1st to 2nd a bit clunky
timboellis
PostPosted: 18:36 - 16 Oct 2010    Post subject: 1st to 2nd a bit clunky Reply with quote
It may just be me but my NT650V seems a bit clunking going from 1st to 2nd anything i should be checking/?
Clanger
Stirrer
PostPosted: 19:16 - 16 Oct 2010    Post subject: Reply with quote
Normal for a Kwaka...dunno about NTV, though the Bros always seemed smooth. Neutral
timboellis
PostPosted: 19:27 - 16 Oct 2010    Post subject: 1st to 2nd a bit clunky Reply with quote
Well all the other gears are fine, also seems to be okay after running for some time like 20 mins or so.
Paxovasa
PostPosted: 19:30 - 16 Oct 2010    Post subject: Re: 1st to 2nd a bit clunky Reply with quote
May need to adjust the clutch cable, they do stretch through time and use. Thumbs Up
Is the drive chain set to the right tension?
Frost
PostPosted: 19:57 - 16 Oct 2010    Post subject: Reply with quote
Simple way to tell if it's the clutch: Start it up, then without sitting on it put it into 1st gear. As your weight isn't on the bike the chain will have some slack. If it bounces when put into gear the clutch is dragging. Another way to tell is to remove the clutch from the equation completely and change up without it and see if things are any smoother.
The last post was made 15 years, 324 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.44 - MySQL Queries: 14 - Page Size: 42.99 Kb
