Removing ER-5 crankcase
Darith_ranger
PostPosted: 11:57 - 23 Jul 2010    Post subject: Removing ER-5 crankcase Reply with quote
I have a slight crack in the front left panel of the engine which i presume is the crank case ( picture attached). Should i use tiger seal from the inside or would a specialist duraflex weld which i have a available. Also is it as simple draining the oil ( i need to change the oil filter anyways) and removing the the seven or eight screws around the edge because there two other screw mechanisms in the centre and above centre ? or is it more complicated?
The last post was made 15 years, 186 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.66 - MySQL Queries: 14 - Page Size: 27.25 Kb
