ignition prob gpz 500s
sweating bullets
PostPosted: 13:03 - 09 Oct 2010    Post subject: ignition prob gpz 500s Reply with quote
Has any one had this prob before? on more occasions now the bike wont fire up from cold but when it has been running it fires up straight away, ive had the plugs out and there has been no spark, but after a few times of engine turn over atemps it will fire up however from cold if i turn the ignition on and leave it for a minute or two then turn fire it up it starts up and runs like a dream after that.any suggestions ?
0ddball
PostPosted: 13:53 - 09 Oct 2010    Post subject: Reply with quote
Check the main relay and fuse behind the left hand rear panel. It gets furred up with white powdery corrosion and can cause intermittent cutting out and starting problems.
sweating bullets
PostPosted: 10:04 - 10 Oct 2010    Post subject: Reply with quote
Hi thanks oddball ! i noticed that late yesterday i bought some new 30amp fuses and a bit of switch cleaner and it fired up straight away however i have not tried it this morning i thought i would check this first for any replies ive seen yours and it seems like it could be the answer so all being well we both could be right so fingers crossed i will try it from dead cold and i will let you know. many thanks for you reply.
sweating bullets
PostPosted: 18:55 - 10 Oct 2010    Post subject: Reply with quote
That seems to of done the trick fired up no probs ran a treat at 70 left it to cool fired up again at 6.30 jobs a good un Thumbs Up cheers.
The last post was made 15 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.05 - MySQL Queries: 14 - Page Size: 37.99 Kb
