Fork Dissasembly - Do I have everything. Also - Fork Paint
herulach
PostPosted: 21:44 - 25 Jun 2010    Post subject: Fork Dissasembly - Do I have everything. Also - Fork Paint Reply with quote
Going to do the fork seals on the YBR next weekend, want to check I have everything I need (the haynes manual is a bit vague)
Fork Oil
New Seals (oil and dust)
one of these seal pullers.
I'm also planning on repainting the lowers, does anyone have any recommendations for paint? Are cheap halfords rattlecans good enough?
YBR 125>FZS600
Teflon-Mike
tl;dr
PostPosted: 23:27 - 25 Jun 2010    Post subject: Re: Fork Dissasembly - Do I have everything. Reply with quote
Fork Oil
Make sure you have all the correct sized sockets & spanners, and often long allen key or allen socket for the damper rod retaining screw, BEFORE you begin.
Never resorted to a seal claw, personally, always used good old fasioned tyre levers & pry-bars.
Fork seals TEND to be a tad tight, and TBH I suspect you may struggle to effect enough force in a straight 'tug-of-war' with it and the seal, but your call..... maybe get yourself a tyre iron from busters or the like.....
sort of like this.....
https://i956.photobucket.com/albums/ae49/bikerbird/new/IMAG0876.jpg
(pics clicky & links to Donnas Pup Project on Show & tell.... page where she's dong her forks, pretty much a step by step how-to, for reference!)
Worth a fiver 'just in case' I reckon.
ANd a DECENT graduated measuring cylinder to measure out your fork oil. DO NOT rely on guestimating by the scale on the side of the bottle!
& more important than the specific quantity is getting the SAME quantity in each leg.
ther than that, see the Show & Tell thread, probably more informative than my waffling on.
Depends... how bad are they how good do you want'em?
Its cheap knacker laquer.... works OK if you put it on well, BUT works MUCH better with decent primer beneath it and laquer over the top.... and THAT particular nasy often reacts with all but Halrauds own brand primer & gel!
Problem with forks is that they live a hard life. Take all the chips and knocks and abrasion fro crud on the road, AND get attached by brake dust, fork oil and anything else.
Normally get badly erroded on the leading edge. Stick a thin skim of knacker laquer over the alloy, and within a few weeks they can often look worse than they did before where the colour chips off and leaves the scabby alloy contrasted beneath.
Some thence say 'dont bother'..... I say Laquer and lots off! better to wear of gel, than paint!
Worth doing properly though if you have the time & patience.... again as illustrated in Donnas Blog. Those legs had four coats primer, three gloss and then three laquer... should hold up pretty well......
But the key, is getting a good key, and that means CLEAN like they have never been clean before, before you paint..... hit em hard with the rotary wire, then clean off with thinners, before primering.... and give plenty of time between coats for the paint to fully cure.
el_oso
PostPosted: 00:57 - 26 Jun 2010    Post subject: Reply with quote
i completely forgot about the long allen key needed to take the damper rod out first time i done motorcycle fork seals. you can fashion your own using a bolt head the same size as the damper rod. then take two nuts screw them onto the bolt and then use a normal socket with a longer extension bar. hope this is clear.
Duke 390
Car: Jeep Wrangler 4.0L
herulach
PostPosted: 09:14 - 26 Jun 2010    Post subject: Reply with quote
Haynes reckons its a T70 bit on an extension, so got one of those on order.
The lowers are fucked, sod all paint on the leading corners, and allsorts of circular scratches round the legs, I reckon someones had a particularly poor fitting L plate clamped round it at some stage. For the sake of £5 and a bit of effort I might see how it comes out with a tin of satin silver. Can't look any worse than it already bloody does!
YBR 125>FZS600
herulach
PostPosted: 12:39 - 26 Jun 2010    Post subject: Reply with quote
Just been for a ride out to halfords, what do you all reckon to Alloy Wheel Paint? Similar substrate in similar conditions.
If I use acid etch primer like this do I still need to put ordinary primer over the top?
Sorry for the dumb ass questions, want to get it right first time
YBR 125>FZS600
neil.
PostPosted: 13:23 - 26 Jun 2010    Post subject: Reply with quote
I believe you need a 16mm allen bit/socket to remove the plug at the top of the stanchion. Also, whilst the forks are off I would highly recommend you fit gaiters to them so that you will never have to worry about pitting caused by stone chips damaging the stanchions and seals. Ones that fit a CG will fit the YBR. I have these: https://cgi.ebay.co.uk/Honda-CG125-Motorcycle-Fork-Gaitors-CG-125-Gaiters-/280514586612?cmd=ViewItem&pt=UK_Motorcycle_Parts&hash=item414ff8e7f4#ht_500wt_928 . In theory you should never have to change the seals again if you have gaiters fitted and if they're tied on, MOT testers can't look under them to check for oil leaks (not that I condone unsafe forks of course!).
Watch out when removing the fastners that hold the mudguard to the forks as I had one snap as it was so badly corroded, leaving half of it in the fork leg, so I'm now using 3 out of 4 fixings on the mudguard until I can be bothered to sort it out.
You also need to fashion some sort of dipstick to measure the oil level in the forks when you've filled them up. One of those wooden sticks you use for supporting plants works well. Measure the correct level along the stick and mark 5 mm after that with a wrap of electrical tape, then you know when you see 5mm of oil on the dipstick the level is right. I say 5mm to avoid the dipstick displacing too much oil and giving you a false reading. Thumbs Up
molex
PostPosted: 13:26 - 26 Jun 2010    Post subject: Reply with quote
Try the easy way
https://www.motorcyclecruiser.com/tech/replace_fork_seals/index.html
herulach
PostPosted: 16:14 - 26 Jun 2010    Post subject: Reply with quote
Have to say I love the ghetto way, sounds like a recipe for mess though! Looks like painting them might be better waiting for a few months till we move and have a garage, the seals need doing now though as one is pissing oil.
Neil, thanks for the gaiters suggestion, but they look so shit I don't know if I could bring myself to do it! Have you any photos of your's with them on?
YBR 125>FZS600
Rob W
PostPosted: 17:39 - 26 Jun 2010    Post subject: Reply with quote
Surely they're RWU forks?
Slide-hammer should be the easiest and best technique for getting the seal out. Prise out the dust seal and the seal retaining clip and then give the fork tube a few good yanks, and the bottom bush should tap out the top one and the seal.
Ignore me if I'm talking bollocks, and your bike cant be done like that, but that's how I've always gotten my seals out on RWU forks.
TS50 > Senda 125 > ZXR400 > CB-1 > GSX-R1000 > Bandit 600 > ZXR750 H1 > GSX-R750 SRAD > '98 RR-W Fireblade > T595 Daytona > Hornet 900 > '04 Fireblade > GSX-S1000F (x2) > '23 XSR900
Robby
Dirty Old Man
PostPosted: 18:05 - 26 Jun 2010    Post subject: Reply with quote
If you want a plain/silver finish on your forks then just take them back to bare metal with nitromors and give them a rub over with some wire wool to lift off any corrosion. If the original surface is particularly smooth you could polish them, but I like the plain alloy look.
neil.
PostPosted: 18:20 - 26 Jun 2010    Post subject: Reply with quote
I actually think the gaiters look pretty good, here's a pic (also pimping out my new braided brake hose that I fitted this morning om nom nom!):
https://www.bikechatforums.com/files/image001.jpg
Teflon-Mike
tl;dr
PostPosted: 19:03 - 26 Jun 2010    Post subject: Reply with quote
I'd endorse the addition of Fork Gaiters also.
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/imag1100.jpg
Here fitted to the old CB125TD I'm renovating at the moment, and not quite built up, but with black forks to give you an idea of what they look like, on them.
Reason for fit here, is as much to hide the state of the forks as stop it getting in that state. Fork Rechroming is about £150 a pair, regardless of bike. Cheaper to get new stansions most times, IF you can get them.... for this bike you cant.... so has to have gaiters and frequent precautionary seal replacements!
DONT get them off e-bay though. Busters, mail order, they are £6.99 a pair I think. HALF the price they are advetrised for on e-bay!
Great investment against having to get new stansions or find some-one to rechrome old ones at some point.
forks on my 750 aren't pitted, but thats got'em for just that reason.
You might as well paint the forks while you have them stripped for the seals. You need'em clean before you re-assemble, need'em clean to paint, saves double doing.
etch, prime, prime, paint, paint, paint, laquer, laquer.
Reassemble with your new seals and gaiters, you shouldn't have to touch them again..... unless you keep the bike a life time.... in which case you may, but NOT for a very long time!
Teflon-Mike
tl;dr
PostPosted: 20:52 - 26 Jun 2010    Post subject: Reply with quote
Vincent wrote:
Hard to believe nowadays when so many people that ride bikes do so for the pose potential but "Looks aren't everything" Wink
Hmmm its all down to asthetics I suppose....
Seemingly no quarlms about using cheap and nasty, 'one shot' knacker laquer to make cruddy looking fork-sliders look like cheap & badly painted cruddy fork sliders....... all for the sake of a little time and hardly ANY more money to do the job neatly, while the forks are apart....
But 'sensible' rubber gaiters, are deemed to look 'shitty'?!?
Looks are in the eye of the beer-holder I KNOW..... but jeez, aint common sense a rare commodity these days! Wink
neil.
PostPosted: 21:57 - 26 Jun 2010    Post subject: Reply with quote
Mike, you know you can repair pitted stanchions with epoxy filling? Looks crap but if it's covered with gaiters, it doesn't matter. Would save having to redo seals all the time because they're getting ripped to shreds by roughnessness.
herulach
PostPosted: 00:03 - 27 Jun 2010    Post subject: Reply with quote
I had a fucking huge reply typed out then before shitty phone net connection died.
Anyway, its a ybr I'm clearly not overly fussed about looks, although imo they are. much nicer with black lowers, which is an option as I'm planning on doing the exhaust at some stage as well.
Reckon I might leave the whole lot till I can throw a few days at doing them properly while I don't need the bike. That's assuming I won't do any serious damage riding with naff all oil in? (you can hear air getting sucked through the damper)
YBR 125>FZS600
neil.
PostPosted: 07:18 - 27 Jun 2010    Post subject: Reply with quote
Seriously, please fit gaiters. Save money, avoid extra work. Everyone I've spoken to about mine say they really suit the bike and one person even said that they look like they could even be an original factory fitted part!
Robby
Dirty Old Man
PostPosted: 12:05 - 27 Jun 2010    Post subject: Reply with quote
You will cause damage riding with no oil in at all. The oil doesn't just provide damping, it also lubricates.
For a bodge to buy you a few days, remove the fork top caps and pour 100ml of oil into each one, measured with a jug or similar. It doesn't even need to be fork oil, engine oil or ATF will do as a temporary measure, I have done a few thousand miles using 10W40 as fork oil before now, it worked.
Have a look for stinkwheel's write-up on using plasti-cote black enamel to paint engine cases on his girlfriend's CB500. He got a good finish, it didn't take too long, and was cheap. The only thing I will mention here is that enamel paint does take a fair while to go off and fully harden. When you use it as engine paint the first few heat cycles speed up this process, forks do not generate a great deal of heat. You could probably try baking them in an oven at 100 degrees for a while, but the owner of the oven may disagree.
You can still replace the seals now. It is easier to paint them with them all stripped, but as long as you mask up the chromed stanchion you can paint them complete. However you do it, do not paint in the area that the seal seat in. The seal is a tight fit, paint makes this tight fit even tighter. A thin layer of paint stopped me from fitting a set of steering head bearings properly, I had to take them out and redo the job.
I still prefer plain alloy, particularly if the engine is silver. Bare metal doesn't chip and wear off like paint does, nor does it need careful cleaning.
Teflon-Mike
tl;dr
PostPosted: 13:54 - 27 Jun 2010    Post subject: Reply with quote
Yup, there's variouse ways smoothing the stanscions, where they have pitted. reletive success depends on how badly the pitting is and how well the filler is applied.
I have used Metal-Set epoxy before and Phenolic (GRP) resin.
The phenolic is the better, its more glass-like and less spongy than nylon based epoxy.
TROUBLE is getting a good finish, and NOT causing more 'discontinuity' than you had to start with when you try nibbing it back.
Unless the pits are REALLY deep, I've found that its better to simply nib back the rust with fine diesel wet wet & dry around the effected area, then polish with autosol to get the chrome back around the pits, and smooth the pits as best you can.
Then turn the stancions round so the pits are at the back or inside of the fork, so less noticeable, and the main 'rub' on a different portion, of the tube.
End of the day, the chrome is on a fork tube to lower friction and reduce the 'stiction' effect.
The structural integrity and performance isn't effected by the pits, only the life of the seal.
AND the pits DO actually have a small self compensating effect, too, in that the rougher metal in them traps oil, when the fork slides over them.
THAT provides better protection against further rust than glue, AND offers a bit of lubrication to give the seal an easier time and reduce friction.
If the pitting is higher up the fork, where they dont get wiped very often, an occassional smear of light oil or vasaline keeps them protected and lubed.
AND under gaiters, its all hidden, and protected, and the MOT man, cant lift'em to look and grumble.....
Though last two that looked at my bike, looked and grinned, and asked poignant questions like "did y' put vaselene over pits before y' fitte' them?!"
Becouse they know ALL the tricks and whats a botch and whats a legitimate fix!
But its NOT a 'fix and forget' job. end of the day, the seals do wear ANY-WAY, and service schedule DOES tell you to change fork-oil every so often, though few do.
Fork seals AINT expensive, less than a tenner a pair on most bikes, and if you have done it once, its easy enough to do again.
So for the sake of a few quid and a little time an effort, no great shakes to change the fork-seals once a year along with the fork oil, to keep the damping performance tip-top, and be sure the seals wont fail when you dont have the time or money to sort.
Much like brake pads, and changing the fluid at the same time....
How often do MOST people think to flush through the old fluid? Or even top it up come to that?
herulach
PostPosted: 17:33 - 27 Jun 2010    Post subject: Reply with quote
Doesn't bare ally need lacquering anyway? Otherwise it goes all grotty.
Anywho, plan looks like do the seals next weekend, the rest afterward when I've the time (and cash) to do it properly.
Uppers aren't really pitted, just the chrome's peeled, so might just wet&dry it and see how it goes. I'm a bit cackhanded with things like glue, and would no doubt end up making it worse!
YBR 125>FZS600
The last post was made 15 years, 290 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 144.86 Kb
