Removing Bandit 600 Tank - Fuel
Adam.I
PostPosted: 15:17 - 18 Oct 2010    Post subject: Removing Bandit 600 Tank - Fuel Reply with quote
Hello all. When I had a Bandit 600 back in 2008, I took the tank off to see the condition of the air filter. As I was taking it off, petrol was going all over the place, despite following the manual.
I have just bought another Bandit 600, and I need to check this one as well. I have got the Suzuki service manual this time round.
The procedure is as follows:
Remove seat.
Remove the fuel tank mounting bolts.
Turn the fuel valve knob to the 'ON' position.
Remove the fuel valve know by removing its mounting screw.
Disconnect the vacuum hose, the fuel hose and the fuel tank drain hose.
Is there something I’ve missed or the service manual missing something (apparently, they don’t always include everything or vague)? Don't want fuel all over the place again!
Veni Vidi Vici
PostPosted: 15:36 - 18 Oct 2010    Post subject: Reply with quote
As above, but the fuel taps can fail and allow fuel to pass all the time.
Paxovasa
PostPosted: 15:39 - 18 Oct 2010    Post subject: Reply with quote
Sounds right to me Thumbs Up
Adam.I
PostPosted: 15:55 - 18 Oct 2010    Post subject: Reply with quote
Thanks for the replies chaps! Just took of the vacuum hose and the fuel hose, absolutely nothing came out. As for the fuel tank drain hose, there doesn't seem to be anything there? There is two 'pipes' metal pipes located near the mounting bolts (but on the tanks underside) and there is an electrical wire to the side of them which won't unclip, but no actual tube.
Veni Vidi Vici
Adam.I
PostPosted: 17:27 - 18 Oct 2010    Post subject: Reply with quote
Well I managed to get it off, and the filter is absolutely filthy, almost black and loads debris inside each part. Incidentally, does a dirty air filter increases fuel consumption and put a strain on the engine? Makes me wonder about other things if and when they were last done. The front brake pads were down to the metal and rusted to high heaven!
Also, should a worry that no fuel tank drain hose is present?
Veni Vidi Vici
The last post was made 15 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.59 - MySQL Queries: 14 - Page Size: 45.24 Kb
