| G |
 G The Voice of Reason
| tatters |
 tatters Exxon Valdez
 Posted: 10:32 - 11 May 2010 Post subject: |
A CNC would,nt be any good, press out the stem and have someone with a lathe take it down to the diameter required of course leaving enought at the end to fit back in to the yoke with a flush fit.
With bearings find tapered needle bearings that OD fit the headstock with a ID that you can machine the stem down to. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| G |
 Posted: 10:42 - 11 May 2010 Post subject: |
I’m taking it to a bike-specific machine shop that should be able to do what’s needed (whether they need to press it out or not to stick it on a lathe). Sorry, just generically used ‘CNC’ - they may or may not use a CNC lathe in this case .
I’d much prefer to use needle roller bearings, but not sure there’ll be space for the right type – while presumably may be able to get ball bearings in a bit narrower configuration? |
| MarJay |
 MarJay But it's British!
| G |
 Posted: 11:28 - 11 May 2010 Post subject: |
Hopefully – it’s pretech I’m taking it to this lunch time .
As it’s a pretty simple job, I don’t see the problem with that – it’s with getting bearings to fit. It would be much easier for me if I could get it to fit without skimming it down more than the top section – that way I wouldn’t need to make a shim for the top yoke or other general hassle like the threaded section for the top yolk nut being too thin (though could possibly stick a threaded rod through it instead). |
| G |
| G |
| Pete. |
 Pete. Super Spammer
 Posted: 00:09 - 12 May 2010 Post subject: |
Better to find the bearings, then machine parts to fit. ____________________ a.k.a 'Geri'
The last post was made 16 years, 124 days ago. Instead of replying here, would creating a new thread be more useful? |
