megneto timing advance reatrd no points help
nezzifer
PostPosted: 23:56 - 05 Dec 2010    Post subject: megneto timing advance reatrd no points help Reply with quote
hi i have a honda redrocket cr100 i need to sort the timing i have sorted the tdc with the magneto but i need to sort the advance retard postion im not sure if im doing it right.
if i take the flywheal off then i get a plate behind that with 3 screws i have to undo then i can knock it so far right or so far left theres no arks on the plate and could do with some tips or pointers on how to sort the tiing out any info would be grate thanks
Lynxx
PostPosted: 19:39 - 08 Dec 2010    Post subject: timing Reply with quote
if theres no marks im guesing the screws would be in the middle of there slots. just a guese, should be 3 marks though.
Current: 1992 Suzuki GSF400V - 1984 Honda MTX200 (SOLD) - 1975 Honda Xl350 (SOLD) - 1993 Honda CB250 (SOLD)
Teflon-Mike
tl;dr
PostPosted: 20:46 - 08 Dec 2010    Post subject: Reply with quote
Often it's 'timed' by the points gap, @TDC.
spark happens when the points start to open. That breaks the circuit 'energising' the coil, causing the electromagnetic field in the primary windings to colapse.
Spark is generated by the coils of the secondary winding in the coil, 'reacting' to the colapse of the field in the primary winding, and creating a huge reverse voltage.
That change is initiated moment the points start opening, BUT we measure the points gap, when they are fully upen.
Ie some degrees of crank rotation AFTER the points started opening, trigering in the spark.
So, if there's NO other markings or guides, default is:-
- Rotate crank to TDC.
- Rotate back plate to get the points follower on the peak of the cam, at TDC.
- Adjust the contact gap to specified setting
- Then nip everything up.
Sparks will fire as points open, which will be at a few degrees in advance of TDC, and gives you your 'base' setting for fine tuning, dialing in more or less advance to suit your fuel and pre-mix etc.
The last post was made 15 years, 290 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.66 - MySQL Queries: 14 - Page Size: 37.32 Kb
