Squealing Rear Drum - Help before I go insane!
herulach
PostPosted: 22:20 - 10 May 2010    Post subject: Squealing Rear Drum - Help before I go insane! Reply with quote
Having finally picked myself up a bike (YBR125 -2005) its developed an incredibly annoying squeal from the rear drum brake.
Any ideas how to go about sorting it? If it was a disc I'd say the pads where probably out of line (or at least thats what it would be on a mountain bike) but I don't think the same reasoning applies to drums.
prawny1
PostPosted: 22:51 - 10 May 2010    Post subject: Reply with quote
Cleaning the dust out and scuffing up the drum face will help along with giving all the pivot/contact points on the shoes and springs a light coating of copper grease/ anti squeal paste.
As a safety precaution use an aerosol brake cleaner to remove brake dust and catch the run off with a cloth to trap the dust, just in case the pads contain asbestos.
hellkat wrote:
Some people are only alive cos its against the law to kill them.
yvaiwhy
PostPosted: 23:06 - 10 May 2010    Post subject: Reply with quote
check the springs...i had a similar problem with my bike..i grinded them a lil from each side with a die grinder and no it hasn't snapped off and still still going strong after an year also Smile
Don't break the speed limit, Just multiply it by 10 times and you will be fine Smile
yen_powell
PostPosted: 07:23 - 11 May 2010    Post subject: Reply with quote
Take the back wheel off, lift out the drum. Tap out the brake dust, then wipe round the drum with a damp cloth.
Takes me back that does, my CG used to suffer with the embarrassing rear brake squeal.
XT1200Z and a DR350 in bits
neil.
PostPosted: 09:07 - 11 May 2010    Post subject: Reply with quote
As said, just needs a clean out and re-grease. Brake cleaner and kitchen paper are good for the drum. Roughen up the shoe surfaces as well. Also remove, clean and grease the cam in there as they do seize up if you neglect them. I use lithium grease on the cam where it rotates in the plate and copper grease on the part that is in contact with the brake shoes and also on the pivot opposite. Thumbs Up
herulach
PostPosted: 21:24 - 11 May 2010    Post subject: Reply with quote
Thanks guys,
I really should have just waited until my haynes manual came in the post today.
Just spent a very satisfying 2 hours faffing with it. Need to go buy a socket set to get the wheel off, but at least I've got the bodywork nice and shiny!
neil.
PostPosted: 22:00 - 11 May 2010    Post subject: Reply with quote
The Haynes manual, although great, lacks detail with regards to the rear brake plate assembly (how the cam fits etc) but the official Yamaha service manual for the bike is more thorough (I use both in conjunction with each other as Haynes tends to be more descriptive of how/why you do things whilst the Yam book is very to the point and 'instructive' but with little explanation of technique etc.
Grab it here: https://dl.dropbox.com/u/175946/YBR125ED_3D9-E0.PDF
Grab the parts catalogue here: https://dl.dropbox.com/u/175946/Moto-YBR125ED-3D91-2005.pdf
herulach
PostPosted: 06:54 - 12 May 2010    Post subject: Reply with quote
Thanks for that, the only one I'd found previously was in spanish, not that useful!
The last post was made 16 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 55.73 Kb
