More GP100 problems!
cb1rocket
PostPosted: 18:47 - 27 Oct 2010    Post subject: More GP100 problems! Reply with quote
Hi all
Finally got engine rebuilt - new piston and a rebore at +1.00 oversize. Went great for the first 20 miles then all of a sudden its running eratic and the throttle just becomes unreponsive, basically the bike just jerks all over the place with constant right hand wrist action.
It was great and was taking it easy as its been rebored for the first 20 miles now all of a sudden the bike just wants to piss me off! Evil or Very Mad
What effect is water in the fuel tank likely to cause? we have had a lot of rain of lately.....
Timing was way off when i got the bike, now I have reset that and got new points. And just to check, I did check the timing again to see if it went off its original mark but nope its ok.
I#m stumped! the first 20 miles was a great grin and smile and now everything after that is steam out of my ears!
Crying or Very sad
pits
PostPosted: 00:24 - 28 Oct 2010    Post subject: Re: More GP100 problems! Reply with quote
Things a petrol 2 stroke bike will run on
Petrol and 2 stroke oil.
Things a petrol 2 stroke bike will not run on.
Water petrol and 2 stroke oil.
As someone who owns a GP100 the only advise I can offer is to just stick it in your wheelie bin Thumbs Up
cb1rocket
PostPosted: 12:08 - 28 Oct 2010    Post subject: Reply with quote
Well my petrol tank has a massive leak so i imagine water has got inside after this horrendous weather.
Is that the effect i would expect to have if water is in the tank?
Anyway another update (same fuel and possible water contamination) the bike did a massive backfire and then died completely - have I wrecked the engine again? Loads of compression so i'm hoping the spark plug has gone duff.
Can't check now as i'm at work and i basically just abandoned the bike for a lift to work!
Evil or Very Mad
pits
PostPosted: 12:14 - 28 Oct 2010    Post subject: Reply with quote
Water and engines don't mix, you could have water contaminated fuel which it will not run on.
Drain the tank, put a new tank on and then try again
cb1rocket
PostPosted: 12:27 - 28 Oct 2010    Post subject: Reply with quote
cheers thats my next plan of action to do, oh and a new plug.
I really need to find a way to stop the tank leaking. Its leaking where the plate bracket is for bolting to the frame. What a bastard design.
Is steel epoxy putty up for this job? Can someone recommend anything else? I heard JB weld but sure its petrol proof. Could i solder and fill the gap or am i wasting my time with it?
PostPosted: 12:34 - 28 Oct 2010    Post subject: Reply with quote
Yes they do
https://en.wikipedia.org/wiki/Water_injection_(engines)
Not to mention alot modern bikes have liquid cooling.
mr rip
PostPosted: 10:21 - 30 Oct 2010    Post subject: Reply with quote
have a close look at your points & if they look a bit burnt, change your condenser,
a dodgy condenser causes erratic running, back firing, & then a complete stop as they pack up, & that sounds pretty much what's happened to yours
they're only cheap so it's no real loss if it turns out to be something else
the crank oil seal behind the stator plate is worth a look too
another thing to check but not too easy to get to is the woodruff key that times the disk valve mounting
I had mine shear off leaving the disk valve to float freely on the shaft, have a guess at how well that ran,
oh, & yes JB weld works well on tanks, I fixed a leaky steel jerry can with it & it never leaked again
never criticise a man until you've walked a mile in his shoes, then when the muck hits the fan you'll be a mile away & you'll have his shoes
cb1rocket
PostPosted: 21:55 - 30 Oct 2010    Post subject: Reply with quote
thanks for the tips, hope it not that bad! I'm on the fuel tank and water issue. checking tomorrow so should find oout then.
ignition points are and timing are all new and setup. engine been rebuilt
mr rip
PostPosted: 09:36 - 31 Oct 2010    Post subject: Reply with quote
water in the carb would be the easiest to check & fix
normaly what happens on a little single is the bike runs fine at low revs & up to half throttle but as soon as you get past half throttle the bike cuts out but revs again as soon as you close the throttle off a bit, kind of like having an on/off switch at the half throttle point, a quick blast from an air line should fix it
the condenser sends a jolt in the opposite direction when the points open, stopping the current from arking across the points
an easy way to check the condenser is to switch the ignition on & open the points manually & look for a big fat spark across the points as you open them if that happens then it's duff
cb1rocket
PostPosted: 20:23 - 31 Oct 2010    Post subject: Reply with quote
well water in the tank and carb it was then.
So cheers for help there, bike runs as it should.
The tank is still the biggest problem, i'm using epoxy steel and the putty type that goes rock hard can be filed etc but the tank still leaks! Its ok at first and sets hard but as soon as you mount it to the frame back on the bike, it starts leaking again. Problem is its leaking from the edges of the welded on mounting plate that attaches the tank to the frame. So when i tighten it, it distorts the plate and therefore the repair putty so it all leaks again Sad
I think i'm going to have to do something drastic about it.
Can i solder the edges of the bloody tiny gaps?! I would love to weld it but i'm not having it blow up in my face! Twisted Evil
cb1rocket
PostPosted: 20:48 - 31 Oct 2010    Post subject: Reply with quote
anyone with experience of tank sealer? Seems another waste of money in my eyes....
Try to get another tank if poss. It is possible to weld the tank if you can find a willing participant. Protip - leave tank to vent without tap and filler cap then purge inside with argon / Co2 while welding. Of course you may do all this then find the tank is paper thin and any attempt to weld it just makes lots of holes. C'est la vie.
............well i do weld, i just ain't great lol
anyone with experience of tank sealers?
mr rip
PostPosted: 22:01 - 31 Oct 2010    Post subject: Reply with quote
I've used fast glass resin to line tanks befor & that can work well
but the tank must be drained & vented for at least a fortnight before you try lining it or the stuff doesn't stick properly
my armstrong had a leak down by the mounting bracket & no matter what I tried it just kept breaking open again after a week or so, I think you'd probably be as well to find another tank
nisp
PostPosted: 10:40 - 01 Nov 2010    Post subject: Reply with quote
my ts had a leaky fuel tank when i got it,
theirs stuff called leak fix, it is designed for rad's, petrol tanks that sort of thing. try it 5 quid at halfords Smile
Suzuki TS 50 1999 Honda CB 125 t2 1981 Yamaha XJ 600 s Diversion Honda cx 500 MZ ETZ 250 1985 Yamaha FZR 400 1981 Suzuki TS 185 1984 Triumph bonneville 790 2001 MZ TS250 1979 Suzuki sv 650 1999 KTM exc RFS 450 2007 Hercules mx 125 1976
truslack
PostPosted: 11:47 - 01 Nov 2010    Post subject: Reply with quote
Do you want to buy a spare Armstrong tank? It comes in a rather fetching glossy camo with a union jack Laughing
mr rip
PostPosted: 12:18 - 01 Nov 2010    Post subject: Reply with quote
hi Truslak,
thanks for the offer but I sold the outfit a few months back (with a spare tank)
truslack
PostPosted: 12:19 - 01 Nov 2010    Post subject: Reply with quote
mr rip wrote:
hi Truslak,
:o How much did it go for?
mr rip
PostPosted: 12:28 - 01 Nov 2010    Post subject: Reply with quote
650 quid
I know it was probably worth more than that with the exras I'd put on it but it had got to the point where I couldn't kick it over any more & I just wanted it gone
Robby
Dirty Old Man
PostPosted: 12:32 - 01 Nov 2010    Post subject: Reply with quote
I have tried to replace a leaking (rusted) tank before now. It didn't work.
To weld it you need to sand back to bright clean metal. In doing this I found another 20 pinholes in the area. Tried MIG welding, just blew holes. Tried brazing which worked to an extent, but not well enough - every time I brazed up the holes I just found more little ones.
Just get a decent tank. May seem expensive, but you'll spend more (and also a lot of time and effort) trying to weld and then repaint the existing tank.
cb1rocket
PostPosted: 13:08 - 01 Nov 2010    Post subject: Reply with quote
I thinks thats going to be the plan - new tank from Suzuki.........
And i'll try and weld up the leaking when I have more time. Its a thick plate that is somehow welded to the tank's underside. So i might try and weld it to that edge and spread the weld over......worth a a shot.
OR
how about soldering?
The last post was made 15 years, 98 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.6 - MySQL Queries: 13 - Page Size: 115.95 Kb
