Kickstart |
Kickstart The Oracle
Posted: 17:07 - 04 Dec 2003 Post subject: |
I suspect the split exhaust port makes the NSR a tad less prone to cold seizures and gives the rings an easier life. However the first of those is fixed by not thrashing it from cold and the second by changing the rings when required.
The Mito engine is basically quite tough if correctly assembled. The only real problem is getting the sare parts through.
The other problem is that the RS and Mito are more adjustable as standard (ie, ignition timing on the Mito and older RS, power valve on the Mito, compression ratio on both of them) which makes it far easier for someone to cock up an engine rebuild.
I really don't think that a properly maintained and looked after RS is any worse than an NSR that is properly maintained and looked after. However it may well cost more to maintain the RS, but then it does produce around 15% more power as standard.
NSR125-Kid-UK |
NSR125-Kid-UK Attention Whore
Posted: 17:19 - 04 Dec 2003 Post subject: |
All I'm after is a nice easy going 125 that looks good and has NSR written on it . I suspect it being a two stroke will complicate things (more maintenance - i need to look at the mechanical pages on nsr125.com), so i could do without the extra hassle . ____________________ https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman |
The BeefMeister |
The BeefMeister Crazy Courier
NSR125-Kid-UK |
Posted: 17:27 - 04 Dec 2003 Post subject: |
You weren't reading Two Wheels Only were you?
I'm not sure about the manufacturing, because NSR's are made in Italy as well. Probably just the design philosophy i.e. more power at the expense of reliability. ____________________ https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
Scotty |
Scotty Scooter Boi
The BeefMeister |
Posted: 17:34 - 04 Dec 2003 Post subject: |
Erm...Yeah it was Two Wheels Only.
I haven't got a clue where the NSR was built. If it was in Italy then it can't be that. It's probably like you lot say the build quality. ____________________ "Put your hands up motherstickers, this is a f*ck up!" |
NSR125-Kid-UK |
Posted: 17:36 - 04 Dec 2003 Post subject: |
I raced an RS50 and lost
I was on a crappy restricted scoot at the time though lol.
He can wait till i get my NSR and i'll beast him . ____________________ https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
Scotty |
Scotty Scooter Boi
The BeefMeister |
Posted: 17:43 - 04 Dec 2003 Post subject: |
The RS50 stated must be derestriced if its at 12bhp. Hard to believe but standard it wouldnt be doing 65mph.
When I bought mine it was already derestriced and did 65mph and thought it was putting out about 9bhp. Most standard peds put out something like 3-5bhp. Might not sound a lot but a lot of 50's can shift!
That was 2003 model that was listed with all the stats. Mine is a 2000 model. ____________________ "Put your hands up motherstickers, this is a f*ck up!" |
Scotty |
Scotty Scooter Boi
Kickstart |
Posted: 17:49 - 04 Dec 2003 Post subject: |
The NSR was designed and originall built in Italy (although they moved production to Spain). On the early bikes the lights (CEV), carb (Dellorto), suspension (Marzocchi) and brakes (Grimeca) at least are Italian. Suspect most of the rest of the bike was made in Italy anyway (frame, wiring, switchgead, seat, etc). Think the ignition system is Japanese, but then so is the oned used on the Mito and the RS (or at least those fitted with the Rotax 122 engine).
From memory with the old NS125 the only bits that were not built in Italy were the engine and the wiring loom.
I suspect someone is being a bit hopeful claiming 12hp for the RS50. Maybe it is at the crank, but then the NSR is probably rather more at the crank. The RS makes around 28.5hp at the rear wheel on a dyno (original RS125 road test in PB), although the newer ones are probably slower as the exhausts now have more restrictions (eg, catalytic converter) and the carbs are smaller.
Kickstart |
The BeefMeister |
NSR125-Kid-UK |
Posted: 17:57 - 04 Dec 2003 Post subject: |
I'll stick to the tried + trusted 2001's . Less money isn't it . ____________________ https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
McJamweasel |
McJamweasel BCF Junkie
Scotty |
Scotty Scooter Boi
The BeefMeister |
Scotty |
Scotty Scooter Boi
Kickstart |
cagiva gezzer |
cagiva gezzer World Chat Champion
Kickstart |
Posted: 20:08 - 04 Dec 2003 Post subject: |
Claimed dry weight of an RS is 115kg accoding to the owners handbook, while the Mito is 125kg (ish) according to the workshop manual depending on the model.
I have never seen an official claim from Aprilia of 33hp. They all gave up claiming peak power figures about 13 years ago after Gilera caused a public outcry releasing the 107mph SP01 (which could be ridden by a 16 year old in Italy). The makers stopped claiming top speed and power figures and the magazines stopped testing them for top speed and power.
cagiva gezzer |
Kickstart |
NSR125-Kid-UK |
Posted: 13:27 - 05 Dec 2003 Post subject: |
The 2003 RS50/125 Is a beautiful machine. Basically it's been made up to look like a baby RSV-R. Picture can be found below.
Yes i'd love one of these babies, they're gorgeous, but I still think the NSR paintwork is better , and besides, not only have i made my decision () but I wouldn't spend £3300 on a new RS125 (Now that i come to think about it)... ____________________ https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
The last post was made 20 years, 149 days ago. Instead of replying here, would creating a new thread be more useful? |
