Datatool system 3 issue - can't turn off - SORTED (I think)
Imonster
PostPosted: 08:30 - 20 Jul 2010    Post subject: Datatool system 3 issue - can't turn off - SORTED (I think) Reply with quote
Apologies in advance for any rubbish spelling or lack of clarity - trying to do this on my phone on the train.
Went to turn off the alarm this morning, but usual button on key fob didn't produce the usual beep or single flash of indicators. Tried using the other key fob with same result.
Red led at back of the bike is still flashing in the usual way it does when the alarm is armed.
Bike is parked in it's usual place so don't think it's radio masts interfering, and bike was fine on sunday, and has been for the last year.
Any ideas please oh knowledgable one's?
Those who make peaceful revolution impossible will make violent revolution inevitable.
dibbster
PostPosted: 08:36 - 20 Jul 2010    Post subject: Reply with quote
Flat battery on key fob?
Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's Thumbs Up
www.bikepics.com/members/dibbster
Imonster
PostPosted: 08:44 - 20 Jul 2010    Post subject: Reply with quote
Was my first thought, but tried the spare with same result. That said i've never used it, and it's been sat in a drawer for the last year so could be flat.
Both fob's light up though when i press the button's, just won't turn alarm off Sad
Steve H
PostPosted: 09:04 - 20 Jul 2010    Post subject: Reply with quote
As far as I recall the '3' has a light on the key fob. When you pressed the button did the light (on the fob) flash at all? I would assume that if the light ain't flashing then it's a fob battery issue, if not then purely an intermittent signal fault. Sods law says that it'll probably work first time when you try it later on today Thumbs Up
Mellow Yellow
Benson_JV
PostPosted: 11:08 - 20 Jul 2010    Post subject: Reply with quote
Perhaps the battery could be strong enough to light the fob up, but not to send the signal across to disarm the alarm? Neutral
andys675
PostPosted: 11:20 - 20 Jul 2010    Post subject: Reply with quote
try holding down both buttons, if the fob has been in your pocket away from the bike and the button has been pressed a few times the fob can go out of sync with the unit, hold down both buttons for a while and it will re-sync the signal with the unit on the bike, this happens because the frequency changes every few times you use it so it can't be scanned and over-ridden by someone with a scanner
Imonster
PostPosted: 13:22 - 20 Jul 2010    Post subject: Reply with quote
Will try all suggestions when i'm back from work - thanks guys, appreciated.
Imonster
PostPosted: 18:53 - 20 Jul 2010    Post subject: Reply with quote
And that was the correct answer as it turned out - weird Confused
Will bear andys350 advice in mind if it happens again though - never knew that Thumbs Up
Cheers gents - karma all round Mr. Green
The last post was made 16 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.49 - MySQL Queries: 17 - Page Size: 60.59 Kb
