| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| Itchy |
 Itchy Super Spammer
 Posted: 10:16 - 09 Sep 2010 Post subject: |
You mean an exhaust stud?
Depends on just how hard they are stuck in tbh...
I drilled out two snapped ones, but this was after I had copper greased them and also used a tap and die set to clean the threads of the old ones. I removed the front wheel (easy) and crouched into the small space to drill them out. The key is to go very very slowly so that you can see the drill bit going round and round and some good quality bits also.
https://www.bikechatforums.com/viewtopic.php?t=148552&
If you destroy the bolt/threads helicoil it. I believe Gman had something similar on his CBR where peter drilled it out while still in the bike (the engine) ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| el_oso |
 el_oso World Chat Champion
| DrDonnyBrago |
| Itchy |
 Itchy Super Spammer
 Posted: 10:58 - 09 Sep 2010 Post subject: |
| DonnyBrago wrote: |
Yeah exhaust studs, they are well and truly stuck. These are the original ones that snapped off as I was removing them so the thoughtful addition of copper grease to make this easier has been overlooked by Mr Honda. If I drilled it then I imagine that the stud would remain in the threads until every last bit had been removed by a drill, meaning a retap  .
I hadn't considered that they may all snap again as I put new studs back in... woo  . I noticed you had the same issue as me with getting the old gaskets out, did you eventually hammer a screwdriver into the gasket itself or between the exhaust port and the gasket from the side? I've been trying to avoid damaging the head and as a result the gaskets are still stuck in there.
I have a mechanic I know nearby but he is proving rather difficult to pin down . |
I put the screw driver on the outer edge of the exhaust port, between the wall and the gasket itself and levered them out. I made a few dents in the edge of the port which were tiny ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| DrDonnyBrago |
| Casper |
 Casper World Chat Champion
| Digit |
 Digit Scooby Slapper
| Pete. |
 Pete. Super Spammer
 Posted: 18:58 - 10 Sep 2010 Post subject: |
Have you thought about taking it to an engineering company and asking them to drill the broken parts out in-situ? They might have a go at it with no guarantees but some people are very handy with a pistol-drill. I'd say the chances of success would be quite high if I attempted it myself. ____________________ a.k.a 'Geri'
| warped one |
 warped one Banned
The last post was made 16 years, 7 days ago. Instead of replying here, would creating a new thread be more useful? |
