manufacturers valve clearances bullshit?
MaybeGuy
PostPosted: 18:50 - 28 Mar 2010    Post subject: manufacturers valve clearances bullshit? Reply with quote
are they just set to be on the VERY safe side?
Just thinking of linear expansion here.
without boring everyone with formulas and bullshit:
using coefficients, steel expands roughly 1mm per meter per 100 degrees
so if a valve is about 60mm long, and if you take the cam into it as well (as it is also a factor), say its roughly 40mm diameter.
at 100 degrees, the valve clearances should be just over 0.1mm to allow for a gap? ie: half what the manufacturers state? and seeing as an engine keeps a consistent temperature of about 70 degrees, should be even less?
or am i completely missing the point?
neil.
PostPosted: 19:48 - 28 Mar 2010    Post subject: Reply with quote
Seems right for my bike then... 0.08 - 0.12 on inlet and 0.10 - 0.14 on the exhaust. Remember the valves are right on/in the combustion chamber, where temperatures will be much higher than 100C (I read somewhere that it was hot enough to melt platinum which would be over 1700C!).
Ichy
PostPosted: 19:55 - 28 Mar 2010    Post subject: Reply with quote
You missed the bit about the engine casing expanding at a higher rate, roughly twice the coefficient of expansion of steel.
PostPosted: 20:22 - 28 Mar 2010    Post subject: Reply with quote
The gaps are calculated to allow a certain amount of seated-time for the valves to keep them from over-heating at the lip. Simply having a clearance isn't enough to keep the valves from burning out.
The last post was made 16 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.96 - MySQL Queries: 14 - Page Size: 40.89 Kb
