Front sprocket nut lost....near death experience!
hopoffbaby
PostPosted: 10:50 - 09 Sep 2010    Post subject: Front sprocket nut lost....near death experience! Reply with quote
Hi all,
Its been a while since I last posted on here. But last night I was riding home from work at a fair pace and all of a sudden I lost all power to the rear.
Upon the AA inspection the guy tells me the sprocket retaining nut is gone as too is the washer. He then continues to tell me that he cannot believe that the chain didn't jam and throw me off!
The sprocket had jumped off the toothed bit of the drive shaft and was free spinning on the remain inch of the shaft, held in place by the now wrecked clutch selector mechanism.
Anyway, long story short, I'm alive but my bike is limp. The thread on the drive shaft luckily looks OK so I think it may just be a case of replacing the nut.
Does anyone know the Yamaha part numbers of the retaining nut and washer? Or where I could order one from?
Thanks and regards,
hopoffbaby
hopoffbaby
PostPosted: 11:02 - 09 Sep 2010    Post subject: Reply with quote
LOL, how stupid of me!
Its a 2002 Yamaha FZS 600
Regards.
PostPosted: 11:21 - 09 Sep 2010    Post subject: Reply with quote
Have had this happen on several occasions. Once on a Cagiva (where the output shaft is very short, hence no chance the sprocket will stay in place when the bolt comes out), and once each on the FZ750 and FZR600. With the FZR600 I have no idea how long I had been riding with the nut missing as there was no sign of it at all.
Suspect it it causes damage the most likely thing to happen is the thread trashed on the output shaft, followed by a broken front sprocket cover.
hopoffbaby
PostPosted: 11:56 - 09 Sep 2010    Post subject: Reply with quote
Thanks for the replies guys,
Yamaha say the nut and washer are ~£3.50 each; not too bad.
I'm going to check the shaft again when I get home from work as it was dark last night and I want to double check. I pray to god I don't have to have the engine taken out etc. I was planning on selling the bike so that would not be good for my pocket! Sad
Regards.
sickpup
Old Timer
PostPosted: 12:26 - 09 Sep 2010    Post subject: Reply with quote
Looking at worse case it's a lot worse than suggested.
Yamaha use a very fine pitch thread for the output shaft, people use a windy gun to do the nut up and strip the threads.
hopoffbaby
PostPosted: 17:29 - 09 Sep 2010    Post subject: Reply with quote
Hi guys,
I've had a look at the shaft and while it does look a little damaged I can still some thread on it. I need a second opinion though, I've attached a few photos for you gurus to look at. I hope its not bad news Confused
Regards,
hopoffbaby
mad4it028
PostPosted: 17:41 - 09 Sep 2010    Post subject: Reply with quote
ide try and get a dia on there and retap it before fitting if i could find the right size dia
PostPosted: 17:43 - 09 Sep 2010    Post subject: Reply with quote
Looks wrecked. Only chance is that the damage is instead the remains of the thread from the nut. Doesn't look like it to me but the undamaged last thread does appear to be the same height so it is possible.
Unfortunately to properly fix it means replacing that shaft which will be an engine out and complete strip job. The nasty bodge job is to weld a replacement sprocket in place.
cyberglass
PostPosted: 18:02 - 09 Sep 2010    Post subject: Reply with quote
looking at the hole in the shaft.
You could possibly see how deep the hole goes if its deep tap it 8mm should do it. Then use a die to rethread the shaft then put everything back on.
Just incase the shaft thread fails again put put a screw covered in thread lock into the tapped shaft hole with a big washer on it.
Temp fix but cheaper than replacing the shaft.
you would need to keep a good eye on it though.
DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005
hopoffbaby
PostPosted: 19:06 - 09 Sep 2010    Post subject: Reply with quote
mannn..... this is not sounding good Sad I'm prob going to take it to the garage, any idea how much I'm likely to get bent over and raped for?
PostPosted: 19:16 - 09 Sep 2010    Post subject: Reply with quote
If they can clean the thread up not a massive amount.
If they need to do the job properly then ~£100 for gaskets and the like, ~£100 for the output shaft and then probably a days labour to drop the engine, split the crankcases (which means the top end off on most Yamahas), replace the shaft, rebuild the engine and put it back in the frame.
lllN30lll
PostPosted: 19:22 - 09 Sep 2010    Post subject: Reply with quote
IMO it would be easier to get a new engine.
https://cgi.ebay.co.uk/Yamaha-FZS600-Fazer-Engine-/370330954975?pt=UK_Motorcycle_Parts&hash=item563971ecdf
https://cgi.ebay.co.uk/Yamaha-FZS600-FZS-600-Fazer-02-Engine-Assembly-/120610421786?pt=UK_Motorcycle_Parts&hash=item1c14f0fc1a
https://cgi.ebay.co.uk/Yamaha-FZS-600-Fazer-01-Engine-/160478234267?pt=UK_Motorcycle_Parts&hash=item255d3f869b
https://cgi.ebay.co.uk/YAMAHA-FZS-600-FAZER-1998-2002-ENGINE-MOTOR-PARTS-/160472842386?pt=UK_Motorcycle_Parts&hash=item255ced4092
https://cgi.ebay.co.uk/Yamaha-FZS600-FZS-600-Fazer-Engine-Assembly-/120616096088?pt=UK_Motorcycle_Parts&hash=item1c15479158
Turbo R1
CRF450R
DrDonnyBrago
PostPosted: 22:52 - 09 Sep 2010    Post subject: Reply with quote
Personally, I'd have a go at repairing it myself; given that if you fuck up you are in exactly the same position you started (i.e. probably easiest to get a new engine) so you have nothing to lose, part the engine out and stick it on ebay if you shaft it.
I am of the impression that an engine removal in that bike is rather simple.
Ed Case
PostPosted: 12:54 - 10 Sep 2010    Post subject: Reply with quote
Anything less than replacing that shaft is OUT, you've been very lucky indeed not to be a high-speed pedestrian once and I doubt you'd get away with it again. The cheapest way around it as suggested previously is probably to ring around the breakers to see if you can get, and how much, another lump would be. Sorry I know it's crap reading this but you've only got one life and it's worth more than money. If it was me and I was brassic I'd get a new front sprocket and get it welded on, if the bike's getting on a bit you've nowt to lose really have you ?
Ed Case
PostPosted: 13:01 - 10 Sep 2010    Post subject: Reply with quote
ps This welded-on sprocket business is not as unheard of as you might think, Laverdas have a habit when a 'sloppy' new one is fitted it can knock the splines of the output shaft all to Hell. There are several running about with this welded-up bodge and as long as you dont run your chain until it's totally, absolutely, positively phukt you could get 15000/20000 miles before your forced to do something about it.
PostPosted: 19:14 - 10 Sep 2010    Post subject: Reply with quote
The shaft is a little chewed but not at the root of the thread so most of the damage is in the nut - I bet it's stripped bare.
A new nut will go on there and tighten to spec I bet. Some blue loctite will stop it coming loose again. It'll cost you less than a tenner to find out, I wouldn't hesitate to ride it if the nut tightened.
The last post was made 16 years, 3 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.09 - MySQL Queries: 14 - Page Size: 97.94 Kb
