Rubber tubing over rear shocks, aka gaiters?
neil.
PostPosted: 17:46 - 19 Sep 2010    Post subject: Rubber tubing over rear shocks, aka gaiters? Reply with quote
Taking inspiration from the massive 125 rebuild thread by snowtigress, what do you lot reckon to getting some old sections of inner tube (bicycle I guess) and stretching them over the rear shocks on the bike? I am guessing as well as protecting against general road rubbish and weather, there would be the added bonus of MOT testers not being able to check the condition of the shocks? Not that one would ever consider riding a bike with unsafe suspension... Whistle Sounds good for those of us who ride all year round and want our bikes to last as well as possible.
Thoughts, anyone?
The Artist
PostPosted: 17:49 - 19 Sep 2010    Post subject: Reply with quote
I had gaiters on my old gs125 forks. Took them off, regretted it later when I saw rust on forks.
neil.
PostPosted: 17:51 - 19 Sep 2010    Post subject: Reply with quote
Yeah I have gaiters on my front forks already, good stuff, but I'm thinking about the rear shocks...
That_Hornet
PostPosted: 18:01 - 19 Sep 2010    Post subject: Reply with quote
Shock sock?
Or shock tube, made an appearance on here not long back, google.
doggone
PostPosted: 18:40 - 19 Sep 2010    Post subject: Reply with quote
I think you will conceal all kinds of nastyness under it and it would be better without so you can clean it properly.
The front fork gaiters are mainly to protect from stone chips which are a bit less likely on you rear shock(s)
Robby
Dirty Old Man
PostPosted: 19:00 - 19 Sep 2010    Post subject: Reply with quote
The advantage of gaiters on forks is that they can cover the section of fork that is exposed, but isn't a working part, so can corrode. The working part of the stancion will rarely corrode in normal use because it is constantly being wiped past the seal and (briefly) being oiled.
On rear shocks the entire length of the damper rod is often full compressed into the shock body, so also shouldn't corrode. If the majority of the damper rod isn't getting into the shock body then your shocks are too hard for your weight or choice of roads.
If you are going to cover them up, then clean off all corrosion first and give them a good spray of ACF50 or similar long lasting corrosion inhibitor. Otherwise you're just locking in corrosion and moisture so it can continue in a nice, safe, sealed environment.
iooi
PostPosted: 19:17 - 19 Sep 2010    Post subject: Reply with quote
A couple of issues with doing this.
1, You will lose cooling effect. Which will affect the damping action.
2, Any crap that gets in will be trapped in there. Any rust that has started will get worse quicker.
3, MOT test on rear shock is usually to bounce the rear end and see if it acts as it should, number of bounces. Not often they take a close look at them. Unlike the front forks.
neil.
PostPosted: 21:08 - 19 Sep 2010    Post subject: Reply with quote
Cheers muchly for the input. Only corrosion I've noticed on the rear shocks is surface rust on the springs that appears in winter and it's easy to clean off. On front fork gaiters, I guess I've been doing things right then as I give the stanchions a good wipe of ACF50 when I clean the bike and lift up the gaiters. The chrome is good and there's no pitting under the gaiters. Also still got the original fork seals in after nearly 3 years and over 30'000 miles. Thumbs Up
Robby, I'm a fat git so the shocks get a big bouncy workout every day! After what's been said I won't bother covering them.
Teflon-Mike
tl;dr
PostPosted: 23:04 - 19 Sep 2010    Post subject: Reply with quote
Well, not a neutral opinion, twas I that got Snowie sticking that shock in a rubber tube. I just wanted to see if she could get something big and hard in a rubber sleeve, REALLY! Wink
Here's the artifact in question:-
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/imag1726.jpg
First off, its NOT a bicycle innter tube, its the 18x 4.00 section innter tube for a motorcycle, in fact the old one taken out of the wheels for the bike the Shock's fitted to, but same size as many others, like CG or YBR etc.
The shock is a snug fit in that size tube, it wouldn't go in the 3.00 section tube from the old front wheel, I doubt that you'd get a bicycle tube over a shock, they tend not to be that big, and if you did, they are thinner rubber, and likely to split. But this is improvised improvements here, so anything goes, its often a case of suck-it and see!
Ideas behind doing this to snowies bike, go like this:
First off, nice shiney shock, bought brand new for NOT an inconsiderable sum, compared to what it was bought to replace, which looked a lot like this, maybe a bit worse!
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/imag0783.jpg
Following thought.... err bolt THIS shiney bit to the bike, it gonna end up like that..... how can we forstall that result / prolong the life of the shock?
Now, whey-back-when, the old Girling type shock absorbers were shrouded or gaitered to protect the spring and damper mechanism.
In the 1960's exposed spring shocks became de-rigeur. Most Brit-Bikes still used gaitered or shrouded shocks, BUT racers used exposed shocks, becouse they were lighter, and it was believed that they dumped heat better, and longevity wasn't such an important criteria.
Japs gave us 'race track technology' for the road, and as it was cheaper to make an unshrouded or gaitered shock, and it was percieved as a higher performance part (Laught at that if you remember the old saying, 'Have a Drama on a Yokahama' and the notoriouse LACK of damping in Jap shox!), by the mid to late '70's exposed shocks were the more common fitment.
When the early Mono-Shock bikes came along in the early 80's, there was a vogue for them to again be shrouded or gaitered.
Reason being that the low and centrally mounted damper unit was RIGHT in the crud zone for muck flung off the rear wheel, and in teh wake of anything coming up under the engine, off the front.
And 'out-of-sight, out-of-mind', manufacturers took teh precaution to offer them a little protection, ESPECIALLY as mono-shocks systems were first evolved on Dirt-Bikes, that would see more than a little crud chucked at them.
With the mono-shock systems emigrating to road bikes, and with cost-cutting excersises on cheaper models, they quickly lost a lot of that protection, and on the CB125T, it is quite obviouse that the system has been engineered down to a price, the monoshock not even having any pre-load adjustment, relying on the high rising rate of the linkage to offer load compensation, and the sophistication of the design to offer ride & handling benefits over conventional T-Shox.
So, aware that the shock is in a vulnerable location, and that many older bikes and dirt bikes had gaiters as standard, though that as a mild-mod, gaitering this one may prove worth while, to give it a little protection against the elements, especially as this will be an all-year, every-day, all weather bike, and Snowies main mode of transport.
And yes, I do remember shock-socks and similar after-market products coming in and out of vogue over the years.
Anyway, starting point was a brand new shock-absorber, so there is NO crud, moisture or wear on there before we began.
Before putting it in the gaiter, it was liberally coated with chain-lube to give it a coating of moisture repellant grease, and protect the surfaces of any moisture that might get in there.
Gaiter then limits the amount of crud that can get onto the shock or the spring erroding the paintes or plated surfaces, or trapping moisture to induce rust.
Intension is that when teh bike is serviced, the gaiter will be lifted, the shock cleaned, and re-greased, when teh suspension linkage is.
The rear suspension on this particular bike is quite a sophisticated linkage, and has quite a lot of joints, and it DOES need propper lubrication periodically to keep it working well.
Most of the examples in my collection are pretty bludy ropey, and that is almost entirely due to neglect.
On most versions only the swing-arm pivot bushes actually have grease nipples, and I'm pretty sure that most owners wouldn't know what a grease gun looks like, even if they cared to enquire! Only the really early examples actually had grease nipples on any othe linkage joints, and even then, not on all of them!
Snowies bike will NOT be suffering such ignorance or neglect, she WILL be servicing it quite thoroughly and frequently, and she will be nagged to make sure her nipples are lubed Wink ....... Oh... yeah, and she sticks some grease in the suspension from time to time!
As for the question of heat dissipation...... I could go into a long and tedius discourse on the topic of damping, and the advantages of a short-stroke mono-shock compared to a pair of long stroke T-shocks, and how for teh same energy dissipation, a mono-shock unit will have to dump twice the energy as a single T-Shock, and being a short stroke device have generally less mass to absorb that heat and area to dissapate it..... and all that sort of stuff....
Bottom line here is that this is NOT a high-performance race bike, or heavy weight tourer, where the amount of energy going into the damper is all THAT high, and we live in wet, windy, britain, not some meditereanian paradice..... dont REALLY think that this thing is EVER likely to be so hard worked or get so hot, that it will start suffering seriouse damper-fade......
YES it IS something to have a think about, especially of you were thinking of doing this gaitering to say a ZX9R or something, but, in THIS case, I dont expect it to be an issue......
If Snowie ever starts complaining that the back end is getting a bit lively after some hard riding............ Smile I'll be a very lucky boy!
Oh.... sorry, if she ever complains about the BIKE getting a bit wobbly after a bit of thrashing..... well..... we may have to re-think the situation......
But at the mo, pros seem to outweigh the cons, so we're going to suck it and see Smile ......... might also give the gaiter a chance too!
Sorry, for all the inuendo! It's Sunday, naughty thoughts day! And I took her over to see a comp-trial this afternoon. Blokes in Lyca wiggling thier bums about, you know how women get!
Robby
Dirty Old Man
PostPosted: 07:30 - 20 Sep 2010    Post subject: Reply with quote
One of these days I'm going to read on of Mike's posts without having to scroll the screen. Do hope you come along to one of the BCF events though, you'd be a good person to have an in-depth geeky chat with about fixing old bikes.
Interested that you haven't put a jubilee clip around the top and bottom of that inner tube, it's protected from direct fling but crap and moisture can still work its way from above and below. I'd be tempted to clip it and cut (or burn with a soldering iron) a small drain hole just above the bottom clip.
neil.
PostPosted: 07:55 - 20 Sep 2010    Post subject: Reply with quote
Hmm, making a small hole would also ease pressure on the rubber during compression of the shock - it wouldn't balloon out. I have done this on my fork gaiters. I was also thinking heat-shrink might be good at the top/bottom of the tube as well, neatening things up a bit, but jubilee clips have the advantage of making it removable. Saying that, on my bike anyway, the shocks aren't meant to be taken apart/maintained (apart from cleaning)...
finpos
PostPosted: 10:38 - 20 Sep 2010    Post subject: Reply with quote
It used to be common to do exactly this to winterise your bike, Just leave the bottom undone so when it leaks it doesn't fill up!
f.
Teflon-Mike
tl;dr
PostPosted: 12:54 - 20 Sep 2010    Post subject: Reply with quote
Maybe..
I'm better in print... I have a pronounced stutter in real life!
We used thick cable ties. 50/50 call.
Could have used clamp-clips, but there was a lot of 'bag' to draw in around the kneck of the shock, the diameter of the spring being around the full 4" of the inner tube, while the shock body where the rubber is gathers is less than half that, maybe 1.75"
Hose clips are pretty secure, and could have given a very good seal, IF the rubber wasn't pleated underneath it. Risk there was that where the rubber folded on its self, the sharp edge of a jubillee could cut in, and where the rubber folded you'd be left with a gap anyway.
Good cable-ties can apply a lot of pressure..... off-roading, often get substituted for hose-clips in impromptu repiars, as they can apply 'enough' pressure, are more versatile, and portable.
If the difference in diameter wasn't as great, might have contemplated a jubilee, BUT, big problem with Jubilees is that they are metal, and are threaded.....
Stick a pair of them down there on a gaiter to stop the shock getting covered in crud and rusting..... outside the gaiter.... jubilees rust & sieze instead!
And a rusty hose clip is a right royal fuck in the arse to remove! Cable ties can be snipped off dead easy if they give your grief!
Vent-Hole idea also contemplated.
In THIS instance, its a short stroke shock; bike has about 4" of suspension travel at the rear wheel, shock-absorber compresses by only around 1.5" under FULL compression.
And it has a rising rate linkage with quite a high rate increase in the last portion of travel.
On the road, biek should 'settle' to nominal ride height, at about 1" of swing-arm compression, but that will only use about 1/4" of damper travel. During 'normal' riding, variation about the nominal, should only be about +/- 1" of wheel-movement, perhaps 1/2" of shock travel.
Or in small words.... the shock wont move much!
Looking at the baloon over the shock, its around 7" long, and 4" diameter, volume inside.... err... I cant be bothered to fathom! BUT 'normal' compression should only see it compress by around 7%ish.... even MAXIMUM compression, should only see it compress by 20% ish.
Tube is a tight fit, the spring coils showing under the tube, like an anorexic supermodels ribs, so I expect that for 'normal' travel, the balooning wont actually see the gaiter expand signiticantly more than simply loosening the fit, while full compression I hope wont see the gaiter actually start balooning, but merely go tad saggy!
Certainly the volume reduction, wont be enough to see significant pressure increase or windage, like you get on a close fitting fok gaiter.....
So, I HOPE that we dont actually need an auxilliary vent in it, but, as said, this is improvised improvements, and IF it bags or baloons significantly when its all fitted up and tested, we may add a hole or two....
Niel, your bike, presume we're talking the YBR125 in your sig-line, is a T-Shock, which is a slightly different arrangement.
First of all, the shocks on your bike are long travel units, providing wheel travel pretty much exactly 1:1 for damper travel, with no linkage to provide a rate change.
They are also 'cosmetic' parts, visible on the outside of the bike, not buried in its bowels, so two things, first of all, they have a cosmetic finish to them, I presume chrome, so that they are more resiliant to enviromental degredation.... (OK, RUST!), and second, not in QUITE such a harsh enviromental location, right in the line of the wheel's 'throw' and under the bike in the plash-wake!
I dont think that this would be a particularly great idea on your bike, Firstly the harder finish on the shocks and less hostile location, probably means that its benefits are negligible. Second up, Your shocks have about twice or three times the travel, and about half the diameter of the Mono-Unit. Putting them in an improvised gaiter, you would be more likely to suffer bagging & balooning, but probably more importantly, it would LOOK rubbish, and be in full view!
One thing I can say though, IF you are thinking about your suspension; little bikes tend not to get the best, and people dont apreciate the significance as much... I mean, its ONLY a tiddler, innit?
But, in fact, on a lightweight, the suspension is actually far MORE important than on a big-bike. There's less mass giving the uspension a hard time, but at the same time, there's less mass in the bike, offering any 'natural' damping, while the ratio of sprung to unsprung mass, probably THE most important criteria of suspension, is significantly unfavourable.
Works like this. Hit bump, bump tries to lift the whole bike. More mass there is in the bike, the more inertia it has and the less it wants to be bounced, less mass there is in the wheel and everything that can be moved up to the main 'sprung' mass of the bike, more readily THAT will deflect and offer complience, instead.
SO, heavy bike, like a gold-wing, LOTS of mass in the body of the bike, and yes, quite a bit in the wheels and swing-arm, BUT as a ratio, suspension going to move a LOT more readily than the bike.
Light weight scooter.... bugger all mass in the 'bike' and a LOT of unsprung mass, particularly having the engine and gear-box forming teh swing arm.... suspension going to be a lot LESS inclined to compress under a bump, and a LOT more inclined to pass that bump deflection on to the bike and rider.
Make sense?
Its made worse on tiddlers; they are ALL built down to a price, and the 'budget' commuter models get barely adequete suspension to begin with. And the shocks significantly lack damping, as thats the more expensive bit to achieve.
If you want to make an improvement to the ride & handling of a tiddler, and CG's & YBR's are a great case in point, a new pair of rear shox can often make a HUGE difference, and a pair of 'better' upgraded shox even more. and they NEEDN'T be really expensive ones, I think that Hagon's budget range are very good value for money, and for between £80 & £100 ish, they are often cheaper than an OE shock, and have better damping charecteristics.... basically thay have a bit!
Thing is, front forks tend to let you know when they need attension, and leak, demanding a seal swap, when they get new fluid, which rather than the seal, is often what makes such a dramatic improvement to the ride, as fork-oil, just like engine oil, breaks down over time & use.
Rear shocks are just the same, only 'sealed' and about 1/4 the size of a fork, you cant change the oil, and whats in there is far more heavily worked.
Worth a thought..... looking here at how to extend the life of your shocks, but really, on a T-Shock tiddler, the finish on them probably outlasts the functionality of them by many, many times.
So, if you want to keep them looking good, just glean them from time to time..... if you want to keep them working good, then a new pair are a worthy investment.
The last post was made 15 years, 173 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 0.78 - MySQL Queries: 14 - Page Size: 96.5 Kb
