| Oz. |
 Oz. Spanner Monkey
| L4Isoside |
 L4Isoside World Chat Champion
| HD |
 HD World Chat Champion
| G |
 G The Voice of Reason
| flumpy7 |
 flumpy7 Could Be A Chat Bot
| Blue_SV650S |
 Blue_SV650S World Chat Champion
 Posted: 11:02 - 01 Nov 2010 Post subject: |
Quite often there can be a little bubble of air right up by the M/C, regardless of how often you try bleeding the brakes, it won't clear.
Two good ways to resolve this:-
1. Reverse bleed - use a syringe full of brake fluid, put some pipe on the bleed nipple, loosen the nipple and push the syringe. This will force fluid UP the system, so the air will be going in a more natural direction and 'vent' in the M/C
2. 'Crack off' the M/C banjo - It is the banjo area these bubbles can form, so pull the leaver in, with pressure on the leaver still, loosen off the M/C banjo, let the leaver pull all the way back and then quickly re-tighten the banjo before letting the leaver back out. This might do the trick first time, if it doesn't then repeat say twice more, if it still isn't any better, then that is not your problem!
Next train of thought - is there lots of leaver travel when stationary (after pumping up) or just on the move?
Either way, suspect warped disc, if it is on the move, it will be warped radially, if it stationary it will be side profile.
Both are easy to check for.
Rotation:- get the front wheel off the ground and spin the wheel, holding a pencil on the fork, pointing to the disc, move it in closer and closer until it touches the disc. If it 'pulses' to any degree, the disk is warped.
Side profile:- When you squeeze the leaver (and then pads close), does the disk 'flex' in the calliper?
Final thought, when looking at the calliper and applying the brakes, how much do the pistons/pads move? If they move a fair ways (and it is not warped disc) then I suspect you are needing to do a calliper overhaul as they are sticking!
hummmm .... Is this post over 200 words?!!?  ____________________ The purpose of life is to fight maturity. |
| Oz. |
 Oz. Spanner Monkey
The last post was made 15 years, 358 days ago. Instead of replying here, would creating a new thread be more useful? |
