Suzuki gs650 katana 83 Side case removal
bradh511
PostPosted: 18:41 - 11 Apr 2010    Post subject: Suzuki gs650 katana 83 Side case removal Reply with quote
hi there im trying to remove the left hand side case off my dad katana for him... as it fell over and has a small crack ( leaking oil)
i just cant seem to get it off try'd priseing it away with screw driver to no affect and hitting it with a hammer..
What Next
Thanks Brad
That_Hornet
PostPosted: 18:46 - 11 Apr 2010    Post subject: Reply with quote
Pictures would be useful Wink
Odie
PostPosted: 19:35 - 11 Apr 2010    Post subject: Re: Suzuki gs650 katana 83 Side case removal Reply with quote
What Next
Thanks Brad
Make sure you have found all the bolts!
Also, under that casing is the alternator, it has a strong magnet, the casing will pull off by hand but be carefull of your fingers!!!
Do not hit it with a hammer as the rotor that the alternator sits inside is also part of the starter !!!
odie
If the casing is cracked a casing from a GS550 will fit.
PostPosted: 20:33 - 11 Apr 2010    Post subject: Re: Suzuki gs650 katana 83 Side case removal Reply with quote
What Next
Thanks Brad
Do your dad a favour and leave it alone.
PostPosted: 21:46 - 11 Apr 2010    Post subject: Reply with quote
Don't hit it you will break things. As has been said it is the alternator and a strong magnet underneight keep prising with the screw driver you will get it efventually. If you think getting it off was hard wait till you try putting it back on.
The last post was made 16 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.97 - MySQL Queries: 14 - Page Size: 45.1 Kb
