| binge |
 binge Emo Kiddy
| r0b |
 r0b Renault 5 Driver
| G |
 G The Voice of Reason
| binge |
 binge Emo Kiddy
| binge |
 binge Emo Kiddy
 Posted: 21:26 - 18 Jul 2010 Post subject: |
Tried making some today.
Managed to fuck it up good and proper.
I might have to buy myself some really thin grinder blades tomorrow, the ones I've got are taking too long to cut through this steel.
Ben |
| G |
| Pete. |
 Pete. Super Spammer
 Posted: 23:12 - 18 Jul 2010 Post subject: |
Easy to make. Do yourself a favour and make them from 6mm.
Another idea is one I use for 'busa lowering links. Drill four holes in each then you have 3 levels of adjustment - 2 sets of links gives you a large range of adjustment. (The pictured ones are for a hayabusa). ____________________ a.k.a 'Geri'
| binge |
 binge Emo Kiddy
 Posted: 22:31 - 19 Jul 2010 Post subject: |
Really cool suggestion Pete, and I did consider it.
But where I've had to lower the linkage to fit the Gixxer K2 shock, and also flip the linkage upside down too.
Literally 6mm on the dog bones, changes the tail unit by about 50mm. It's ridiculous.
I'm dubious that 195mm is going to be wrong. If it's like 2 or 3mm out, it's going to make it noticeably "wrong" on the ride height.
It has to be smack bang on the mark.
Hence the reason I thought about adjustable ones, made from M12 rose joints and some drilled/threaded hex bar.
BUT, it wont fit.
Here's a comparison just so you have an idea how different the shocks are.
https://i902.photobucket.com/albums/ac227/pitbikeben/Photo1724.jpg |
| binge |
 binge Emo Kiddy
 Posted: 08:18 - 20 Jul 2010 Post subject: |
Well I guess it pays to ask the Ebay sellers before buying bits to make them.
I emailed 2 sellers on ebay yesterday. One looked like a mainstream seller who makes them for loads of bikes.
The other looked like a private seller who makes them from home.
Got two replies. One was basically saying his are all lazer cut, and he cant make custom lengths. However, his XJ1300 lowering kits are bang on 195mm center to center. He sent me the item number for it, £15. Sorted.
The other guy said he makes his own, and will forward me some pictures, all I need to do is add the measurements, send back, and he will make them up, and send them out. Again, at £15.
Yesterday at work, I was being impatient, Went into town and spent like £20 on a 12mm drill bit and a pack of 10, 1mm cutting discs. Teach me I guess!  |
| Pete. |
 Pete. Super Spammer
 Posted: 21:11 - 20 Jul 2010 Post subject: |
Well I cut you some flat bar today to make them
The difference in length of those two shocks is quite large. You might find you have changed the spring rates quite dramatically by altering the linkage geometry.. ____________________ a.k.a 'Geri'
The last post was made 16 years, 21 days ago. Instead of replying here, would creating a new thread be more useful? |
