| Daryl86 |
 Daryl86 Two Stroke Sniffer
| Ichy |
 Ichy World Chat Champion
 Posted: 15:56 - 06 Jun 2010 Post subject: |
Its Chinese, be grateful it runs
Backfiring on the overrun isn't a big problem and can be just a bit of fuel 'trapped' when you shut off the throttle being burnt off.
Might be related to an air leak in the exhaust but, personally, unless it gets worse and everything else is ok then just ignore it for now. |
| Daryl86 |
| doggone |
 doggone World Chat Champion
 Posted: 17:08 - 06 Jun 2010 Post subject: |
Might be letting air into exhaust near engine.
Probably won't do any harm but in theory the back pressure from explosions could damage exhaust valves, so doing it a lot is not good.
Occasionally, it's more of a feature - which can be kinda fun if you suss out how to make it happen on demand  |
| drzsta |
 drzsta World Chat Champion
| Daryl86 |
 Posted: 17:56 - 11 Jun 2010 Post subject: |
Ive adjusted the fueling and it seems to have got better now.
I have another problem with the bike though! When doing 60 ish in top gear if you back off the throttle slowly it seems like the bike jerks slightly. This is affecting my confidence in some corners because it unsettles the bike.
Its not like a sudden jerk though, it seems like the bike speeds up a little and slows of its own accord. Its slightly hard for me to put into words
It only does it when im in 5th gear though. Any other gears, rolling back off the throttle seems fine.
Any more help is muchly appreciated  |
| stirlinggaz |
 stirlinggaz World Chat Champion
| Daryl86 |
 Posted: 18:17 - 11 Jun 2010 Post subject: |
Funny you should mention that. I had the day off work today and spent some time tinkering with the bike. I have adjusted the chain anyway, because it seemed very slack. I didn't connect the two problems together as I'm new to working with motorbikes.
These 125's are easy as hell to work on though which is good! I haven't had a chance to ride the bike today after adjusting the chain tension but I will be out on it tomorrow and see how it rides.
Cheers  |
| stinkwheel |
 Posted: 20:17 - 11 Jun 2010 Post subject: |
A lot of those chinese bikes also have a PAV valve on them that bleeds air into the exhaust on the compression stroke in an attempt to lessen exhaust emissions.
Bleeding air into the exhaust is a recipe for backfiring if the timing of it isn't exactly right ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 16 years, 61 days ago. Instead of replying here, would creating a new thread be more useful? |
