indicator circuit diagram urgent !!!!
devojunior
PostPosted: 00:01 - 24 Oct 2010    Post subject: indicator circuit diagram urgent !!!! Reply with quote
I need to make a circuit to run indicators on my runner 125 on a seperate circuite i can prob make the circuit but unsure how to wire the relay in thanks adam.
PostPosted: 00:14 - 24 Oct 2010    Post subject: Reply with quote
One I did for comeone else:
https://www.bikechatforums.com/download.php?id=68933
Missing the fused, switched live into the flasher relay
devojunior
PostPosted: 11:41 - 24 Oct 2010    Post subject: Reply with quote
cheers mate shopuld do the trick but is the green circle at the top the battery ? cheers
PostPosted: 12:15 - 24 Oct 2010    Post subject: Reply with quote
No. It's the flasher repeater bulb. A circle with a cross in it is the electrical symbol for a bulb.
It doesn't show the battery. You wouldn't be attaching this directly to the battery or anyone walking past would be able to switch your indicators on even with the ignition off. There will be a wire somewhere that is normally used to connect to the flasher relay that only comes on when the ignition is on. You connect that to the other terminal of the flasher relay (not shown on diagram).
Where it says earth, you either connect this to a bare metal part of the frame or directly to the battery negative.
The last post was made 15 years, 293 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.58 - MySQL Queries: 14 - Page Size: 39.87 Kb
