Rough cost of carb clean fro gpz 1100
markimari
PostPosted: 19:50 - 15 May 2010    Post subject: Rough cost of carb clean fro gpz 1100 Reply with quote
HI there just picked up a gpz 1100 been standing for over a year, it won't idle even after I changed oil plugs filters so I'm guess carbs could do with a clean, once yer on the open road rides great just cuts out when yea stop. How much would I pay for a carb clean as I've never done this myself and wouldn't be too confident to take it on Question
temeluchus
PostPosted: 22:03 - 15 May 2010    Post subject: Reply with quote
few hours labour. I would be surprised to see much change out of a hundred quid.
I dont know about the aircooled one but if its the watercooled GPz1100, the airbox is a total pig to fit,
markimari
PostPosted: 22:09 - 15 May 2010    Post subject: Reply with quote
cheers mate was budgeting for round 150ish, ah well a few less pints next month Crying or Very sad
markimari
PostPosted: 17:36 - 16 May 2010    Post subject: Reply with quote
Vincent wrote:
Is it a fuel injection one? A lot of people retro fitted CV carbs on those due to problems with the original carbs if I remember right.
Check this out re ultrasonic cleaning:-
https://www.jrs.uk.com/Motorcycle_carbs_-_older_machines.html
tis not a fuel injected one its on an 01 plate ABS model and only covered 18000 miles has been sat idel for a few years in the shed off the bloke I bought it off
will check out link cheers
temeluchus
PostPosted: 22:25 - 16 May 2010    Post subject: Reply with quote
The 90's ones are more related to the ZX10/ZZR1100.
The ZZR has a downdraught head, but the GPz has sidedraught. The GPz is where the ZRX engine came from.
markimari
PostPosted: 20:16 - 17 May 2010    Post subject: Reply with quote
cheers lads popeed into bike shop on the way home lad in there said would do it fro 80quid so once pay day comes I'll be getting her sorted can't wait Mr. Green
Rowey
PostPosted: 20:52 - 17 May 2010    Post subject: Reply with quote
Sounds like your carbs could be out of synch too. This would be better done by a shop unless you want to pick up a vacuum gauge and the necessary adapters.
Cleaning them is very easy. I've used carb cleaner to good effect. I've also chucked a pair in the dish washer, again it worked very well.
£80 seems a lot of money for something that'll only take you a couple of hours to do one weekend.
ZX6R C6F.
Phoenix
Twisted Firestarter
PostPosted: 23:54 - 17 May 2010    Post subject: Reply with quote
Cleaning out carbs is an easy job, least I thought so until today when I spent pretty much all afternoon just trying to get the rusted, seized carbs off a Varadero 125, there's about 15 pipes and cables attached to them aswell, an absolute joke, wish I'd never started it. GPZ1100 should be a lot easier though, takes about 15mins to get them off on a Fireblade and another 30 to have the bowls off and checked. Synchronise them once they're back on, if it's running badly then they're probably out.
temeluchus
PostPosted: 04:19 - 18 May 2010    Post subject: Reply with quote
its a sidedraught engine so you have to manueaver the airbox around the frame rails. It is a total pig-nowhere near as easy as a downdraught engine.
The last post was made 16 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 14 - Page Size: 68.66 Kb
