MarJay |
MarJay But it's British!
nowhere.elysium |
nowhere.elysium The Pork Lord
Posted: 11:19 - 17 Jul 2012 Post subject: |
Fizzer - I remember just what a difference balanced carbs can make from my experiences on the Bandit. Unfortunately, I don't have a temporary tank yet - I've got a fairly high-capacity petrol-resistant funnel that I can use, although I'll need to make up an adapter pipe for it.
Shaft - that sounds beautiful. I'm still in two minds about the whole idea, because if I can get the CV carbs sorted I won't need to touch them again for some time, but a pair of sidedraft Webers does sound awesome in pretty much every available way
MarJay - Cheers It was a worthy learning project, I think, especially after my initial sodding about with smaller bikes. I can't help but think that it gives off this slight air of 'old man', but since it's such a composed ride, I genuinely don't care ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
MarJay |
nowhere.elysium |
chris-red |
Robby |
Robby Dirty Old Man
Kickstart |
Kickstart The Oracle
neil. |
neil. World Chat Champion
Posted: 05:58 - 18 Jul 2012 Post subject: |
I have a theory. Suppose you were to leave the idle running as rich as it is. Suppose that when you pull up to the 'ring of steel' at work, and they ask you to remove your lid, do a strip search etc, you leave the bike running... It's possible that they'll soon pass out/throw up. ____________________ CBT February 2008 | A2 June 2008 | Yamaha YBR125 (written off) | Honda CBF125 (current) |
nowhere.elysium |
MarJay |
nowhere.elysium |
Posted: 11:59 - 23 Jul 2012 Post subject: |
MarJay wrote: | nowhere.elysium wrote: | In unrelated news, I've just sorted the fuel sender. I now have a working fuel gauge. |
Aww maan. I want a bike with a fuel gauge now. Seems silly, but I do!
I'm almost tempted to buy a BMW for commuting... someone stop me! |
Well, if it makes you feel any better, the fuel gauge is temperamental. If it rains, I have no fuel gauge for the next 24 hours - I need to go over everything with some kind of waterproofing technology that's better than my 'plastic bag zip-tied to the switchgear' approach.
In related news, the carbs are now balanced, thanks to the significant efforts of my mate Toby, and Shaft's 'point and laugh'-fu. 'Tis lovely. I've got the new indicator relay, too, so I should have it all completely operational before too long. Just need to coat the electrical system in vaseline or something similar.
:edit: Also, yes, I've now oiled the air filter. So glad it's not one of those silly K&N 'requires the special lube' filters - 10W40 is the recommended, and that is indeed plentiful. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project
chris-red |
Shaft |
Shaft World Chat Champion
Posted: 17:07 - 23 Jul 2012 Post subject: |
What's needed here is self amalgamating wiring! ____________________ Things get better with age; I'm close to being magnificent........
nowhere.elysium |
Casper |
Casper World Chat Champion
nowhere.elysium |
Posted: 10:46 - 25 Jul 2012 Post subject: |
1888 wrote: | That sounds like two things wrong. The tap should not let that happen unless it was left on prime but the carb needle jets should not let it happen also so the jets have shit or float hight on one is wrong. When i did my float hight on my GPz i made the mistake on only measuring one float but they were squint so i got false readings. |
I've done all of the float heights properly, and the float needles were replaced some time back. The tap was set to 'on', so it shouldn't have been that. I'll get to the bottom of it, it's just not really something that you want to see of a morning, you know? I've still got the SV, so can commute on that (which is the main reason for hanging on to it), but I'm just a bit irritated, is all. I don't know what it is that could have changed between last night and this morning, aside from the heat. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
Casper |
nowhere.elysium |
Casper |
nowhere.elysium |
Posted: 12:36 - 25 Jul 2012 Post subject: |
The vacuum takeoff on there looks properly budget, too
It's a brass spur on mine, as opposed to the cast rubbish that's on that one. I've fitted a rebuild kit to the original tap anyway, so I'm reticent to point the finger of blame at that - I'm going to see what's what on Friday, and hopefully get it all nailed down. I'm just a bit annoyed that I'd only filled the tank yesterday evening, so that's nearly £20 of petrol that's gone. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
Suntan Sid |
Posted: 19:32 - 26 Jul 2012 Post subject: |
Finally found the photos of my 550, I'll scan'em in at work tomorrow! ____________________ "Everybody needs money, that's why they call it money!" |
nowhere.elysium |
nowhere.elysium |
nowhere.elysium |
nowhere.elysium |
Posted: 18:30 - 01 Aug 2012 Post subject: |
Oh, it gets better. On the ride home from Rainham, it decided to shed a downpipe. Yes, a downpipe.
Managed to recover it ok, bungeed the downpipe to the luggage rack once it had cooled, and then proceeded to push the bike back home.
All 240kg of it.
In full leathers.
At the only point in the day when the sun elected to shine upon us.
Never before have I felt like I've deserved a beer as much as I do now. Thank fuck for off-licenses, is all I can say. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
The last post was made 11 years, 269 days ago. Instead of replying here, would creating a new thread be more useful? |
