carb problems with my 1998 kh 125 (i think)
ukash
PostPosted: 15:52 - 15 Aug 2010    Post subject: carb problems with my 1998 kh 125 (i think) Reply with quote
hi there im having some trouble with my 1998 kh 125 k10
it rufuses to idle lower than 2500 rpm, when i turn the tickover down slowly it drops 4000,3500,3000 etc but as soon as i hit 2500 it dies, and sounds starved of fuel
im usually quite good with 2 strokes but this has got me stumped
new fuel line/filter etc
fuel tap soaked and blown out with air, has a good flow
new plug BR8HS (not sure if it the correct one? i just bought the same as the one that was in)
gap set to .6 mm
flywheel/points/condensor/coil/ht lead/cap are good
carb has been soaked overnight in cleaner and everything blown out with air
it has a 90 main jet and cant read the pilot jet, what size is pilot?, and does the main sound right as standard?
head and base gaskets appear tight no leaks or crap coming out where it shouldent
doesnt smoke too much when running so dont think a seal has gone
the autolube has been disconnected and im running premix, where the oil goes into the crank case has been blanked off(it was over oiling and i prefer premix cus i know it always there)
its been rebored by the previous owner, not sure to which size though, which made me think it might be under jetted?
so i gave it a good ride for about 5 miles opening it up a little, quickly shut it off and whipped the plug out and its white/grey which means running lean, the biggest oversize would take it up to 134cc so im guessing i would need to increase both the pilot and main jet a little? i did take the needle up one which helped a little but still not fixed
anyone know what carb the kh uses i know its mikuni but what model?
any help/info would be great thanks
ukash
PostPosted: 17:51 - 15 Aug 2010    Post subject: Reply with quote
right i think im getting somewhere, ive sealed the cover and the rubber cap which the cables go through with gasket sealant,
after giving the carb another clean and setting the mixture screw to 1 and a half, it ticks over nicely at 1500rpm on the stand
but when i take it off the stand it dies after around 20-30secs, i found that if i lean the bike to the left it continues to run but when i straighten the bike up it dies so im thinking that the float is not set right does anyone know what height it should be set at?
ukash
PostPosted: 23:15 - 15 Aug 2010    Post subject: Reply with quote
anyone?
The last post was made 16 years, 25 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.51 - MySQL Queries: 14 - Page Size: 35.98 Kb
