GPZ500s cam chain tensioner, or clutch...
dextersaurus
PostPosted: 20:21 - 09 Aug 2010    Post subject: GPZ500s cam chain tensioner, or clutch... Reply with quote
Since i've never done this kind of maintenance before, i'm wondering if there is anything i should be watching out for...
The bike has only done 33k miles in 16 years, so the camchain should hopefully be good for another wee while...
The main problem is that when it's running at really low revs (-2k revs) it taps quite loudly... And the tapping gets a lot quieter if the bike is leaned over to the right.
Now after doing some research, i've come to the conclusion that it's either the clutch or the cam chain tensioner.
I noted that once when i started the bike cold, i went to stick it into first gear, with the clutch held in, and it jerked forward and stalled... So the clutch didn't seem to be working. (this was before the oil change)... But starting it back up and grabbing the lever a few times, it worked fine afterwards.
I'm thinking if it's the cam chain being too loose (i've heard the tensioner sticks sometimes), i'll take off the tensioner and clean it up to the best of my ability, then slap it back in and see if that solves anything....
But if that doesn't help, i'm taking it that it's the clutch...
Any ideas?
If it IS the cam chain, what's the best way to clean up the tensioner?
Dunc
Acemastr
PostPosted: 20:34 - 09 Aug 2010    Post subject: Reply with quote
I noticed the exact same thing today, on tickover or coming down from very very low revs i can hear it tapping, bike shop said cam chain tensioner, although my clutch makes funky noises when it's not pulled in.
2016 Toyota Tacoma Limited
PostPosted: 21:01 - 09 Aug 2010    Post subject: Reply with quote
Cam chain itself on the GPZ500 is sometimes not the longest lived item. However the other thing that can slap around is the primary drive chain.
Dazbo666
PostPosted: 21:30 - 09 Aug 2010    Post subject: Reply with quote
Did some minor maintenance of the CCT on my old GPZ some time ago...
I seem to remember removing it, using Gunk/degreaser to clean it up, then using a Dremel to clean off some surface corrosion, then some Hammerite spray paint to prevent future corrosion.
From memory you just need to be careful about maintaining pressure on the spring when re-installing it - the spring inside the tensioner needs to remain compressed until after you've tightened the fitting bolts. Sorry I don't have the bike or the Haynes manual to be able to quote the exact fitting instructions.
Word of the day : DILLIGAF
Acemastr
PostPosted: 18:14 - 11 Aug 2010    Post subject: Reply with quote
anyone know how dangerous the tapping is? mines been doing it slightly for a couple months (not really noticed as i wear earplugs) changed oil on sat and noticed it far more lately. It's quite noisy at low revs/tick over
sorry to steal your thread dunk
Pickledswede
PostPosted: 19:08 - 11 Aug 2010    Post subject: Reply with quote
Those of you with Hondas... are you sure it's not just the clutch rattling? If you're idling it and it's rattling then you pull the clutch in and it stops then that's what it is. I believe this is quite normal on Hondas and nothing to worry about!
c-m
PostPosted: 21:22 - 14 Aug 2010    Post subject: Reply with quote
Remember that the GPZ (i fact most kawasaki) do sound like a bag of spanners rattling around.. its normal.
My GPZ used to sound like a diesel hackney carriage.
dextersaurus
PostPosted: 17:18 - 15 Aug 2010    Post subject: Reply with quote
Well, now that an incident while it was running involving bouncing it off the limiter happened, it now only runs on one cylinder...
Thought this might have something to do with it, unless it's just that buggered the carbs.
Again.
Dunc
robocog
PostPosted: 20:39 - 15 Aug 2010    Post subject: Reply with quote
Sad
AFAIK there is no "rev limiter" function from the CDI (based on what I have read)...apart from physical mechanical limits of components
I would be doing a compression check and whipping the cam cover off to have a nosey if its only running on one cyl since its been bouncing off a non exhistant limiter
cam chain is easily accessible when the cam cover is off (just done my clearences)
Only bit that caused any drama was the rubber O-rings for the water take offs on the head
Took me a few minutes of swearing at one of them and much lube till I got one of the swines in place without it pinching/twisting up, the other popped straight back in place without drama
I have my fingers crossed for you that valves have not been intimate with the piston on the non running side (and its nothing more serious than a bit of crap in the carb!...get a filter fitted if it hasn't already)
Regards
Rob
Needs a bigger garage...
The last post was made 16 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.71 - MySQL Queries: 14 - Page Size: 61.93 Kb
