MillaMeter |
MillaMeter Nova Slayer
fiery tupp |
fiery tupp Trackday Trickster
Posted: 21:12 - 19 Dec 2010 Post subject: Re: YBR125 55 plate with rev counter issues |
I'm guessing the tickover is 1500rpm.
Between 1300-1500 rpm
I don't know about your clock problem though ____________________ If you can't fix it with a hammer , use your head . |
craigT19 |
craigT19 Jolly Green Giant
Posted: 22:40 - 19 Dec 2010 Post subject: |
What generation ybr is it pls?
Mark 1: has carb
Mark2: has injection
Mark3: has side coveres on the tank.
Cheers. ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003 |
herulach |
herulach World Chat Champion
MillaMeter |
craigT19 |
Posted: 20:52 - 20 Dec 2010 Post subject: |
Erm yes, its a massive difference, i had to be sure because the flicking to 2k rpm means the air temp sensor isnt working, and i didnt want to simply tell you to change it as the air temp sensor is combines with the air pressure sensor, engine temp sensor and is built into the throttle body.. A new one is about £300.
As u have fitted the clocks from the injected bike onto the bike with a carb its trying to find sensors which dont exist so theres your problem, the newer ybrs also use a different method to mesure the rpm so i would bet your getting incorrect rpm readings. ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
The last post was made 13 years, 123 days ago. Instead of replying here, would creating a new thread be more useful? |
