First off
Derivative
PostPosted: 20:14 - 26 Sep 2010    Post subject: First off Reply with quote
I was practicing for my Mod1 today and managed to knacker the CG pretty badly Sad
The throttle on my bike has always been a bit sticky and sometimes needs a nudge. I didn't think this could be too dangerous until today as it's easy to fix quickly. Let the throttle go at 35, front brake on maybe a bit too fast. The rear wheel locked and the bike tipped left a little (wet patch?), I don't know what happened next. Think it regained traction, I went left and the bike went right. Pretty strange watching it slide down the road smashing bits off on the way. Gear is in a pretty bad state but knee armor kept me alright, scuffs on my visor as well.
The bike: Handlebars are out of alignment, I don't think the forks are bent as I managed to twist the wheel back into position with a bit of leverage. Speedo is smashed up and catches at 10mph as the clocks aren't parallel with the unit now. Both mirrors are knackered (not smashed, the joints are all buggered. Rear indicator snapped off, Front brake lever bent. Rear part of the 'fairing' is cracked as well, along with a knackered footpeg (rubber's snapped off, fair amount of the metal has ground down or snapped off somewhere)
Don't have any pictures as the bike is in a relative's garage, will be without it for a few months so I'll be checking up then :/
I'm just kinda depressed as I might end up having to just scrap the bike and hire for my practicals now. It worries me how easily this happened, not ungrateful that it happened on an empty industrial estate!
stonesie
PostPosted: 20:20 - 26 Sep 2010    Post subject: Reply with quote
Glad your ok, The bike can be fixed for not-a-lot by the sound of it, that's if you want it back on the road...
CaNsA
PostPosted: 20:38 - 26 Sep 2010    Post subject: Reply with quote
https://www.tier8.net/pictures/welcome1-126.jpg
joncwl
PostPosted: 20:42 - 26 Sep 2010    Post subject: Reply with quote
well the good thing is you ok at the least be thankful your bike took the damage and not you Confused glad your ok btw
currently being a cager cause winter......the bike will be back out during the summer now
last bike, 1990 yamaha tzr125 (2rk model) - still after a fairing kit for it !!!!!
blurredman
PostPosted: 20:45 - 26 Sep 2010    Post subject: Reply with quote
Ah gutted mate, sorry to hear that Sad
That's damn annoying fella.
I heard offroad motorbikes are easier to balance at lower speed because the natural high revving of the engine acts like a gyro better than a lower revving cg.
If that is the case, would it be a good idea to have the rev on the CG higher when doing things like low speed ?
joncwl
PostPosted: 22:29 - 26 Sep 2010    Post subject: Reply with quote
yeah offroad bikes are alot easier to balance i think my rm80 did roughly somthing between 15-20k revs revs my step dad said and he used to do alot of motocross racing in his youth and his dad did so they know a fait bit between them
c_dug
PostPosted: 23:50 - 26 Sep 2010    Post subject: Reply with quote
Surely the high centre of gravity of an MX bike counters any gyroscopic effect the engine has?
blurredman
PostPosted: 00:04 - 27 Sep 2010    Post subject: Reply with quote
After riding my CG125 around for some months now still getting bad balance on junctions, I rode my brother's TS50 and I was going 1mph down the garden and it felt so balanced and I was going in a straight line and without putting feet down... It was amazing!
c_dug
PostPosted: 00:51 - 27 Sep 2010    Post subject: Reply with quote
I don't think that can be attributed to this:
A TS50 engine is tiny, and at "1mph" the engine is hardly revving its head off so any gyroscopic effect will be minimal.
When a bike is moving at speed the wheels create a large amount of gyroscopic force, hence why turning a bike at speed is harder than turning one a low speeds.
I would image an MX bike being easier to balance is more to do with the riding position, and maybe a lower weight, although when comparing a CG125 with a TS50, there is probably not much difference in the weight.
blurredman
PostPosted: 08:53 - 27 Sep 2010    Post subject: Reply with quote
[quote="c_dug"]I don't think that can be attributed to this:
Blurredman wrote:
the natural high revving of the engine acts like a gyro/quote]
It just felt much more natural on the other bike than on my cg..
Sorry for thread-jacking OP Sad
Bull
PostPosted: 09:16 - 28 Sep 2010    Post subject: Reply with quote
[quote="Blurredman"]
Hi im new,
I ride a CR250 MX Bike every sunday i Marshall with it picking people up thats fallen off ect And yet when i did my MOD1 i failed it by putting my Foot down on the Figure of 8 ( rest was faultless!!!)
MX Bikes are set up for slow riding aswell as fast and for going in and out of tree's ect there seat being higher makes a Big differnce!!!
I brought a ER5 (500cc) bike and found it weid to ride come paired to the CR250,
(the ER5 Had also been dropped and did simaler damages to your CG Bars indercator mirrors and clutch lever dent in the fuel tank)
But there all easy bits to replace EBAY will have all the parts for your CG im sure,
If you have some idea with Spanners your soon have it fixed up to use (money depending)
Hope you get it fixed up and get your test done soon i passed mine Last Monda and Only had 1 dry day or riding the CBR600 i got the rest i got wet but still using it ;D
tahrey
PostPosted: 19:37 - 11 Oct 2010    Post subject: Reply with quote
Bad luck fella Sad
However if you haven't ruined the frame I bet you can patch it up cheaper than you think with ebay and/or scrappie parts. What, bars, mirrors, pegs and plastics? All bolt-ons. Wink
As for the gyro thing, this was actually a tip that one of the guys on my DAS said about. I don't know whether it's real, or some kind of placebo thing (and the real trick to it is that it means you can smoothly feed the power in with the clutch, rather than having a lumpen surge with it fully engaged), but it definitely did wonders for my stability on the figure-8, U-turn, tight corners and all that stuff. Probably more effective on a slightly larger engine - maybe a 125 but certainly the 500s we were using.
'course, it's no good on a boxer or the like!
Clanger
Stirrer
PostPosted: 13:09 - 14 Oct 2010    Post subject: Reply with quote
Don't beat yourself up about it. In hindsight you will see it's better that you do all your falling off, and silly accidents on a cheaper slower ride. It's all part of the learning process.
Once you become more proficient and capable, you won't make so many daft mistakes and you will become more confident...and with confidence comes the bigger and more powerful and more expensive bikes...
By this stage you won't want to come off because of the expense of the damage it will cause...hopefully it won't come to this, because you will be a better rider. Karma Thumbs Up
The last post was made 15 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 89.91 Kb
