Supermoto conversion
maully
PostPosted: 16:03 - 03 Sep 2010    Post subject: Supermoto conversion Reply with quote
Basically as the tittle says. Ive currently got a 1991 CRM125, and have brought some NSR Wheels for it upon reading somewhere that they got straight on to the CRM. The current tires need changing so just wanted to double check that the wheels will go straight on before ordering the tires.
any help or info would be great cheers alex
hmmmnz
PostPosted: 20:33 - 03 Sep 2010    Post subject: Reply with quote
ahh the old someone said it would fit story Very Happy
you have a few variables,
firstly, the axle sizes, crm front- 15mm crm rear - 17mm nsr f-15mm r 17mm
so that sweet,
next variable is brake rotor, 240mm front on the crm dunno what the rear is and don't know what the nsr uses,
next variable is the brake off set,
next is the spacers,
next is the cush drive on the back
i doubt its just a straight swap, it might be as minor as changing the spacers,
but it could be that you have to modify the torque arm for the rear caliper, off set the front caliper and make new spacers,
worth a try, i managed to make bandit 6 wheels fit a gs500 with quite a bit of work
good luck
the humans are dead
I kick arse for the lord
The last post was made 15 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.99 - MySQL Queries: 14 - Page Size: 32.15 Kb
