| Gazdaman |
 Gazdaman I did a trackday!!!
 Posted: 15:27 - 17 Mar 2010 Post subject: SV650 Road/track project |
This bike is another communal BCF bike, having belonged to both Jay12329 and MarJay.
It's got a good spec, it's got cams from a pointy model which gives slightly more power. A full micron exhaust system, k&n filter, braided hoses, maxton fork internals in pointy model forks, maxton rear spring and Pirelli supercorsas both ends.
The engine itself has done around 10k, with the chassis done about 30.
https://www.gaz-racing.co.uk/images/vehicle_962.JPG
So I paid MarJay and went down to pick her up, having only seen photos:
https://www.gaz-racing.co.uk/images/vehicle_1067.JPG
Bike's decent, it's pretty much complete, comes with a fair few spare parts, like a spanking new clutch cable and adjuster, set of brake pads and a mint petrol tank.
The bike came with a complete set of plastics although they were scuffed and broken. Not an issue, I would use them until some mint ones came along.
As we started to strap it down it became apparent that the front mudguard was fingertight. Never mind, whipped that off and drove back to Leicester.
https://www.gaz-racing.co.uk/images/vehicle_1031.JPG
My first task to get it MOT worthy was definitely to buy a legal sized numberplate. The original was laughable! The bracket that it bolted to was wider than the numberplate itself.
Then I fixed the other glaring MOT failure, which was an extremely worn rear supercorsa. So I replaced it with another supercorsa scrub.
https://www.gaz-racing.co.uk/images/vehicle_1065.JPG
I also changed that god aweful exhaust bracket, that you can see in the first picture.
https://www.gaz-racing.co.uk/images/vehicle_1064.JPG
Also changed the clutch cable and adjuster on the lever as it'd split straight down the middle.
https://www.gaz-racing.co.uk/images/vehicle_1059.JPG
With those jobs done I started to fit the bodywork in order to take it for its MOT. On my way I found a random cable poking out the side of the petrol tank. A bit of pokery worked out it was the choke cable.
I lifted the tank and found it was the choke cable for the front carb. A bit more pokery found it wasn't fitted because there was already a choke plunger seized in the carb. Balls. I tried to release it, but even grabbing it with pliers it wouldn't twist, or pull out.
So I put it all back together.
When I got to start fitting the bodywork I found that all the mounting points on the headlight were broken, and it was only held on by the bodywork, which was very shakey!
So I decided to remove everything to see the extent of the damage.
https://www.gaz-racing.co.uk/images/vehicle_1066.JPG
Sadly I then had to pronounce the headlight dead. The clocks were ok, with only one mounting bolt snapped.
So to remedy the problem of both the headlight, and the scabby bodywork I've decided to go naked and I've bought a 7" single round headlight with mounts. And some chrome mirrors and mounts to match.
For the moment I'll make some bracketry to attempt to mount the existing clocks until I find a better looking alternative. My only concern is that the faired clocks are remarkably ugly and are usually hidden by the fairing.
Apologies for the poor photos, that's my phone for you.
So I've also bought a new set of carbs to replace this front one to remedy the choke problem.
So I paid £800 for the bike, and I've spent about £100 in parts for it so far. And I expect to have it on the road for not a lot more.
Then this winter I intend to take it off the road, strip it down completely and powdercoat the frame and swingarm.
Gaz |
| MarJay |
 MarJay But it's British!
 Posted: 15:50 - 17 Mar 2010 Post subject: |
https://www.twinshack.co.uk/prods/images/295_3.jpg ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| Gazdaman |
| MarJay |
 Posted: 16:37 - 17 Mar 2010 Post subject: |
That is hideous.
The one I posted is correct. The one you posted is just plain wrong. In fact, its brimming over with wrongability. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| Gazdaman |
| MarJay |
| Gazdaman |
| MarkJ |
 MarkJ World Chat Champion
 Posted: 17:08 - 17 Mar 2010 Post subject: |
| Gazdaman |
| MarkJ |
 Posted: 17:23 - 17 Mar 2010 Post subject: |
I reckon a headlight would be OK in those. There's a guy on ebay selling single projector headlights for £75 (clicketh) which have a flip down cutoff line (so dipped and full in one projector unit). Buy one of those, cut a hole in the front of fairing. Make a bracket that is vertical, out of metal/wood/fibreglass on the back of the nose cone. Screw the projector to said bracket, job jobbed. Then just stick a white LED somewhere on the front for the side light  |
| Gazdaman |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 21:49 - 17 Mar 2010 Post subject: |
GSXR forks?  ____________________ My Flickr |
| Gazdaman |
| MarJay |
| Gazdaman |
| instigator |
 instigator Super Spammer
 Posted: 00:29 - 18 Mar 2010 Post subject: |
How much did you but it for?
I'm on the lookout to buy an sv shortly, under £1000, but try and find one below that figure with reasonably low mileage (crash damaged is fine...). Early Sv's are well overpriced at the moment.  |
| twotakt |
 twotakt World Chat Champion
| Clanger |
 Clanger Stirrer
| ms51ves3 |
 ms51ves3 Super Spammer
| 400bandit |
 400bandit World Chat Champion
 Posted: 19:52 - 18 Mar 2010 Post subject: |
I think this SV looks the nuts (not just because its mid-air!)
https://www.seppes.com/photos/635375357_ZVtNB-XL.jpg
Joe ____________________ Current Bikes 650 Honda Bros, VTR1000 Firestorm // Past Bikes: Sachs Madass 50/110cc - Bandit 400 - FZR750
(+ a XS650 in lots of pieces in my garage and other places...) |
| Gazdaman |
| Wafer_Thin_Ham |
| MarJay |
| twotakt |
| DynaMight |
 DynaMight World Chat Champion
The last post was made 16 years, 215 days ago. Instead of replying here, would creating a new thread be more useful? |
