post subject: Reply with quote
I can remember (Ariel maybe?) getting through an MOT with a GPS when no speedo was questioned.
Gazdaman
I did a trackday!!!
PostPosted: 18:15 - 25 Mar 2010    Post subject: Reply with quote
Yeah I read that. I can't see any problems with that, it has a damn accurate speedo reading on it.
Legal. I suspect some MOT testers wouldn't like it though.
Gaz
PostPosted: 18:17 - 25 Mar 2010    Post subject: Reply with quote
Not that I wish to give 'you lot' any ideas Wink, but.... there can be some issues when between high buildings and obviously in tunnels.
MarkJ
PostPosted: 18:18 - 25 Mar 2010    Post subject: Reply with quote
I'm sure someone told me that speedos aren't needed for an MOT as they aren't checked - but they are a legal requirement (as stated above). Might be wrong.
Gazdaman
I did a trackday!!!
PostPosted: 19:24 - 25 Mar 2010    Post subject: Reply with quote
Yeah they're not tested in the MOT, so it doesn't have to work. but I'm not sure if it would still fail if there isn't one there at all.
Gaz
MarkJ
PostPosted: 23:42 - 25 Mar 2010    Post subject: Reply with quote
From here: https://www.motester.co.uk/CarOwnersGuidetoTheMOT/MOTQA/MOTQApage3.aspx
MOTORCYCLE SPEEDO
Does my motorcycle require a speedometer for an MOT? If not what milage would the Tester put down on the VT20 or VT12? Phil
You will be pleased to hear that the speedometer is not checked in the MOT. The Tester would simply note that the motorcycle has no speedometer.
Looks like you're ok without one at all Thumbs Up
The last post was made 16 years, 161 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 123.45 Kb
