anyone know about shower pumps? (plumbers!!)
steven_191
PostPosted: 17:44 - 16 Apr 2010    Post subject: anyone know about shower pumps? (plumbers!!) Reply with quote
im going to be fitting one to a hot water supply. it needs to be a negative head pump and is only needed for the hot. the cold is mains pressure.
now i can get a stuart turner pump for about £325
or i can get one by Mabis, which i was told is manufactured by watermill (which is now actually owned by grundfos) and i know grundfos are good. that is a positive head pump for £99 but with a negative head conversion kit for £50. so £150 all in.
the stuart turner is a single pump. the Mabis is a twin.
so if i go for the cheaper twin pump, is there any problem is having a very low pressure hot supply and a mains pressure cold supply? would this cause an unbalance in the pump as it isnt variable impellers or would it run fine?
Al
PostPosted: 16:12 - 17 Apr 2010    Post subject: Reply with quote
On any shower pumps I've seen, it always says that they shouldn't be mains fed. They normally state that they should be balanced tank feeds. I think the max inlet pressure the manufactures state is less then mains pressure.
If you have a cold water tank could you not run a feed down to the twin impeller pump so you've got balanced feeds.
These are an interesting idea and would be ideal for your situation - https://www.new-team-showers.co.uk/Newteam-Jetstream-Venturi-Showers.html
But I've no idea how well they work.
Yamaha FZR400RR 3tj
My Instagram Thingy
The last post was made 16 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.7 - MySQL Queries: 14 - Page Size: 32.34 Kb
