Derestricting my Ped
tweezy
PostPosted: 23:22 - 10 Feb 2010    Post subject: Derestricting my Ped Reply with quote
Hi all, I've just reached 17 and I wish to derestrict my 50cc Vivacity Moped, if anyone has any ideas how to do this, then please respond!!
Thanks guys, also, pics or a step-2-step giude would be awesome ^^
~tweezy
PostPosted: 23:44 - 10 Feb 2010    Post subject: Reply with quote
You would probably want a new exhaust and rollers.
https://cgi.ebay.co.uk/PEUGEOT-VIVACITY-50-SCOOTER-RACE-EXHAUST-inc-50-FREE_W0QQitemZ350130560268QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item5185685d0c
Thats a decent kit i suppose.
Then maybe a free flowing air filter, carb rejet..
that might be all, many 2 stroke tuners on here... they will add more info/bash the shit out of me for giving you the wrong stuff Laughing
Doovy
PostPosted: 23:52 - 10 Feb 2010    Post subject: Reply with quote
for a start, its probably got a restriction washer nut thing in between the variator (most 50cc peds are restricted this way)
transmission case off
variator nut off (usually on left of casing, variator will need to be locked in place not to move)
remove small washer stopping the two halves of variator from coming together completely
re-assemble
sorted! at least, my 50cc yamaha jog r was that way..
PostPosted: 00:16 - 11 Feb 2010    Post subject: Reply with quote
It's not a washer on a Peugeot, it's a plate which is behind the variator bolted onto the back of it with three 8mm bolts. Remove that and the variator is de-restricted.
The variator nut should be torqued up to 40Nm if you have a torque wrench (don't worry if you don't, just do it up tight) and some Loctite 243 should be used to stop the nut coming undone when ridden.
There is also a resonator pipe on the exhaust that needs cutting off and the hole welding up. The carb needs re-jetting but I have no idea what to.
Visit: www.pug-club.co.uk
They'll be more helpful than BCF.
AmyDobinson
PostPosted: 20:52 - 26 May 2010    Post subject: derestrict piaggio zip Reply with quote
hello everyone ive got a piaggio zip 50cc. ive just bought a endy exhaust pipe as was hoping it would make it go that little bit faster but its the same speed what can i do to make it go faster? as 30mph is a little boring please reply thankss
ADobinson
The last post was made 16 years, 107 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.84 - MySQL Queries: 14 - Page Size: 44.04 Kb
