| Author |
| Ingah |
 Ingah World Chat Champion
| Back to top |
| That_Hornet |
 That_Hornet World Chat Champion
 Posted: 17:43 - 01 Jul 2010 Post subject: |
Look through some skips. I have a small selection from taken out the skip at work. Includes a few steel rods about 1ft, bits of copper pipe (heating) about foot long each. Solid copper drift 1ft by 1". Some was off some scrap metal left for the pikeys in the tipper to come along.
It all gets used in some form.
Just keep an eye out for some.
| Back to top |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 17:48 - 01 Jul 2010 Post subject: |
Machine Mart, use web site. Plenty of stores around, if you want to view before you buy, use the store locator.
Sealey tools online. or general motorfactors. Most do Draper tools, and they have a pretty good set of drifts punches & chissels, think theres 5 or 6 in the set, for about a tenner.
well worthy investment. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Back to top |
 ..... Quote Me Happy
| Back to top |
| Pete. |
 Pete. Super Spammer
 Posted: 18:40 - 01 Jul 2010 Post subject: |
A drift is nothing more than a rod or bar for using as an extension for transferring impact energy from the hammer to the object you're wanting to hit. Old socket-set extension rods make quite good drifts if you cut the square drive off the end - but beware as once you've used it as a drift it's ruined as an extension rod.
For wheel-bearings you have to have a quite hard drift as the bearing race is very hard and usually you only have a tiny edge to get purchase on. You will lose the edge of the drift if it's too soft and have to keep cutting it back. ____________________ a.k.a 'Geri'
| Back to top |
| beast rider |
 beast rider Could Be A Chat Bot
| Back to top |
| Pete. |
 Pete. Super Spammer
| Back to top |
| iooi |
 iooi Super Spammer
 Posted: 20:28 - 01 Jul 2010 Post subject: |
Got a local garage.
Take wheel off and ask them to tap em out. Even a car one should be able to do that for you. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Back to top |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 20:33 - 01 Jul 2010 Post subject: |
| Joe wrote: | I'd get a set of brass drifts so they're generally softer than what you're hitting. For doing wheel bearings I use a length of steel rod about a foot long and a cm in diameter. It has a good sharpish lip on it and the extra length helps when you pass it through the hub to knock the bearings out the other side. |
good thought and just reminded me.... doing the effof awkward wheel-bearings on Donna's Pup the other day, rear has a curiousely wide hub, and my drift wan't long enough, well the ones narrow enough to get a decent angle.
A length of M8 or M10 'unithread' rod, about 3 or 4 quid at a decent hardware store or builderss merchant, or a couple of quid more at your average DIT place, is a great thing to have knocking about.
Get nuts and big washers for it as well, and can be pressed into service as a long drift, as I used it, on that occassion.
Does bugger the threads on the end, but you just grind or hack-saw them off when done. Can also grind ends to shape if you need to get into a tight spot or in a smaller hole etc.
With a good threaded portion, nuts and washers you can also use it to wind bushes into thier housings.
Can but cut up into length to make fastners (replace exhaust manifold studs generally!).
Basically the stuff is a yard of threaded metal! Use the thread, dont use the thread, use it however suits, stuff has MULTIPLICITY of injeniouse applications, if you want to get really creative, WELL worth having some knocking about the place!
| Pete. wrote: | A drift is nothing more than a rod or bar for using as an extension for transferring impact energy from the hammer to the object you're wanting to hit. Old socket-set extension rods make quite good drifts if you cut the square drive off the end - but beware as once you've used it as a drift it's ruined as an extension rod. |
I'm not the only one to do that then!
actually, the Ex used to keep buying cheap socket sets for me for the kids to give me as Birthday & Christmas presents.... 'Oh, he's always buying tools, THESE look 'good', seventy five sockets for £3.99, that'll keep him happy for a while!' Whenever she went into Wilco to buy more blue paint!
You can imagine how 'useful' they were. I have a nice collection of cracked 1/2" drive sockets, extension bars, etc... I find used for them. Have a nice 16mm 'deep' socket constructed from a spark-plug T-bar spanner and a 3/4" double hex that cracked ona Land-rover Diesel cylinder head bolt, welded together.....
BUT... Range-Rover, V8 starter motors, are attached with 8mm cap head bolts. Only theres no room to get a socket in them AND turn it! well with anything like a 'normal' set of tools!
Imagine, that once you have a socket in the cap-head, ther nearest place you can find to get anything like a 1/4 turn on a wratchet is under the front bumper.... while the cap-head you are tryng to undo, is about under the accelerator pedal.
Needs an extension about four and a half feet long!....
I curiousely had enough socket extensions to do this.... now try holding them all together while you turn!
Ent the electric metal mender a wonderful invention! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Back to top |
| yen_powell |
 yen_powell World Chat Champion
| Back to top |
| Ingah |
| Back to top |
| BanditsHigh |
 BanditsHigh Worse than a woman
| Back to top |
| That_Hornet |
 Posted: 06:29 - 11 Jul 2010 Post subject: |
| Back to top |
| Ingah |
| Back to top |
| stonesie |
 stonesie World Chat Champion
| Back to top |
| Villers |
 Villers World Chat Champion
| Back to top |
| BanditsHigh |
| Back to top |
| Ingah |
| Back to top |
The last post was made 15 years, 200 days ago. Instead of replying here, would creating a new thread be more useful? |
