 fintan L Plate Warrior
 evoboy World Chat Champion
 Posted: 22:25 - 13 Jun 2010 Post subject: |
May well be between the carbs and engine, in the inlet rubbers.
With the airbox off, if you open the throttle full so you can see past the butterflies, you should see a black hole, if theres a silver plate in there with a smaller hole in, thatll be your restriction.
Just a matter of undoing the clamps on the inlet rubbers that hold the carbs on, then peel back the carbs and pop the washers out.
EDIT: Fail for not reading the title and noteing fuel injection!!!
Might well be worth looking down the throttle bodies to see if there is any form of restriction there. But itll most likely be in the form of a different 'restricted' ECU or otherwise. ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
 Noxious89123 World Chat Champion
 Posted: 00:05 - 14 Jun 2010 Post subject: |
If there are washers, they'll be in the bottom of the inlet rubbers, closest to the cylinder head.
Some of the bikes are restricted at the ECU. There was a guy on here called p0peye I think, and he had to change his ECU. Don't think his was a UK bike using an FI International kit though. ____________________
'06 Honda CBR125RW-6 ~ '00 Honda CBR600F-Y ~ '07 Honda CBR600RR-7 ~ Bikeless
'53 Ford Ka 1.3 ~ '03 Vauxhall Astra SRi 1.8 ~ '52 Vauxhall Astra SRi 2.2 ~ '53 Vauxhall Astra GSi |
