zxr750 indicator problem
dansrockin
PostPosted: 12:08 - 20 Apr 2010    Post subject: zxr750 indicator problem Reply with quote
hi, i noticed yesterday that my right side indicators on my zxr750L are not working as they should. the left one work fine, but when the right ones are turned on, i just get a fast ticking noise from the relay, and nothing at the bulbs. if take the back bulb out, the front one comes on and stays on as it would normally if a bulb had blown. as soon as i make contact with the back bulb though, the front goes out and the relay starts buzzing again.
i know there is power getting to the back bulb as when i touch the neg wire to the bulb holder, there is a little spark as it touches.
anyone know if its likely to be wiring issue or the relay or maybe something else? i dont really want to be ripping my bike to bits if its something really simple!
thanks
dan
dansrockin
PostPosted: 10:45 - 23 Apr 2010    Post subject: Reply with quote
i got this sorted!
i swapped the bulbs and it worked for a second and then went off again, so i guessed it must be something else. as i was taking the bulb out, the glass part came away from the base of the bulb! so i had to get a new bulb anyway, and they are not cheap!!! £6.50 for a tiny indicator bulb!
but, i noticed that the bulb holder positive terminal was loose and shorting out on the side of the holder. so after a bit of fiddling and moving wires around its now sorted.
just to make things that bit worse, as i was putting the bulb back in i dropped it and it went down a drain so i had to get another!! Laughing
dan
cb1rocket
PostPosted: 13:15 - 23 Apr 2010    Post subject: Reply with quote
£6.50??!?!!?
more like 1 quid or less, what are they? 12v 10W bulbs?
The last post was made 16 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.14 - MySQL Queries: 14 - Page Size: 35.74 Kb
