| skithepowder |
 skithepowder Borekit Bruiser
 Posted: 12:59 - 02 Nov 2010 Post subject: Getting the bung part of crash bungs off? |
Hi I have R + G crash bungs on my 2003 SV 650. I dropped it last week and bent the left hand bung. I'm replacing them with some Motosliders bungs in the next 2-3 weeks. In the meantime I want to take the R+G bungs off as it looks a little bit shit with a bent left bung.
I didn't fit the bungs myself so I don't know how exactly they fit. I'm aware that there is a bolt that goes through the frame and right through the engine to the other side. I'm also aware that I shouldn't remove this bolt so there is nothing left there and ride around. So because I didn't fit them and don't have the original bolt I need to leave this bolt in.
So I essentially just want to take the external rubber bungs off. How hard is this to do? I'm only just building up my tool collection, will I need a torgue wrench to do this?
Can anyone tell me which bolts I need to be playing with to just take the rubber bungs off and leave the main bolt asssembly through the engine for the time being? I've attached a photo of them below
https://img243.imageshack.us/img243/3738/photoxs.jpg
Uploaded with ImageShack.us
I've labelled the 3 bolts A, B, and C on the damaged side. B is down the tube of the bung so I'm not quite sure how I'd actually get to that one? But any help over what to leave and what to undo to get the actual rubber bungs off would be much appreciated!
Thankyou![/img] |
| Alex A |
 Alex A World Chat Champion
| stonesie |
 stonesie World Chat Champion
| skithepowder |
| Walloper |
 Walloper Super Spammer
 Posted: 13:34 - 02 Nov 2010 Post subject: |
1st thing. You twit! For dropping it.
(I dropped mine in a petrol station whilst checking the tyres pressures. )
The bung can be cut off the bolt but you would then have a big thing sticking out which would be a definite tug and fine under Road Traffic Law : Construction and Use. They will then be able to remove your trousers and have a root around up there too.
Looking at the pic it looks like you could simply grip the outer plastic bung and unscrew from the mounting bracket. I am guessing the mounting bracket has a 10mm threaded hole which the bung bolt screws into.
If that is the case then simply remove the bung as said.
You don't need a torque wrench to remove things. (Normally) Normally you need a torque wrench during assembly.
For fitting bungs or anything to a stressed member then a torque wrench should be used Though there are a load of folk on here who 'know better'. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| jay12329 |
 jay12329 Dr. Evil
| stonesie |
| skithepowder |
| Alex A |
The last post was made 15 years, 356 days ago. Instead of replying here, would creating a new thread be more useful? |
