| lihp |
 lihp World Chat Champion
 Posted: 16:09 - 08 Jan 2011 Post subject: 2002 R6 Misfire |
Ok guys, my R6 developed a misfire at idle, and it has gradually got worse to where it's a very rough ride.
I'm part way through stripping the bike to get the carbs off, however, while there I am checking for a spark, coils resistance is ok, but when checking for spark by holding plug against an earth, I had a spark on 1 and 2, then #3 coil on #3wire wouldn't fire, moved #3 coil to #2 wire and still no spark, now there's no spark on anything.
After a short while I did #1 coil back on #1 wire, and spark came back, but then has now gone again.
Any ideas?? |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
| lihp |
 Posted: 19:14 - 08 Jan 2011 Post subject: |
The R6 has 4 coilpacks which are integrated into the HT lead, so no seperate leads either.
The spark goes and comes back quite intermittently, The bike does start, but has a rough idle and very poor performance till about 6k, and hesitates at quick throttle changes.
As the bike has a datatool alarm/immobiliser, I decided to check the wiring, and noticed that while it was plugged into my battery charger (oxford optimate) that when I moved a connector the top green battery condition light flickered on and off.
This connector, is triangular in shape and has 3 wires, white blue and something else, but may be different it was a few hours ago since I checked before work lol.
I am going to check this further, and test for spark again while wiggling this connector to see if it has any affect on it.
Finally, Is it ok to keep letting fuel pump prime and run with no fuel in (tank is off), or am I better pulling the fuse for it, so I don't dry run it all the time?
Also while taking airbox off, I noticed the inside of the airbox near cylinder 1 (left hand side) that it was quite damp with fuel. The carbs do need cleaning and balancing, however I need to discover what this loose wire affects and the issue with the spark. |
| 0l0dom0l0 |
| lihp |
| 0l0dom0l0 |
| craigT19 |
 craigT19 Jolly Green Giant
 Posted: 21:34 - 08 Jan 2011 Post subject: |
Its farely unlikely to be a tps problem, on the old carb models the tps isnt particularly complicated and doesnt have anything to do with fuel metering, the basically a control unit for the electronic ignition providing the ecu with info on throttle movement to optimise the ignition timing, at idle the tps isnt active
Sounds like you may have some shit in one of your carbs, a blocked jet a needle jet from what you have said. ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003 |
| craigT19 |
 Posted: 21:36 - 08 Jan 2011 Post subject: |
Oh and the petrol in the air box has probably come from the crank cases, of the bikes been stop for a while chances are some petrol has drained past the piston rings into the crankcases, its fairly comon and the petrol evaporates comes out the crank case breaver into the back of the air box where it condensates and leaves a petrol resedue ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
| lihp |
| craigT19 |
 Posted: 22:48 - 08 Jan 2011 Post subject: |
I wouldnt worry if the fuel did get past the rings it will only be a very small amount as it was what was in the barrel.
For the charger....who knows there somewhat of a mystery to me, ive found my optimate will ofter say full charge... yet if i wiggle the connector that attaches it to my battery it will swicth back to charging again.  ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
| 0l0dom0l0 |
| lihp |
| lihp |
| lihp |
| gray84 |
 gray84 World Chat Champion
| lihp |
 Posted: 18:25 - 09 Jan 2011 Post subject: |
I'm in Warrington, Cheshire, what about you?
In this PDF
https://www.yzfr6.net/manual/r6_manual_electric.pdf
page 8-15
It's test 12 that I found it on.
The test for "continuity" actually reads around 760ohms, but to me continuity should be nearly zero.
I assume this can stop a spark, as that's the troubleshooting procedure for no spark, or intermittent spark. |
| gray84 |
| lihp |
| gray84 |
| 0l0dom0l0 |
| craigT19 |
 Posted: 21:41 - 09 Jan 2011 Post subject: |
continuity wouldnt read 0, continuity simply means there is a complete curcuit, and if there is a curcuit there will be some resistance.
Your getting lost in the workshop manuals troubleshooting.
Your looking at your starter relay when your problem isnt starting the bike...its the way it runs.
The starter relay simply bridges your battery directly to your starter motor to give it mazimum amps for the starting cycle, once the start button is released the relay becomes a bridge for the battery to the rest of the electrics.
As said above from what you have said with your bike running poorly at idle but ok when the revs pick up points to a few things.
If i was working on your bike this is probably what i would look at.
1. Shit in one of the carbs would be my first stop probbably a blocked needle valve.
2. More serious is the possibility of a cracked valve head, poor valve seat. This could cause the problems your getting because at low rpm your loosing compression from one cylinder before it ignites properly but this becomes less obvious at higher rpm as the compressed fuel air mix has less time to seep out.
The second is extreme but is possible i had it happen on my zx6r
Start simple.. you know the bike runs.. you know the carbs are getting fuel, run the bike at idle and quickly touch each of the header pipes (or spray summin on them) if one of the 4 is running poorly it will be noticably coolder than the others.
Once u got your cylinder you know that theres a problem between the fuel going into the carb...and getting burnt in the engine.
So remove the carbs and check there clean and in good order. If thats all good get a compression check done.... poor compression? bad ring or valve XD ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
| craigT19 |
 Posted: 21:46 - 09 Jan 2011 Post subject: |
It wont be this, this is called the multi function relay and controlls all kinds of things, including fuel pump pressure shutoff... if this was faulty the bike wouldnt start full stop. ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
| lihp |
 Posted: 01:25 - 10 Jan 2011 Post subject: |
Apologies if my initial post was difficult to follow, it was posted in a rush.
There are actually 2 seperate issues, that I don't think are related.
1. Poor idle, sounds like misfire, this I believe is dirty carbs due to being stood.
2. No spark on any cylinder, but had one a few days ago.
While following the Yamaha tests, everything tests fine, until that relay, Which although I am not entirely sure of it's purpose, it must have control of the spark for Yamaha to include it in their test procedures?
I am an Electrician so understand that 760ohms is still a circuit, but for something that states should have continuity I believe should be a lot lower than that, for a specification where 760ohms was correct I'd expect to see a range of resistance, such as when doing tests on coils etc.
This is why I am looking for somebody with another one, to do the same test as what's on the PDF, if it's the same or very similar it's not the issue, but if it reads a very low resistance, then this I believe is a likely cause.l |
| craigT19 |
 Posted: 09:51 - 10 Jan 2011 Post subject: |
oh right i see, if if was a never bike i would say you have an imobiliser issue, do u have an alarm and if so what one? if i can remember ill send you a private message on how to temporaraly bypass your alarm without actually removing it. ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
| lihp |
The last post was made 15 years, 258 days ago. Instead of replying here, would creating a new thread be more useful? |
