RSV 1000 R Track Bike
MarkJ
PostPosted: 10:54 - 29 Oct 2010    Post subject: RSV 1000 R Track Bike Reply with quote
As I mentioned in the Winter Projects thread, I'm going to convert my 2002 Aprilia RSVR for track duties. I bought the bike in November 2008 and loved it. After owning it for a while the riding position started to grate and i used it less. However, my love for it was rekindled when i took it on track, as it's awesome there. After those trackdays I rode it even less on the road, as the only time it was comfortable and 'fun' to ride was when I was giving it the berries, and I didn't want to lose my licence!
Here's how I bought it:
https://i47.photobucket.com/albums/f186/markjackson13/n660357060_1551843_2894.jpg
https://i47.photobucket.com/albums/f186/markjackson13/n660357060_1551841_2380.jpg
I purchased some track fairings but the rear seat unit never fit over the numberplate bracket on the undertray and the double seat subframe.
Cadwell 2009:
https://i47.photobucket.com/albums/f186/markjackson13/6408_111070147060_660357060_2730823_1955418_n.jpg
NEW for 2010! BLACK GAFFER TAPE! (Donington)
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1019.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1034.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1038.jpg
Cadwell 2010:
https://i47.photobucket.com/albums/f186/markjackson13/l55.jpg
I enjoy this bike so much on track i figured I'd just put the track fairings on and give it a good spruce up, as I used it on the roads once this year Laughing I already bought a spare single seat subframe (so the tail piece can fit over), undertray and petrol tank. I need to do the following:
Replace double seat subframe with single seat subframe
Chop the numberplate brackets off the spare undertray and fit to single seat subframe
Buy some front fairing and wheel spindle crash bungs
Repair all the fairings (some have big splits in them and have cracked the paintwork)
Paint orange Mr. Green
Give it a service - valves need checking, oil & coolant change etc.
Then give it a bit of a tidy - clean the engine and replace some rusty clips.
Now, I actually started this a couple of weeks ago but never got around to posting this thread. I also filled up a memory card (only 64mb) and took a few pics of me fitting the new subframe on the camera's internal memory, but I now can't find the cable for it! I'll try and dig the cable out at the weekend and edit this post with pics of the subframe fitting.
So...
I took the rear plastics off the double seat unit
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1042.jpg
Took the ECU box and battery out
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1043.jpg
You have probably noticed I have an alarm on the bike. I was going to chop it out, but then thought that i don't mind it having an alarm really. I'll keep it but will pack the area it sits in with foam for when it's at a trackday - I put it into service mode at trackdays so if I fall off and a marshal turns it off by the key the alarm won't arm.
Double seat subframe out!
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1051.jpg
You can also see I removed the rear hugger. This actually took 3 hours to get the four bolts out as they'd all seized into the swing arm Sad Had to impact driver two of them out by cutting a slot in them, and got one out by hammering a torx head into it:
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1052.jpg
**** New pictures
I put the undertray in the new subframe, but the seat unit doesn't go on because it can't get past the numberplate brackets:
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1062.jpg
So I chopped 'em off!
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1064.jpg
The undertray then fits in the seat unit
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1065.jpg
Undertray is a bit grotty, so may give it all a sanding to see if it'll get rid of the crap. hopefully the burn mark is just on the surface.
View from the top
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1066.jpg
Comparison of double and single seat units:
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1063.jpg
**** End of new pictures
I tried to mount the reg/rec with cable ties but it stopped me being able to put the seat unit on. I ended up screwing it to the side of the subframe with just one bolt.
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1056.jpg
Then I fitted the seat unit!
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1053.jpg
Underneath. Can just about make out where I chopped the numberplate brackets off.
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1054.jpg
Unfortunately there are a few cracks like this one:
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1055.jpg
So I set about with the fibreglass repair kit. Before:
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1059.jpg
After:
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1060.jpg
And finally, a picture of the spare tank I have.
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1061.jpg
The fuel pump inside it works (tested it last night) which is good.
Had to get the lock picked on it Very Happy It's a plastic tank. Has anyone ever sprayed a tank like this before? Would I need a plasticiser?
That's currently where I'm at. Hopefully in the next few days I'm going to sand and body filler the seat unit. I'll also wheel the bike out and take some better pics of it.
MarkJ
PostPosted: 10:37 - 03 Nov 2010    Post subject: Reply with quote
New pictures added (managed to get the undertray ones off the camera). The start and end of them is marked out in bold in the above post. Also the seat unit is pretty much repaired, just need to sand a few body filler'd parts then I'll have pics of that too.
L4Isoside
PostPosted: 10:55 - 03 Nov 2010    Post subject: Reply with quote
Nice one.
I maybe on the look out for a trackbike next year, but converting one your self looks like a lot of fun as well!
MarkJ
PostPosted: 12:10 - 03 Nov 2010    Post subject: Reply with quote
Yeah I do enjoy tinkering with track bikes it seems. Making one out of a road bike definitely isn't a cheap way to get a track bike though. The reason i've done it with my RSV is that they can be had cheap (for what they are) now, and for the sake of saving a few hundred quid I can have a bike where I know it's mechanically sound.
L4Isoside
PostPosted: 13:13 - 03 Nov 2010    Post subject: Reply with quote
Yeah that is someting I was wondering about as well, cheap track bike that may have little history or a more expensive road bike but with better history and you know it wont have been as thrashed to death.
Older CBR track bikes to go cheap on ebay though....
MarkJ
PostPosted: 11:06 - 08 Nov 2010    Post subject: Reply with quote
Seat unit is pretty much sorted now, just need to drill a mounting hole in where I filled it in. The seat unit was in the worst shape of all the fairings so hopefully should have everything repaired soon ready for painting.
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1085640x480.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1086640x480.jpg
Went from (nearly) fully faired:
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1069640x480.jpg
To not:
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1079640x480.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1080640x480.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1081640x480.jpg
Bits that need fixing...
Nose cone. The side that surrounds the clutch lever is pretty thin and has cracked with the stress of the wind:
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1071640x480.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1082640x480.jpg
Bit of a gouge at the top mounting point too:
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1070640x480.jpg
Belly pan. There are some flimsy parts at the back which aren't strong enough, so wobble and crack the paint. these just need strengthening.
Exhaust side:
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1074640x480.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1073640x480.jpg
Chain guard:
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1072640x480.jpg
The ram air ducts are in pretty bad shape too with big cracks in both of them, and a hole on the LHS one.
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1076640x480.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1077640x480.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1075640x480.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1083640x480.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1084640x480.jpg
And finally, some of the DZUS fastners on the fairings don't fit tightly, so undo themselves unless they are gaffer taped on:
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1078640x480.jpg
Will probably just stick a bit of foam/sealant/bodyfiller behind the fairing to widen the gap making the bolts fit tightly.
Last night I strengthened the bellypan:
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1098640x480.jpg
And strengthened the nose cone:
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1097640x480.jpg
MarkJ
PostPosted: 00:43 - 15 Nov 2010    Post subject: Reply with quote
Bought some R&G bungs the other day, fitted them tonight.
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1099.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1100.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1101.jpg
Fairings were already cut for crash bungs so this was a nice quick job. Should hopefully be finishing off the bodywork this week.
Syris the Indomitable This post is not being displayed because it has a low rating (Off Topic). Unhide this post / all posts.
AngelGrinder
PostPosted: 23:49 - 20 Mar 2011    Post subject: Reply with quote
Update this now Wink
Your track fairings seems better in some ways than mine, and worse in others. My belly pan still allows me to screw it into the plastic guard around the back of the exhaust, making it a little stronger.
The rear seat unit on mine is all one peice, with foam seat, but doesn't have as nice a shape as yours, and makes the seat alittle higher, but fits over the numberplate bracket no problem. Although it also has been made a bit weak and tatty from the stretching to get the damn thing over the subframe, especially with the alarm on one side of the subframe aswell. And your fairings also seem to include parts for the air ducts, whereas I have had to keep my standard ones Sad
Nice little project though, let me know how she goes!
MarkJ
PostPosted: 00:31 - 21 Mar 2011    Post subject: Reply with quote
This was going to get updated Wednesday-ish Very Happy
I "finished" (got them to an OK standard then got fed up with them) preparing the fairings, bought the paint and then made a right cock up of spraying the primer. It came out all watery, but was still thick inside the gun and clogged it all up. They're currently at the painters now and should be done on Tuesday hopefully, will post some pics then.
The air ducts are just another set of standard air ducts, definitely not race items. I'd actually forgotten how bad a condition these were in until I looked at these pics - they're not perfect now, but at least look presentable Very Happy
DrDonnyBrago
PostPosted: 14:31 - 24 Mar 2011    Post subject: Reply with quote
Are all the cracks, damage, scratches and what not on the track fairings from crashes or just from wear and tear (wind, vibration etc) on a bike high speed?
MarkJ
PostPosted: 15:17 - 24 Mar 2011    Post subject: Reply with quote
Everything except the air ducts is just from wind pressure and vibration. The glass fibre was quite thin in a few places and obviously the stress of it moving made it crack. The air ducts however seem to have been on a bike that's been crashed due to the damage. After I sanded them down you could see that this fairing kit had been made up from different pieces.
It's made up of:
One green side panel
One blue side panel
An orange nose cone and belly pan
A green tail unit
One silver air duct
One black air duct
One black petrol tank (which I bought)
Painters haven't phoned me yet so I'll give them a ring if I get a spare minute at work today.
steven_191
PostPosted: 18:32 - 24 Mar 2011    Post subject: Reply with quote
you might need to be careful if your strengthening stuff with fibreglass.
i have some mito race fairings and they weigh twice as much as the standard ones. completely pointless.
MarkJ
PostPosted: 18:42 - 24 Mar 2011    Post subject: Reply with quote
It's made no difference, they're still half the weight of the standard plastics. The point of these is so I don't mess up road fairings anyway, not weight.
Painters called me an hour ago to say they're painted Thumbs Up
Pussy Magnet
PostPosted: 19:07 - 24 Mar 2011    Post subject: Reply with quote
He has a very valid point most " yes " most race fairing these day weight more than the standard fairing theres not much point in paying good hard earned money for something twice as heavy :L
Nice project though lovely bike worth the time and effort Smile
MarkJ
PostPosted: 02:24 - 27 Mar 2011    Post subject: Reply with quote
Right, I very roughly put everything on today, going to screw everything together properly together tomorrow.
Ready for painting:
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1163640x480.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1164640x480.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1165640x480.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1166640x480.jpg
And back from the painters:
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1167640x480.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1170640x480.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1169640x480.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1168640x480.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1173640x480.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1172640x480.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1171640x480.jpg
Shiny Mr. Green I know orange isn't to everyone's taste but I like it. The painters did a really good job and at least I won't be one of the many black or red bikes in the trackday pictures Very Happy
Shreddie
PostPosted: 02:56 - 27 Mar 2011    Post subject: Reply with quote
I hate orange... But it looks kinda tidy as an orange/white combo!
Nice work!
AngelGrinder
PostPosted: 09:26 - 30 Mar 2011    Post subject: Reply with quote
Looks good, that paint looks really smooth...must have taken forever to get it prepped that well! Liking it Thumbs Up
Gazdaman
I did a trackday!!!
PostPosted: 10:07 - 30 Mar 2011    Post subject: Reply with quote
I love it, looks awesome.
Gaz
AL-
PostPosted: 11:10 - 31 Mar 2011    Post subject: Reply with quote
Gaz
Agreed Cool
MarkJ
PostPosted: 23:30 - 07 Apr 2011    Post subject: Reply with quote
Thanks for the kind words Thumbs Up
I seem to be going backwards now Laughing
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1174640x480.jpg
The suspension linkage bearings on the bottom of the swingarm had seized (common problem with RSVs) and if left like this for a while can eventually disintegrate and sometimes snap the linkage plate, so I took the swingarm off and took it to my local bike shop for the new bearings pressing in.
The shock is quite awkward to clean as the swingarm is quite tall so now was a good opportunity to clean the whole area.
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1175640x480.jpg
20 minutes of scrubbing with a rag and white spirit later:
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1176640x480.jpg
https://i47.photobucket.com/albums/f186/markjackson13/DSCF1177640x480.jpg
Picking swingarm up tomorrow, fitting that and the fairings & tank properly at the weekend then should be all finished Thumbs Up
Stav
PostPosted: 13:52 - 08 Apr 2011    Post subject: Reply with quote
Absolutely cracking! Love it! Orange/white combo looks really cool! Thumbs Up
Present> 03 Tuono RSV1000 - Past > 02 Honda NSR125RR > 02 Triumph TT600
Cage> 03 Audi TT
The last post was made 15 years, 181 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 130.76 Kb
