| Ingah |
 Ingah World Chat Champion
 Posted: 07:24 - 19 Jul 2010 Post subject: Stubborn CG125 Screw and Bolt |
I went to sort the fork seals for my CG125 and am nearly ashamed to say i managed to get stuck on step 1
The speedometer screw (on the front wheel), won't come out and the screwdrivers keep slipping out and are beginning to damage it so i stopped (Halfords Professional so i know it's not my tool's fault). I've also tried an impact driver (won't budge it at all despite reasonably hard whacks - i daren't try too much harder because i already mashed my nail open good and proper just a few days ago after missing a wheel bearing with a hammer - too painful a mistake to repeat) and of course, copious amounts of WD40. I've also tried hitting it directly with a hammer hoping to free the thread, and trying to turn it the wrong way to break the seal (neither worked in the slightest).
That's me stuck. Any ideas of what to do next? (bearing in mind this is probably the first time i've had to consider an alternative to the normally effective WD40 + impact driver)
I moved on to the bolt securing the wheel axle, but that won't budge either (despite pushing down really hard on the spanner, and again, considerable amounts of WD40). Am i best to get an extension bar for the extra leverage, or is another method better/safer? (can i even fit an extension bar over a combination spanner - after all it's thicker at the ends?)
I've attached a diagram - it's not my CG but it'll do for demonstrative purposes (1. is the speedo screw, and 2. is the axle bolt thing). ____________________ -- Ingah |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
 Posted: 08:41 - 19 Jul 2010 Post subject: |
WD40 is a water displacing (WD) agent; it's not a lubricant and not a penetrating oil. Something like plusgas will work much better in most instances, but still might not help at all.
How much grab can you get on the screw? I'd get the wheel axle out first, might be able to get the speedo drive out without touching the screw or might be easier with the fork on a bench.
For the axle - use a 6 point socket and breaker bar.
A large piece of steel tubing splipped over the spanner would work but it might be a nice time to invest in a decent socket set and breaker bar . |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 08:51 - 19 Jul 2010 Post subject: |
If it's only the forks you want to get at, unscrew the speedo cable from the clocks and tape a bag over the end of it. Doesn't cure the siezed screw problem, but lets you get on with the forks. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 09:06 - 19 Jul 2010 Post subject: |
why does the fromt wheel even need to come off to replace the fork seals? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| muffy |
 muffy Borekit Bruiser
| DrDonnyBrago |
| muffy |
| crackpotterpi... |
 crackpotterpi... Renault 5 Driver
The last post was made 15 years, 264 days ago. Instead of replying here, would creating a new thread be more useful? |
