Author |
Shaane |
Shaane World Chat Champion
Posted: 00:55 - 23 Dec 2010 Post subject: Battery Exploded |
As the title says guys, Bike hasn't be fired up for 2 weeks so when i got home yesterday i tried to fire her up and after a while ran the battery dead. Put it on charge overnight and when i came to it this morning it was still charing but i attempted to fire her up again. She ran for about 0.5 seconds and then when i pressed the electric start again the battery blew a hole through both sides leaving abit of a mess. When i removed the battery i saw that all the destilled water inside the battery had frozen and wasn't sure if this was the cause of the problem? Any help/Advice would be appreciated.
Bike is a 1999 ZX6R ____________________ EMRA Roadstock #92 - Paperwork Permitted.
Previous: 1992 DT125R
Current: ~ 2005 ZX6R C1H |
Back to top |
N cee thirty |
N cee thirty Banned
Back to top |
stinkwheel |
Posted: 01:08 - 23 Dec 2010 Post subject: |
Advice:
It's not distilled water, it's strong sulphuric acid. Wash it off everything it got on with lots of fresh water right now if not sooner. It will dissolve your bike, clothes, skin, eyes and garage floor. Especially alloy bits. Wear rubber gloves and goggles.
Frozen battery could potentially have cracked the casing already? Could also have blocked the breather hose on the battery causing any gas top pressurise it.
I'm serious about washing off any acid spills. Do it right now using LOTS of water to dilute the stuff. Worry about ice later. Be careful where you put the battery (in a plastic bucket?) so the stuff doesn't get on anyone/thing else.
EDIT: Having posted that. Before you try it with a new battery, check all the cabling running from the battery to the starter solenoid and from there to the starter motor. As rob yarrr correctly states, one thing that could cause it is a dead short of the battery. Realistically, this could only be caused by the battery positive touching the frame or by one of the big thick leads to the solenoid or starter motor having shorted out to the frame. All the other wiring that comes after the solenoid is protected by a 30A fuse which should have blown well before battery-exploding currents are experienced. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
Shaane |
Posted: 01:09 - 23 Dec 2010 Post subject: |
Cheers mate, I'm pretty sure they didn't short. Connected both terminals like i should have then as i walked awa 3-4 seconds later it popped. Clips might of slipped or something i suppose?
Stinkwheel - Okay mate, managed to clean most of the mess at the time but couldn't get into a really small gap so pushed a cloth in as much as i could. Battery has been put into a plastic container and sealed off so that my Cat/Dog doesn't get to curious and start sniffing. ____________________ EMRA Roadstock #92 - Paperwork Permitted.
Back to top |
CaNsA |
CaNsA Super Spammer
Back to top |
neil. |
neil. World Chat Champion
Posted: 07:38 - 23 Dec 2010 Post subject: |
Hmmm this is scary because I noticed that the distilled water I have in the garage for topping up the battery had frozen. Didn't even think to look at the battery itself.
I would assume the gel acid batteries don't suffer the same fate? |
Back to top |
doggone |
doggone World Chat Champion
Back to top |
alains |
alains World Chat Champion
Posted: 17:26 - 23 Dec 2010 Post subject: |
depense on the degree of charge range between minus 6 until minus 15 (celcius) but if you try charging a frozen battery it will explode ____________________ the worst day fishing is better than the best day working |
Back to top |
ms51ves3 |
ms51ves3 Super Spammer
Back to top |
baldy |
baldy World Chat Champion
Back to top |
The last post was made 13 years, 126 days ago. Instead of replying here, would creating a new thread be more useful? |
