Speedfight 50 starting problems
lee24yorkshir...
PostPosted: 11:59 - 28 Sep 2010    Post subject: Speedfight 50 starting problems Reply with quote
Hi all, I am having problems getting my speedfight 50 goin, it turns over with good compression and i have got a spark, plug is also wet when i remove it so petrol is getting thru. Can anyone give me other things to check? I havent tried a new spark plug yet altho i have tried a different spark plug but was an B8es. it sounds like it wants to fire up and smoke comes out of exhaust but it just wont go
Thanks
lonie This post is not being displayed because the poster is banned. Unhide this post / all posts.
lee24yorkshir...
PostPosted: 16:25 - 28 Sep 2010    Post subject: Reply with quote
the battery is brand new on today fully charged definitely not that, I will be getting a new plug but the b8es was brand new and that didn't help so cant see it being that. As for the imoboliser am not too up on these but would I get a spark if this was at fault? carb has also been cleaned out earlier but will try some fresh petrol with the new plug, thanks
lee24yorkshir...
PostPosted: 18:39 - 28 Sep 2010    Post subject: Reply with quote
well I tried some fresh petrol but to no avail, also the immobiliser seems fine, light comes on, goes off, then flashes twice and stays off. what compression should it be kicking out as its reading at 130psi, which doesn't seem low.
lee24yorkshir...
PostPosted: 19:45 - 28 Sep 2010    Post subject: Reply with quote
yeah tried it with the air filter off spark looks blue but not 100% sure if its a good spark might get a new coil and try that. something else i discovered is the spark plug is a speedfight 100cc and upon further inspection the barrel is 100cm with 50.5mm piston. would a 100cc barrel fit a speedfight 50 or would a 100cc engine fit a speedfight 50? just wondering what coil to get 50cc or 100cc or are they the same?
Thanks
lee24yorkshir...
PostPosted: 23:34 - 28 Sep 2010    Post subject: Reply with quote
Thats how I bought it, just been reading somewhere that if the fuel tap is faulty this can cause the engine to flood but not sure how to check it, its some kind of vacuum tap? anyone know how to check the functionality of this part?
Thanks
lee24yorkshir...
PostPosted: 23:50 - 28 Sep 2010    Post subject: Reply with quote
the bottom pipe on the pump is dry but when I disconnect the upper pipe petrol comes from the tap, does that mean its ok?
lee24yorkshir...
PostPosted: 00:06 - 29 Sep 2010    Post subject: Reply with quote
the only time I touched the fuel cap was when I put fresh petrol in earlier but then it was refitted straight away. I've ordered a coil anyway so see if that helps
thanks for your input people, I will get this thing going!
lee24yorkshir...
PostPosted: 00:37 - 29 Sep 2010    Post subject: Reply with quote
if the tank breather was blocked wouldn't that cause fuel starvation? there's plenty of fuel getting thru i no that for sure
lee24yorkshir...
PostPosted: 12:06 - 02 Oct 2010    Post subject: Reply with quote
well i have changed the coil today and still no joy, what else could cause a weak spark?
Paxovasa
PostPosted: 12:11 - 02 Oct 2010    Post subject: Reply with quote
Dodgy lead.
Glenben92
PostPosted: 12:22 - 02 Oct 2010    Post subject: Reply with quote
not flooding is it? "spark plug is WET" rings alarm bells to me like
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
lee24yorkshir...
PostPosted: 12:30 - 02 Oct 2010    Post subject: Reply with quote
could be floodin what would cause that?
Paxovasa
PostPosted: 12:34 - 02 Oct 2010    Post subject: Reply with quote
You flood it when you keep trying to start it and it does not fire up. If it is flooded leave it 10 mins until you try to start it again. So the petrol can evaporate.
lee24yorkshir...
PostPosted: 15:40 - 02 Oct 2010    Post subject: Reply with quote
I think it must be a weak spark but the coil is not at fault so I need to find out what else could cause this?
Glenben92
PostPosted: 11:52 - 03 Oct 2010    Post subject: Reply with quote
Bare in mind that with a 2t, if the plug gets oiled up its NOT gonna start. Mixture could be too rich, which fouls the plug with oil before it can get a chance to fire. I've had this before with a 2t ped.
andys675
PostPosted: 12:30 - 03 Oct 2010    Post subject: Reply with quote
if you have a speedfight with an immobiliser you should always use a Resistor type spark plug as in BR8ES as the radio waves transmitted by an non resistor plug can damage the CDi, frying the programming so it fires at the wrong point, also getting the cdi connector plug wet can affect the spark timing, as does putting the battery on the wrong way or shorting it out Wink
The last post was made 15 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.76 - MySQL Queries: 17 - Page Size: 133.08 Kb
