| map |
 map Mr Calendar
 Posted: 16:44 - 18 Nov 2010 Post subject: CG magneto/timing slipping |
Following on from my earlier thread on this (info click here) the problem has come back.
Despite my (and others) best efforts the magneto cover appears to slip (the nut gets loose).
This knackers the woodruff key and takes the timing out.
So, any help on how to sort this short of a new engine/engine rebuild would be appreciated.
Already tried to make sure nut tight with impact driver and did use threadlock on it.
Also attached pics of the last fix.
https://www.bikechatforums.com/download.php?id=75884
and
https://www.bikechatforums.com/download.php?id=75883 ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| N cee thirty |
 N cee thirty Banned
| map |
 map Mr Calendar
| satans_BIG_helper |
 satans_BIG_helper Nearly there...
| N cee thirty |
 N cee thirty Banned
| finpos |
 finpos World Chat Champion
| map |
 map Mr Calendar
| N cee thirty |
 N cee thirty Banned
 Posted: 22:07 - 18 Nov 2010 Post subject: |
i'll take a pic tommorow  ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
Jewlio Iglesias wrote: I actually did vote BNP once |
| stinkwheel |
 Posted: 22:54 - 18 Nov 2010 Post subject: |
Did you thoroughly degrease the taper before fitting?
I wonder if it's totally spun-up at some point and knackered the facings on the flywheel taper (the crank taper is usually hard as fuck). Trouble is, as you point out, you haven't got a hell of a lot of clearance left to re-dress it.
As finpos has pointed out, green bearing fit compound would hold it BUT I wouldn't rate your chances of ever removing it again. The stuff I have quotes a torsional grip force of 21ft/lb, and that's on a slightly loose fitting bearing race. I shudder to think how much force it would take to pull it straight off.
You can lock-up the engine to tighten it by putting the piston to BDC, stuffing a load of washing line in through the sparkplug hole then turning the engine.
Flywheel nut should be tightened to somewhere in the region of 25ft/lb.
This is a C90 one done up finger tight:
https://i48.photobucket.com/albums/f216/stinkwheel/DSCN1001.jpg
EDIT: Your stator plate looks weird. Obviously I can't see it all but on your second picture it looks like there is a piece of alloy plate with one edge cut off straight sticking out from behind the flywheel Should that be there, what's it doing? The stator plate normally looks like this:
https://www.electrexworld.co.uk/images/Stators/300x200/white-back/ST1102.jpg ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| map |
 map Mr Calendar
| finpos |
The last post was made 15 years, 83 days ago. Instead of replying here, would creating a new thread be more useful? |
