ajbsmirnoff |
ajbsmirnoff World Chat Champion
UnspeedySam |
UnspeedySam World Chat Champion
Robby |
Robby Dirty Old Man
UnspeedySam |
nowhere.elysium |
nowhere.elysium The Pork Lord
Posted: 11:30 - 01 Nov 2010 Post subject: |
'The boy'? Cheeky git. Still, you know infinitely more about 80s bikes than I do, so I'll let that one go, this time.
As Robby says, most Jap bikes from the beginning of the 80s onwards are guaranteed to run on unleaded. I believe that the Japanese have had unleaded fuel since the 70s.
I didn't get the opportunity to strip the switchgear properly yesterday, on account of having my parents over for dinner, which had to take priority. Hopefully, I'll have something to report on this by tonight/tomorrow. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
Kickstart |
Kickstart The Oracle
Robby |
Robby Dirty Old Man
nowhere.elysium |
Robby |
Robby Dirty Old Man
nowhere.elysium |
Posted: 12:44 - 05 Nov 2010 Post subject: |
Stripped, cleaned, tested and fixed the switchgear now, and photos will follow shortly.
Starter solenoid appears to be toast, though. I've stripped it down, and checked the winding for continuity, only to discover there isn't any.
I can get hold of one for £40, but unfortunately, I lack £40 at the moment. Tits.
Anyone got any workaround suggestions?
:edit:
are there likely to be any adverse effects if I temporarily bodge* the starter solenoid off my Chinese bike on there, for the sake of seeing if I can convince it to start?
*The earth wire fits differently. Other than that, it looks similar. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
Robby |
Robby Dirty Old Man
nowhere.elysium |
Posted: 13:54 - 06 Nov 2010 Post subject: |
Robby wrote: | A solenoid is effectively just a chunky relay, so it should work. Give it a go and see.
How dirty was the switchgear? |
Yeah, I'm going to head down and give it a shot when I've finished re-organising the living room. Again.
I'm also intending to re-test the coils, as I'm a little dubious of the readings I got before. I'm hoping that a) the chinese solenoid can handle the current that the Suzuki one is designed to deal with (I'm never likely to be in a position of fully trusting a Chinese component), and b) the coils really are ok, and that it's only the solenoid that's toast.
Given the fact that I got a good continuity reading through the HT leads, the coils are the obvious candidate at the moment.
The switchgear was full of prime 80s filth. My parents keep muttering about how much dirtier the roads were in the era of four-star, and I'm beginning to believe them. Sticky black shite a full millimetre deep in places.
Anyways; a more detailed pictographically-laden report will follow. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
Blau Zedong |
Blau Zedong Banned
nowhere.elysium |
Posted: 14:32 - 06 Nov 2010 Post subject: |
BLUEX5 wrote: | Just seen this, looks a fun project. I think most of the issues you'll have in getting it to fire up, and run will be related to the fuel system, and I have a feeling you'll be exploring the deepest darkest reaches of the carbs before too long as they'll be full of nasty tar from gone off petrol. Rest of it looks OK, and they are pretty solid bikes. |
Well, brown goop has already been extracted from the fuel tap (which was the biggest fuelling problem thus far); the plugs are getting wet, and the float bowls drained successfully, so I'm thinking the carbs aren't the hugest problems on this one at the moment. However, fate has a talent for proving me wrong, so I'll lay off the proclamations of perfect function for now.
The biggest issue at the moment is that there's no spark. With a bit of luck, as soon as I can sort that, we should have a bike that's in some state of running. Coils aren't all that cheap (£25 each), though, and the solenoid's looking pricey too (about £60, last I looked).
Given your predilection for Suzuki's air/oil-cooled lumps, d'you know if I can get away with transplanting bandit parts onto there in the mean time, just to get it running? I'm going to try swapping the solenoid from my 125 on to there as a temporary check, but I'm not sure how long it'll last. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
virus |
virus World Chat Champion
Posted: 14:58 - 06 Nov 2010 Post subject: |
Check:
Mechanical advancer isn't seized, its a counterweight spring affair under the left hand crankcase if i remember correctly.
Carb slides are coming down correctly, remove carbs, lift the pots one at a time and see if they come all the way down firmly but slowly, if not you've got leaky diaphragms or crap in the body between the slide and the inner wall.
Pilot jets, id expect them to be brass and tar plugs by now rather than precise holes, fag lighter refill can is good for clearing these just dont cold burn your hands.
earth points, both battery to frame and coils to frame, the bolt that mounts them to the frame supplies earth so if theres corrosion all over it then it wont be helping.
Oh and you should be alright on solenoid bodging, as robby says its just a big relay, if anything dies it'l be the chinky solenoid and not the bike so its all good.
John ____________________ own: 81 xs1100g...
nowhere.elysium |
Posted: 16:31 - 06 Nov 2010 Post subject: |
virus wrote: | Check:
John |
Cheers for the info: that's definitely on the list of things that need doing. At the moment, fuel is getting through to the cylinders, but I have no way of currently telling how accurately metered out it is: I'm more curious to see if it'll spark/start up, in the short term.
On a curious and perverse side note: the Chinese solenoid was a drop-in replacement: everything bar the hull stampings are identical, even the molex plug.
The coils will be coming off later today, with a little luck, and I'll be checking the mounts for corrosion. From what I remember, they had been pretty well preserved by the horrible black crap that was all over them, but they've only really had a cursory inspection.
Anyhoo: the promised photos of the switchgear stripdown:
https://farm2.static.flickr.com/1401/5150813743_95d4f94090_z.jpg
This is just after having given the contacts a bloody good scrub with wire wool - they're still discoloured as hell at this point, but I ended up scraping much of the muck off with a screwdriver.
https://farm2.static.flickr.com/1420/5150813239_438ab37a39_z.jpg
As you can see from the state of the phillips screw head there, someone else has had a go at this previously, and kinda bollocked it up. Not to worry, I convinced it to move with a set of pliers, and managed to get away with not causing any further damage. After cleaning all of the stuff out of the head of the screw, I can now undo it with a screwdriver successfully, so I didn't feel the need to replace it immediately. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
Blau Zedong |
Blau Zedong Banned
virus |
Robby |
Robby Dirty Old Man
Posted: 22:02 - 06 Nov 2010 Post subject: |
This month's issue of motorcycle mechanics has a full feature on cleaning out rusty fuel tanks, which is timely. Worth getting, but the basic jist is:
1. Empty the tank, pop in a couple of detergent or dishwasher tablets and fill it with boiling water. Leave for a few hours, moving occasionally to make sure that all sides of the tank get a good soaking.
2. Empty, rinse with water.
3. Fill with an acid strip solution - various acids do this, although rather annoyingly it doesn't say which ones, apart from that you should take care with brick acid.
4. Drain, rinse a couple of time, swill round some meths, drain, leave to dry somewhere warm.
5. Fill with fuel or swill round some oil to stop is rusting if it will be stored empty. |
nowhere.elysium |
Posted: 09:49 - 07 Nov 2010 Post subject: |
BLUEX5 - it's CDI ignition, I'm afraid. Will standard I4 CDI coils for a bike of similar displacement do the trick? I keep banging on about the Bandit ones because a) they're a piece of piss to get hold of, and b) they're a third the price of GS coils.
Robby - Got any suggestions as to what kind of acid solution should be used? I've also been given a bottle of Petseal by a mate of mine, who's never had cause to use it. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
virus |
Kickstart |
nowhere.elysium |
Robby |
Robby Dirty Old Man
Posted: 12:48 - 08 Nov 2010 Post subject: |
Have you tried it with the fixed switchgear and different solenoid yet? Always fix the problems you know before trying to fix the ones you're not sure of.
Also, give all of the fuse contacts a good going over to get shiny metal. They're fickle.
As for acid solution, probably any acid will do. Hydrochloric can attack paint so needs extreme care, I would try sulphuric. See if you can acquire some from the lab at uni, and do a test by leaving a rusty nail in it for a few days to see if it works before filling the fuel tank. It should work, I know its an excellent way of cleaning sinks.
As for petseal, a tank liner shouldn't be necessary after an acid strip and they're best avoided unless absolutely necessary. Only the very newest liners are compatible with modern fuel. The acid strip you should leave you with with dull grey, slightly pitted, steel.
You'll need to make up a plate to cover the fuel tap hole, a little bit of steel with some holes drilled to bolt over the hole and a strip of old inner tube as a gasket does the job. Don't leave the fuel tap in, the acid may eat the tap or the filter. Leave it on the balcony over a plastic tub in case something leaks.
Do the trick with some dishwasher tablets first though, a lot of that rust is loose and will shift easily, giving the acid an easier time. |
nowhere.elysium |
Posted: 16:07 - 09 Nov 2010 Post subject: |
Not tried starting it up again, yet: should be having a crack at that on Friday, though. Given that there was no spark even when we were shorting the solenoid, I'd assume that the problem* wasn't there, though.
Good news, though - I'll re-check the coils as and when I get the chance (hoping to tomorrow - I can't tonight), but if they do need replacing, the Bandit ones are the same rating, according to the Haynes book of lies. The fact that my local bike shop has got a couple of spare ones knocking about that I can have fairly cheap is just largely comprised of awesome.
As for getting hold of acid from work: I'll see what I can do, but we don't do a chemistry degree, and the closest we've got is Health and BioSciences. They should have some (I'd hope) but since they're on a different campus, it may be a little difficult to acquire it. Any ideas as to where I can buy some? Alternately, are there any other common household chemicals that'll do the same job without destroying the paint?
Would just blasting it with the dishwasher tablets be enough to shift the bulk of the loose stuff? Since I'm intending for this bike to receive fairly regular use, I'm not expecting there to be frequent water ingress.
*i.e. the lack of spark. Obviously, the solenoid was fucked, but that was it's own issue. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
The last post was made 13 years, 171 days ago. Instead of replying here, would creating a new thread be more useful? |
