| Author |
| kingsknight |
 kingsknight World Chat Champion
| Back to top |
| cb1rocket |
 cb1rocket World Chat Champion
| Back to top |
| kingsknight |
| Back to top |
| truslack |
 truslack World Chat Champion
| Back to top |
| kingsknight |
| Back to top |
| truslack |
| Back to top |
| cb1rocket |
| Back to top |
| herulach |
 herulach World Chat Champion
| Back to top |
| cb1rocket |
| Back to top |
| Kickstart |
 Kickstart The Oracle
 Posted: 18:23 - 10 Dec 2010 Post subject: |
That sounds pretty hideous. Not sure on the RS (never measured it) but it's not bad on oil (old early AF1 was great on oil, and had a 1.8 litre oil tank). The manual lists the oil mix as between 0.9% and 2%.
I would also expect way more than 40mpg. When I measured and recorded mine it averaged about 55mpg over quite a few thousand miles, but that is mainly when used out of town (but a fair bit of flat out riding). Ridden with great care during the fuel strikes it managed 74.5mpg (but it really was horrible to ride like that).
| Back to top |
| truslack |
| Back to top |
| Kickstart |
| Back to top |
| truslack |
 Posted: 19:13 - 10 Dec 2010 Post subject: |
I run my H100 at 20ish:1 ____________________ Current: Suzuki RG 125 Gamma, Honda H100, Triumph Tiger 800XC, Suzuki SV650 (minitwin) |
| Back to top |
| Kickstart |
 Posted: 19:24 - 10 Dec 2010 Post subject: |
Wouldn't expect it to need anything like that rich a mix of 2 squeak oil.
Honda manual says to use between 25:1 and 50:1 premix to run the engine when bleeding the oil pump. At 1300rpm idle speed the oil pump gives a maximum of 0.364cc per minute. Assuming that the amount rises directly in relation to rpm then that is 134cc an hour at 8000rpm. Assume 90mpg on petrol at 8k and 60mph (not exact but close enough) and that is 3 litres of fuel used in an hour. Based on that the Honda pump gives 22:1 at the very most (shut the throttle and the oil delivery drops by about 80%).
| Back to top |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 19:25 - 10 Dec 2010 Post subject: |
for 'pre-mix' the rough reckoner was that low-tuned motors like strimmers or lawn-mowers would run a thicker mix, down around 25:1 or lower, becouse they dont suck fuel in so fast, you need to put more oil in it so that the bearings get enough lube.
On higher perfromance engines, they are using a lot more petrol, so they dont need as much oil in it, and thinner mixes up in the region of around 50:1 or thinner are more common.
35:1 is a rough-reckoner starting point for a 'typical' air-cooled road-going two-stroke, like a YB100.
Auto-lube is a different matter, and can get complicated. Pump meters the oil into the engine, but there's a meter-valve worked by the throttle cable.
Often this actually DECREASES oil-flow, rather than increases it.
Pump delivers measured volume of oil per revolution, and geared to the crank, that means so much per rev or cycle.
And the throttle adjustment will lean off the oil-feed as loads increase, to compensate for the fact that the pump is probably geared to over-oil at low revs when there's little flow through the crank-cases to wash lube into bearings.
Ie, giving the thicker effective mix of a low-speed engine an part throttle and lower speeds, the thiner mix a higher output engine needs at higher rpm.
So..... if the cable has never been adjusted and has gone slack...... likely its not leaning off the oil feed as much for wider throttle openings....... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Back to top |
| Kickstart |
 Posted: 19:32 - 10 Dec 2010 Post subject: |
Not sure on leaning off the oil (although might) but likely not richening it up at anything like the rate the fuel supply increases as the throttle is opened wide.
The Honda H100 workshop manual unusually has a graph of oil supply to control lever angle (ie, the lever on the pump) at 1300rpm. With the lever angle of zero it passes 0.065~0.073cc per minute. This increases at a constant rate up to 0.338~0.364cc per minute at 39 degrees of control lever angle. After that the amount doesn't increase any more.
| Back to top |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 19:39 - 10 Dec 2010 Post subject: |
| Kickstart wrote: | Hi
Keith |
Essance was "Service your bike - Check the auto-lube cable adjustment"
Have to confess, that I got COMPLETELY bamboozled by the intricacies of auto-lube many years ago, while setting up the super-tuned 50 I'd built for a laugh, the conclusion of which was simply to rip it off and go 'pre-mix'!
Dealt with a couple, and I think it was the Kawasaki AR, where the auto-lube had an eccentric cam, and did wiered things to the metering, demanding flow-rate measurements at different openings to adjust it 'properly'.... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Back to top |
| truslack |
| Back to top |
| Kickstart |
| Back to top |
| Cheeseybeaner |
 Cheeseybeaner World Chat Champion
| Back to top |
| HD |
 HD World Chat Champion
 Posted: 19:57 - 10 Dec 2010 Post subject: |
Err.
My bike is very oily so I slackened off the cable a bit. Would it be better to actually tighten it then?
EDIT: I didnt actually slacken it I more pulled it out more so there was less cable actually pulling so I sort of did if you get me  ____________________ Rusty '02 Vito Camper + CBR600F3 |
| Back to top |
| Cheeseybeaner |
| Back to top |
| cagiva gezzer |
 cagiva gezzer World Chat Champion
| Back to top |
The last post was made 15 years, 310 days ago. Instead of replying here, would creating a new thread be more useful? |
