zzr 1100 front brake issue
scally
PostPosted: 11:13 - 22 Aug 2010    Post subject: zzr 1100 front brake issue Reply with quote
I have a 1998 D model ZZR 1100 and the front brakes are really poor. Had it in a garage, new front disc and pads, changed to braided hose, bled properly but the lever still travels a great distance before they start to work. anyone any ideas please
Walloper
PostPosted: 13:32 - 22 Aug 2010    Post subject: Reply with quote
You must still have air in the system.
Ensure that there is no air in the highest point, master cylinder first.
Try removing the calliper and bleeding with the nipple above the master cylinder.
Easybleed pressurizing kit from Halfords £5 ish
scally
PostPosted: 16:12 - 22 Aug 2010    Post subject: Reply with quote
thanks for that although the mechanic was 100% happy there was no air left in it.
Digit
PostPosted: 16:28 - 22 Aug 2010    Post subject: Reply with quote
Regardless of what the mechanic says I'd bet that there is still air in the system. Quite a few calipers can only be bled successfully off the bike so that the bleed nipple is at the highest point, DAMHIK!
Roy.
Happy daze!
scally
PostPosted: 16:34 - 22 Aug 2010    Post subject: Reply with quote
thanks for your advice, will take a look at that...
Flip
PostPosted: 16:40 - 22 Aug 2010    Post subject: Reply with quote
Back bleed it. Get a syringe and a tube and pump the brake fluid in via the open bleed nipple (carefully) with the reservoir cap off.
The last post was made 16 years, 18 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.25 - MySQL Queries: 14 - Page Size: 44.83 Kb
