| SpannerMonkey |
 SpannerMonkey World Chat Champion
| lewis87 |
 lewis87 Scooby Slapper
 Posted: 22:23 - 28 Sep 2010 Post subject: |
Loads of "how to wheelie" videos on youtube that might help you.
Look at my hands in this video, it is just a quick flick of the clutch with a handful of throttle at the same time:
https://www.youtube.com/watch?v=rocCWSryKA
Just roll along at a steady speed where your bike makes good power, then try it. Start with small amounts of throttle and it won't jump up high.
| SpannerMonkey |
| lewis87 |
| SpannerMonkey |
| tvr321 |
 tvr321 Nitrous Nuisance
| SpannerMonkey |
| lewis87 |
| lewis87 |
| TUG |
 TUG World Chat Champion
| G |
 G The Voice of Reason
| Misc |
 Misc World Chat Champion
 Posted: 14:51 - 29 Sep 2010 Post subject: |
How easy are 1000cc bikes to power wheelie?
On 600s i know you have to accelerate hard or do that snapping motion to get it to power wheelie, is this the case with a 1000 or does it take no effort to smoothly lift the front?
I ask because i've had the Bandit 600 power wheelie accidently a few times now & each times it's been so smooth i hardly noticed it. When i've tried to replicate the power wheelie i just ended up red lining the bike. Not sure what i done. Had the same on the Ninja once. |
| G |
| Misc |
 Posted: 15:58 - 29 Sep 2010 Post subject: |
I didn't like the feel of holding the throttle open, seems you have to snap it wide open straight away for it to lift which made me feel uneasy & even less in control then 'attempting' to use the clutch, not to mention the screaming engine. I thought the 1000s would be much less effort at lower speeds & feeling more in control when power wheelying.
One thing that puts me off a bit is that i've never felt comfortable with any of the rear brakes on my bikes. Probably because i'm tall & could do with a custom set. |
| G |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 16:59 - 29 Sep 2010 Post subject: |
Well first off, there are so many ways to get it wrong trying to wheelie, you can seriousely mangle your bike, without MUCH effort what so ever.....
That acepted......
Practice, Practice, Practice!
If you are going slow and 'snap' the throttle open, you get 'lag' in the throttle, and the impotus to get the front end up is lost by the time the engine responds.
You need the motor spinning at a responsice speed, with a bit of gas before you begin. THAT is where having a bit of clutch control comes in.
Trickle it, wind on the throttle, getting the revs up without increasing road speed, then use the clutch & throttle to feed the power in hard, at say 7K revs, opening the throttle progressively, and feeding in the clutch, without dumping or snapping, AS you apply a little rearward weight shift to aid upwards momentum, BUT keep enough weight over the front that you can PUSH it back down if its coming up too much.
You need to work up, to the point of balence, where it will 'flip' and get to the point where you can hold it 'just' before that flip-point on balence and throttle.
ONE 'trick' worth a thought is the 'dive' wheelie. Used all the time in trials and off-road, you throw your weight forwards just before you start the manouver to compress the forks, THEN as they start to come back up, you wind throttlke and feather clutch, using the 'rebound' to get the initial upwards imputus for the wheelie.
THE most important thing about wheelies is dont do ANYTHING suddently of violently.... any sudden or violent actions, (like dumping the clutch!) have violent re-actions..... and thats what either makes the bike bog, stall, or flip! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Misc |
 Posted: 17:00 - 29 Sep 2010 Post subject: |
Cheers. You're completely right about getting used to it, that initial jolt when you clutch it in puts me off, just need to get more of a feeling for it. A wheelie day would be good for this, or i could man up & practice in a carpark. |
| G |
 Posted: 17:03 - 29 Sep 2010 Post subject: |
| Teflon-Mike wrote: | ONE 'trick' worth a thought is the 'dive' wheelie. Used all the time in trials and off-road, you throw your weight forwards just before you start the manouver to compress the forks, THEN as they start to come back up, you wind throttlke and feather clutch, using the 'rebound' to get the initial upwards imputus for the wheelie. |
On the road you tend to do this by bouncing down on the pegs with your feet.
THE most important thing about wheelies is dont do ANYTHING suddently of violently.... any sudden or violent actions, (like dumping the clutch!) have violent re-actions..... and thats what either makes the bike bog, stall, or flip! |
Dumping the clutch is definitely the way to do it I'd say; 'violently', if you like. However, of course, the trick is to do it well under control and not to suddenly try it at redline when you've never done that before.
I always say that approached sensible, it should be a lot safer learning to wheelie sensibly than riding on the road normally. |
| dragstaar |
 dragstaar World Chat Champion
 Posted: 17:09 - 29 Sep 2010 Post subject: |
The one thing I'll tell you is this:
No matter what everyone says, it'll all be gibberish to you untill you actually get that wheel up for the first time.
I still remember my first wheelie, i was trying for a week before i got it. I was doing everything right, rolling slowly forward, slipping the clutch, but the damned bugger just wouldn't come up, and thats embarrassing seeing as it was a 600 bandit!
But now i can wheelie my dad's turd CG125.
1. You're stationary.
2. Start rolling forward in 1st gear, you'll be doing about 5-7mph.
3. snap the throttle on (not all the way, but give it some umph. you can increase the umph as you get more comfortable)
4. literally, a split second after you snap the throttle open, pull the clutch in a tad and let go, all in a smooth motion that lasts less than a second
5. your front wheel comes up!
if it didnt, then try again. When you open the throtte just before you slip the clutch, it throws the weight back, then the clutch slip lets the front wheel come up easier.
You will inevitably close the throttle as soon as you feel the wheel come up. this is normal, you gotta becom fearless and hold that throttle open.
Just before you land a wheelie, give it some throttle and it'll land oh so smooth! |
| Teflon-Mike |
 Teflon-Mike tl;dr
| P.addy |
 P.addy Red Rocket
 Posted: 17:56 - 29 Sep 2010 Post subject: |
| joncwl |
 joncwl Scooby Slapper
| J D |
 J D World Chat Champion
 Posted: 18:02 - 29 Sep 2010 Post subject: |
Go on paddy lets see a wheelie vid  ____________________ m0l0t0v wrote: Chris, just so you know, JD is a nutter
| r0b |
 r0b Renault 5 Driver
| Jayy |
 Jayy Mr. Ponzi
The last post was made 16 years, 31 days ago. Instead of replying here, would creating a new thread be more useful? |
