Mudguard Laws
Throttle
PostPosted: 11:06 - 21 Jul 2010    Post subject: Mudguard Laws Reply with quote
Can someone inform me of the law regarding mudguards??
As I want to bob the Monkey, I am wondering if by law I am required to have a front mudguard?
PostPosted: 11:08 - 21 Jul 2010    Post subject: Re: Mudguard Laws Reply with quote
That's gotta be a euphemism Smile
Paxovasa
PostPosted: 11:09 - 21 Jul 2010    Post subject: Reply with quote
I believe that a front mudguard has to be fitted. Thumbs Up
Edit: If you have one fitted it has to be secure, but it is not a legal requirement . Although it is a requirement for road use, just like a speedo. As you don't need one fitted for an mot, but do need one fitted for road use.
PostPosted: 11:16 - 21 Jul 2010    Post subject: Reply with quote
From a chopper forum :-
You’ve actually more chance of failing an MOT ‘With’ a front mudguard than without one, because it isn’t actually part of the MOT test.
To quote VOSA:-
MOT guidelines on Motorcycle Front Mudguards.
“The mudguard is not a tested item, as part of the MOT test. Its condition size and position would have no bearing on the test, unless a mudguard, if fitted, adversely affected the rotation of the front wheel”
This goes back to what I’ve said in the first issue, so just to recap, the MOT test is only a periodic safety check to identify worn or defective parts, it doesn’t check whether the bike is actually legal to ride on the road.
However, technically you 'could' still fail an MOT without one, although the guard itself isn't part of the inspection, the roadtest is still an optional part of the MOT if the inspector chooses to use it, if the vehicle isn't road legal then he or she won't be able to complete the inspection and it'll fail in that instance. It won't fail on the lack of a mudguard it'll fail as the inspection wasn't completed.
Mudguards are required to pass the MSVA.
Ok, so what does the rule book say, and are they required?…..yep I’m afraid so.
To quote The DfT:-
“Motorcycle mudguard requirements are contained in Regulation 63 of “The Road Vehicles (Construction and Use) Regulations 1986 (SI 1986/1078)” as amended. It states that, motorcycles are required to have mudguards fitted which catch, so far as practicable, mud or water thrown up by the rotation of its wheels” So we’ve established that you’ll need a front mudguard, but how much tyre does it need to cover? Well here, we do have some ‘leeway’ because there isn’t any actual regulation that covers a mudguards size, other than being ‘practicable’ So I asked the local Constabulary how they enforce the C&U’s Regulation 63 on the road, to quote the Road Traffic Policing Unit:-
“They are legally required. With regards to size, I have looked everywhere that I can think of to find the answer but have failed, so there are obviously no guidelines available. My only comment would be that
they should not constitute any ‘dangerous parts’, e.g. sharp protruding edges, etc, that may cause injury to a pedestrian in a collision”
So there you go, a front guard is a legal requirement, but there are no dimensional requirements, if its checked for size it’ll be down to the discretion of who ever checks it and whether it could be considered ‘practicable’ or not. The full regulations are below.
Provides for the fitting of wings or
mudguards to vehicles to prevent mud or
water being thrown up by the wheels or
tracks.
63(1) This regulation applies to:
(a) invalid carriages;
(b) heavy motor cars, motor cars and
motor cycles, not being agricultural motor
vehicles or pedestrian controlled vehicles;
(c) agricultural motor vehicles driven at
more than 20 mph; and
(d) trailers, unless exempted by paragraph
(4).
63(2) Every vehicle to which this regulation
applies shall be equipped with wings or
other similar fittings to catch, so far as
rotation of its wheels or tracks, unless
provided for in paragraphs (3) and (5).
63(3) The requirements specified in
paragraph (2) apply, in the case of a trailer
with more than two wheels, only in respect
of the rearmost two wheels.
63(4) Those requirements do not apply in
respect of:
(a) a works truck;
(b) a living van;
(c) a water cart;
(d) an agricultural trailer drawn by a motor
vehicle which is not driven at a speed in
excess of 20 mph;
(e) an agricultural trailed appliance;
(f) an agricultural trailed appliance
conveyor;
(g) a broken down vehicle;
(h) a heavy motor car, motor car or trailer
in an unfinished condition which is
proceeding to a workshop for completion;
(i) a trailer used for or in connection with
the carriage of round timber and the rear
wheels of any heavy motor car or motor
car drawing a semi-trailer so used; or
(j) a trailer drawn by a motor vehicle the
maximum speed
63(5) Instead of complying with paragraph
2) a vehicle may comply with Community
Directive 78/549.
neil.
PostPosted: 12:28 - 21 Jul 2010    Post subject: Reply with quote
Hm interesting. My front mudguard only has 3 bolts out of 4 holding it onto the forks (2 on one side, 1 on the other) because one bolt sheared off last time I had to work on the forks. The front wheel spins fine, the mudguard seems secure and doesn't have any excessive play. Would the missing bolt be an MOT fail?
PostPosted: 12:31 - 21 Jul 2010    Post subject: Reply with quote
Possibly, if the examiner deemed the mudguard to be part of the structural integrity of the front end. They'd have to be bloody picky though Smile
neil.
PostPosted: 12:36 - 21 Jul 2010    Post subject: Reply with quote
Perhaps I'll superglue the head on then. Twisted Evil I tried to drill the bugger out at the time and all I did was make a hole, so there's no thread in there. I assume it'll have to be tapped out again. Meh.
Throttle
PostPosted: 13:46 - 22 Jul 2010    Post subject: Reply with quote
Cheers for that Shaggy.
Looks like I need to re-think the build a little.
tahrey
PostPosted: 04:19 - 25 Jul 2010    Post subject: Reply with quote
Sorry to threadjack shaggy, but what's the last few lines of that thing you posted (from "(j)" to the end) on about? I tried googling for relevant bits and got nowhere fast.
drzsta
PostPosted: 15:42 - 25 Jul 2010    Post subject: Reply with quote
i've rode for almost a year without one, cops dont know fuck all about it.
it would only be a problem with the MOT, where you just slip it back on before hand.
onlyh trouble i have is that when its raining, the front tyre showers you in shit off the road.
Dan79
PostPosted: 00:11 - 26 Jul 2010    Post subject: Reply with quote
I'd be more concerned about function, if it comprises the only brace between the forks, I would not ride without it, however if there is a separate brace (e.g. a bracket that is mounted on both forks, onto which the guard is fitted) I wouldn't worry about it. Taking care though that brake / speedo cables don't snag the wheel in the absence of the guard.
Previous bikes - 1984 Honda VF500 (FII) Interceptor and 1990 Yamaha RXS100
Current bikes - 1984 Honda VF500 (V30) Magna
The last post was made 16 years, 114 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 73.58 Kb
