Bandit 600 K2 Spark Plug Socket Size
Adam.I
PostPosted: 23:10 - 23 Oct 2010    Post subject: Bandit 600 K2 Spark Plug Socket Size Reply with quote
Hello all. Does anyone know if this would fit the spark plugs on a K2 600 Bandit. No toolkit supplied with the bike so need to buy something to check. Had a search but keep getting various answers. Thought the experienced BCF lot would know!
Veni Vidi Vici
molex
PostPosted: 06:10 - 24 Oct 2010    Post subject: Reply with quote
First unknown the Spark Plug size
So buy the [b][u]ORDINARY[/u][/b] Spark plug Remover
Use the remover just loosen it, then use the old [b][u]OIL PIPE[/u][/b] loose out.
no need special one.
dodgydog
PostPosted: 07:41 - 24 Oct 2010    Post subject: Reply with quote
CR9-EK plugs for K2 Bandit.
16mm hex
Dog
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
Walloper
PostPosted: 08:55 - 24 Oct 2010    Post subject: Reply with quote
I never knew this until recently. Embarassed
Someone in their 'infinite' wisdom decided to use the diameter of the threaded part of spark plugs to identify the wrench size.
Most fcuking confusing.
Adam.I
PostPosted: 13:59 - 24 Oct 2010    Post subject: Reply with quote
Well I managed to find a long 16mm socket. Put that with a extension bar and got them all out. They look carbon fouled. Apparently this can happen due to fuel/air ratio mix up and a dirty air filter (which mine was awful!).
I've attached a pic so you can see what they look like. Should I replace them or just give them a good clean? Also, there is loads of rust on the 'nut' part.
Veni Vidi Vici
Bezzer
PostPosted: 15:23 - 24 Oct 2010    Post subject: Reply with quote
Replace them, looks like it was due a good service anyway with the crudded air filter as well. Do the lot - filters. plugs, oil, tappets and carb balancing then you know where you are.
The last post was made 15 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.62 - MySQL Queries: 14 - Page Size: 47.68 Kb
