Derbi senda Gearbox/engine/drive Problems.!
LJColeman
PostPosted: 15:17 - 08 Jan 2011    Post subject: Derbi senda Gearbox/engine/drive Problems.! Reply with quote
Ive got a Derbi Senda X-Race 2009 sm, Its been running fine, its got a gianelli pipe, 14t f sprocket, blah blah,
But Last saturday and today i was out for a blast and i was in 5th gear about 9000 rpm and suddenly the back will locked up and the engine sort of died, i kept it under controll and when i pulled over, i put it into nutrual and it started straight away and was fine!!
it has only ever done it twice and only in that gear at high rpm!!
Any ideas guys?
Derbi Senda extreme Smile
Old Git Racing
PostPosted: 17:01 - 08 Jan 2011    Post subject: Reply with quote
Sounds like it has seized the piston then freed off. Is it running hot? has it been jetted for the pipe? Running the correct oil mix with good quality oil?
Best sort it out cos repeated seizures will kill it eventually and one day it might lock up on a corner and either chuck you into the roadside scenery or into oncoming traffic and kill you.
OGR
fiery tupp
PostPosted: 17:02 - 08 Jan 2011    Post subject: Reply with quote
I'm guessing it could have seized temporary , cooled sightly when you stopped , & allowed you to restart ? if so , you are lucky not to fek it up completely,
Smoker experts on here will be able to tell you better Neutral
edit, old git was faster typing Very Happy
connornrg
PostPosted: 17:13 - 08 Jan 2011    Post subject: Reply with quote
just do a quick check for us please and remove your spark plug and check the colour of it.
Milky = To Lean! (UPJET)
Chocolate Brown = Perfect!
Black = To Rich! (DOWNJET)
Also i would be weary of the condition of your bore now, maybe look at installing a new one or upgrading to a 70?
Bikes (Not Bikes Really Just Shitty Mopeds)
**04 - Piaggio NRG MC3**02 - Yamaha Aerox 50/100**07 - Piaggio NRG Power - Shit.**
LJColeman
PostPosted: 18:16 - 08 Jan 2011    Post subject: Reply with quote
Had a look at plug, all fne, had the head off, piston is fine ! , and nothing appears to be worn or overheated,
put the bike up on my bike ramp and let the wheel spin free, put it in 5th and reved to 9000 rpm, and the chain was leaping all over the place, and sprocket was moving a large amout,...
so im thinking maybe the chain jumped on the sprocket causing it to momentarily lock the rear, and because of this stall the engine? im going to put a new chaain and sprocket on and see how it goes..
The last post was made 15 years, 93 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.66 - MySQL Queries: 14 - Page Size: 44.56 Kb
